Old Dec 02, 2012, 11:03 AM
Brian Courtice is online now
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Tricopter 2.6: Excellent anti-vibration mount
I just finished modifying my FPV Manuals tricopter by adding David Windestål's RCExplorer 2.6 version anti vibration mount. The results were excellent!
My Canon S95 camera is very sensitive to vibrations. Before now I could never get it to take clear multicopter AP photos, not even when mounted to my Y6 with AV130 gimbal.
I happened across David's Tricopter 2.6 artical here, http://rcexplorer.se/projects/2012/0...copter-v2-6hv/, and I thought, "Hmmm, that looks like it could be worth trying."
A few hours later, my Tricopter 2.6 was ready to fly! I fabricated the mounts from 1/16" ply, instead of the carbon David used, and I used 1/16" music wire for the dampers.
The verdict? I went from getting almost no usable photos with my S95, to having all my pictures come out crystal clear! I am thrilled.
My copter lifts the S95 just fine with 2213n motors, and I get about 7 minutes on a 2200 mah 3 cell battery.
Here are some shots of my tricopter, and a couple of samples from my first outing with the 2.6 damping system.
KK2 controller , 1.5 firmware
HK F-30 escs, Simonk flashed.
2213n motors
10x4.5 props
6 ch HK Orangerx receiver
Turnigy Nanotech 2200 3C battery
Hextronic D-MG16 servo
Canon S95 camera
Brian Courtice is online now Find More Posts by Brian Courtice
Old Dec 02, 2012, 02:39 PM
TLHover is offline
Find More Posts by TLHover
DLG Bug Bit Me
TLHover's Avatar
Australia, NSW, Wauchope
Joined Jan 2012
If you can put a heavier battery on there aswell it will work even better.
Your flight times will increase too.
I'm loving the 2.6 4s powered one I made.
Keep having fun.
Thanks for posting.
TLHover is offline Find More Posts by TLHover
Old Dec 02, 2012, 02:58 PM
Free as a bird now.
Joined May 2002
Thanks TL. I've been thinking about a motor and battery upgrade, but for now, my tricopter is flying pretty well with the gear it's already got.
Let's see your 4S 2.6!
Old Dec 02, 2012, 04:31 PM
Free as a bird now.
Joined May 2002
Nevermind, I think I found it. Now that is a super clean build.
Old Apr 01, 2013, 04:28 PM
TRIstyle is offline
Find More Posts by TRIstyle
Joined Mar 2013
Could you say where you got your wire for this build? I tried making this mount with some .047in music wire from the local hobby store but it isn't working right. Was very difficult to bend into the right shape and the mount just seems to make larger and lower frequency vibrations than those on the rest of the tricopter. Thanks and great build!
TRIstyle is offline Find More Posts by TRIstyle
Old Apr 01, 2013, 04:43 PM
TEDious is offline
Find More Posts by TEDious
Autodidact
Joined Jan 2012
I used .055" music wire and it worked well.... the wire was Very hard to bend nicely..... I have jello free video at 1080p
TEDious is offline Find More Posts by TEDious
Old Apr 01, 2013, 05:18 PM
AnthonysQuad is offline
Find More Posts by AnthonysQuad
Happy Holidays
AnthonysQuad's Avatar
Joined Jan 2013
I was thinking of useinh memory foam has anyone tried that somehow?
AnthonysQuad is offline Find More Posts by AnthonysQuad
Old Apr 01, 2013, 07:16 PM
TRIstyle is offline
Joined Mar 2013
thanks, I think I'll try some 1.5mm wire. Don't know how David Windestål bent his so perfectly in the new build...
Sold HL500 Anti Vibration Camera Mount ArtS FPV Equipment (FS/W) 0 Oct 01, 2012 07:21 PM
Sold 150 size anti vibration rail mounts chyorn Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 03, 2012 07:32 PM
Discussion Dubro Anti-Vibration Mount 80-91 4 stroke measurement GeetarJoe Engines 6 Mar 30, 2012 12:28 PM
