Old Feb 08, 2013, 07:01 AM
lacey is offline
Find More Posts by lacey
Joined Feb 2012
Ok thanks im about to print out the plans U sent n I'll decide that way will let ye know
lacey is offline Find More Posts by lacey
Old Feb 08, 2013, 12:49 PM
lacey is offline
Joined Feb 2012
ok so have done some seareching for electrics! ill link everything i have found. ok so boat will be made from balsa either 1.5mm or 3.00mm? dont really want to have to buy epoxy/fibreglass so can i not varnish or some waterproof paint instead? then i found 2 servos as ye will c will the lighter one be too weak?what ye thing of motor only problem i see is that its not in stock ye know of anything around the same? amm still looking for prop n driveshaft if ye would have any ideas? ye might have a quick look at everything else to make sure it all works together? please and thanks, jack!
http://www.hobbyking.com/hobbyking/s...ght_Left_.html
http://www.hobbyking.com/hobbyking/s...736&aff=500143
http://www.hobbyking.com/hobbyking/s...476&aff=500143
http://www.hobbyking.com/hobbyking/s...197&aff=500143
http://www.hobbyking.com/hobbyking/s...069&aff=500143
http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s...2Ch_Tx_Rx.html
Old Feb 08, 2013, 01:22 PM
builder bob is offline
Find More Posts by builder bob
builder bob's Avatar
United States, MA
Joined Oct 2011
1.5mm balsa probably will be fine with just some hard varnish. the lighter servo one might be to small but I know that I've seen some small boats with ones like that those. might get some ideas for the motor and servos from here: http://www.rcgroups.com/forums/showthread.php?t=1694339
everything else seams great!
builder bob is offline Find More Posts by builder bob
Old Feb 08, 2013, 01:35 PM
lacey is offline
Joined Feb 2012
http://www.conrad.com/ce/en/product/208233/
best i can find so far would it be too big?
Old Feb 08, 2013, 02:03 PM
United States, MA
Joined Oct 2011
prop is to big I think for that high rpm motor. gotta ask somebody with more experience about that though. stick with the old battery because it's lighter.
Old Feb 08, 2013, 02:31 PM
lacey is offline
Joined Feb 2012
ya i think so 2! will keep looking! is it too small tho? its only 1s!
Old Feb 08, 2013, 02:37 PM
lacey is offline
Joined Feb 2012
http://www.hobbyking.com/hobbyking/s...rm_2s_4s_.html
http://www.hobbyking.com/hobbyking/s...g_0_09Sec.html
should i get one of those and thats the servo?
Old Feb 08, 2013, 03:14 PM
lacey is offline
Joined Feb 2012
Also another point.. i printed out plans there but how come all the (support things, the go in middle of boat theres about 6 of them) they are in halfs? i dont really know how to explain but if you look you might understand me! tks
Old Feb 08, 2013, 03:36 PM
United States, MA
Joined Oct 2011
you could just get the motor, servo, and battery for a v911 heli and use those to power it.
Old Feb 08, 2013, 03:41 PM
United States, MA
Joined Oct 2011
servo looks good but you don't need the low voltage thing I think because the first run u can just use a timer and see how long it takes for the power to start to die, then subtract a minut and only drive it that long the next time. like on a nitro plane you never really measure the fuel, just put it in when u fly it the first time and if it doesn't die just guess to get that length of a flight next time. if it dies, don't fly as long. or you can rev it up to full on the ground and measure how long it takes to die.
I think I saw this servo being used on another small boat: http://www.hobbyking.com/hobbyking/s...dProduct=30919
here's a list of parts that probly will work: http://www.rcgroups.com/forums/showthread.php?t=1236903
I don't know how you make a flex shaft though
Old Feb 08, 2013, 03:44 PM
United States, MA
Joined Oct 2011
it's so that it's easier to draw; trace it out one way, then flip it over. the spot that looks like it's supposed to be a cut is the center line of the piece. essentially it is half of the piece. hope that helps
Old Feb 08, 2013, 04:20 PM
lacey is offline
Joined Feb 2012
ok yes i understand now thanks!
Old Feb 08, 2013, 04:33 PM
United States, MA
Joined Oct 2011
great, glad I could help!
Old Feb 08, 2013, 05:28 PM
lacey is offline
Joined Feb 2012
thanks i cant find spares for the v911 or else im not searching right! any chance u have a link? tks jack
Discussion 2.4ghz booster for long range? A bad or good idea? Koo FPV Talk 24 Nov 30, 2014 09:19 AM
Discussion Receiver Add-On Voltage Leveling Capacitor Good Or Bad Idea? itsme2 Radios 1 Jul 22, 2012 03:05 PM
Discussion Good or Bad idea or a waste of money jumpinjo Life, The Universe, and Politics 46 Apr 17, 2011 08:36 AM
Discussion Health Care Bill via Reconcilation, Good Idea or Bad Idea? Real Ira Life, The Universe, and Politics 61 Mar 04, 2010 12:49 PM
Good idea or BAD idea ? AustinTatious Thermal 7 Aug 27, 2004 02:49 PM
