Old Dec 02, 2012, 10:51 AM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
Help!
Unstoppable tail wag
I have a clone 450, spectrum tx and receiver. I'm using a spectrum h3020 digital tail servo, my gyro is a Gy48v. The odd part is it flew great I tried to put this frame in a fiberglass body and it was to heavy so I went back to the regular frame, now it has a bad tail wag in avcs mode, so replaced the gyro thinking it went bad. Well even with the new gyro ( which is different kind from what I had) it still does the tail wag all setting are correct and have not changed since it flew good. Any idea what will make his happen this?
john_53_70 is offline Find More Posts by john_53_70
Old Dec 02, 2012, 05:42 PM
alanthor is offline
Find More Posts by alanthor
hovering-stage
Joined Dec 2012
Try decrease the gyro sensitivity (gain)
alanthor is offline Find More Posts by alanthor
Old Dec 02, 2012, 05:54 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Yeah
Might need to be re-tuned , so play with the gain ..
Also check the controls for any binding ..
Rotor speed ? has it gone up ? sometimes if you increase rotor speed it increases the sensitivity of the gyro as the tail rotor has more authority . And there probably is a few other things , but if you haven't changed anything
old4570 is offline Find More Posts by old4570
Old Dec 02, 2012, 06:08 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Well with the digital servo being used it say's to set it at zero, although I did try that and it made no deffrance. And the head speed is the same. Could I have a bad tail servo
Old Dec 02, 2012, 06:42 PM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
Look for a missing or worn down tooth on a gear.
karlik is offline Find More Posts by karlik
Old Dec 02, 2012, 08:02 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
Found it, two parts the shaft that holds the tail rotor was dry and not allowing the steering Mechanism to slide freely. So I lubed it up. And the other part was the nut that holds down the metal pice that holds the tail rotor blade was loose. So I was about to sling a blade off! Guess the old girl was trying to tell me something was wrong
Discussion T-REx 450 Sport tail wag jmparsons Electric Heli Talk 1 Nov 11, 2012 09:00 PM
Help! Tail wag Kwik-Fli DoctorG Classic Pattern Flying 12 Nov 08, 2012 04:27 PM
Help! 600 3GX Tail wag midohioboarder Large Electric Helis 0 Mar 28, 2012 08:25 PM
Help! Tail wag on spool up and spool down tonycopter Beginner Training Area (Heli-Electric) 9 Mar 17, 2012 02:54 AM
Discussion 450 pro tail wag dgibbons 3D Electric Heli Flying 3 Mar 11, 2012 12:00 PM
