Old Dec 02, 2012, 02:17 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
blade dimensions at the grip
Have a friend who flies 500 and 600 now and gave me a few unused 325mm wood blades. The grip section is waaaay to thick to fit into my grips. I just assumed wood needs to be thicker for strength.
Now I'm shopping for blades and I notice that hobby king is giving the grip sizes - one (fiberglass) is 5mm and comments say you need shims to keep them tight? Still other fiberglass blades have comments that they are too thick for the grips.
Since I don't do any 3D or high G stuff, figuring out which ones to order is no problem - I just need a new battery for my micrometer to measure my grips.
But now I am curious why they vary so much, even in the fiberglass stuff. Fat ones for higher headspeed or maybe strapping on a heavy camera?
And do some of you guys buy special grips to fit the fat ones or the skinny ones?
karlik is offline Find More Posts by karlik
Old Dec 02, 2012, 03:58 PM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
No idea why there is so much variation in that matter....
I have Spinblades (350 mm) that have blade roots that are a lot thinner than the bladegrips of my Copter-X heads.... And the thing is: I cannot find a rotorhead that has grips that are a direct fit for the Spinblades. Spinblades do not sell their own head as far as I know
It is completely beyond me, why any manufacturer would build blades with "just some" root thickness.
In the .50~.60 size there seems to be a standard of 14 mm, and even that I cannot find any info as to why it should be that measurement....
I just look for shims at the autoshop to get my blades to fit....
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Dec 03, 2012, 01:55 AM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
stick brands like Align, Rail, and Edge or Compass
i have not had any issues with blades not fitting in grips on ether of my helis
Elios000 is offline Find More Posts by Elios000
Old Dec 03, 2012, 02:03 AM
karlik is offline
Closed Account
Joined Apr 2010
I can't justify that kind of money for the kind of flying I do.
I never drive over 70, I see no reason to buy a porsche.
Old Dec 03, 2012, 07:26 AM
Elios000 is offline
Elios000's Avatar
Joined Jul 2010
Align and Compass blades are hardly high end >.>
Old Dec 03, 2012, 01:15 PM
karlik is offline
Closed Account
Joined Apr 2010
http://helidirect.com/align-325mm-32...50-p-10218.hdx
http://helidirect.com/edge-325mm-pre...on-p-18631.hdx
http://helidirect.com/325mm-pro-3d-f...50-p-10348.hdx
For what I do, those $6.30 blades will work just as well as the $40 ones.
I never asked what blades are best, what are most expensive... just why they have a variation in the width of the grip.
Wanted Blade 450 Alum Tail blade grips wbefield Aircraft - Electric - Helis (FS/W) 0 Mar 04, 2012 03:36 PM
Careful! glass blade breaks at blade grip lightfoot500 Electric Heli Talk 4 Jul 24, 2009 10:55 PM
For Sale For Sale - Compy 300 CP parts--CNC head,washout,Main blade grips,tail blade grips,mai Lonelasso Aircraft - Electric - Helis (FS/W) 0 Feb 02, 2008 09:28 PM
Off Site Compy 300 CP parts--CNC head,washout,Main blade grips,tail blade grips,main gear Lonelasso Aircraft - General - Miscellaneous (FS/W) 0 Feb 02, 2008 02:21 PM
Careful! HDX500SE : aluminum blade grip - bearing easy to leave out at factory.... Matthew Cotten Electric Heli Talk 0 Oct 16, 2007 07:57 PM
