Old Dec 02, 2012, 06:26 AM
T. van Vuuren is offline
Find More Posts by T. van Vuuren
Theuns
T. van Vuuren's Avatar
Joined Sep 2011
MD 500 fix
Hi all. Here is a 50 size MD 500 that a mate managed to "bend" a little. I will help him fix it as he has hassles working with glass.
I will also have to extend the boom by about 5" to fit the longer boom of the mechanics.
Theuns
T. van Vuuren is offline Find More Posts by T. van Vuuren
Old Dec 02, 2012, 10:40 AM
trucker41 is offline
Find More Posts by trucker41
cant get right !!!
trucker41's Avatar
United States, CA, Victorville
Joined Sep 2012
Theuns
gel coat and alot of sanding ! i would start by finding gel coat at the local plastic suply "its cheaper there " and for the boom i dont have a clue other than finding anothe wrecked fuse and cutting what you need and grafting it on good luck .
trucker41 is offline Find More Posts by trucker41
Old Dec 02, 2012, 10:59 AM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
On scalerchelis.com, there was a thread where a boom was repaired at a fly-in that was wrecked worse than that one. They make a tapered cone up to go inside the boom and I think it was covered with something like saran wrap so nothing stuck to it. They added glass over top and rebuilt it a layer at a time. I think the first step, however, was to use CA to get most of the large pieces back where they came from and then the glass was added over top. It was amazing to see how it was MacGivered together with litterally nothing, and flew on the last day of the weekend event. No get coat was used at the time, but the final rebuild was not shown. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Dec 03, 2012, 02:36 AM
Theuns
Joined Sep 2011
Thanx for the tips guys.
What I need to do firs is to somehow claen off the small rough epoxy bead tha holds the two halves of the boom together. There is no glass joiner tape and this is why it split open.
As soon as I have an even surface I will join with glass strip and when structural I can do all the rest.
I will extend the boom by installing a central stabilizing rod in the back of the boom and using high density foam shaped to the correct size.
This will then be epoxy glassed over onto the old boom and later with loads of sanding I hope to get a nice joint.
It is basically the same tecnique I used to make the dog box plug and molod for the 222.
The trick will be to lesten the amount of re-painting I will have to do. We will try not to repaint the entre heli if it could be helped.
Theuns
Old Dec 07, 2012, 09:27 AM
Theuns
Joined Sep 2011
Hi. My idea of cleanig off the existing epoxy bead to get even surface for the join glass would not work ,so I made a paste of epoxy and flox that I spread either side of the bead. This gave me a flat surface I can glass over tomorrow.
As for the gapinghole in the rear of the boom ,I taped a piece of cardboard over it to give the basic shape and then glassed the inside of the boom. I am sure this will be good enough to get a backing for the filler to go on.
Pix to follow.
Theuns
Old Dec 07, 2012, 09:41 AM
Keyrigger's Avatar
Joined Sep 2009
I company that makes hobby resins was recommended to me to repair my Jet Ranger body. They recommended Z-Poxy finishing resin to do the outside final finish before primer and paint. That and a little fine glass cloth for deeper filling. They said that it sands very smooth and as such can be used as if it was a fine putty to fill in spots caused by chipped gelcoat or paint. I have not got to that project yet as there is still a chance of flying in the next couple of weeks before Winter really sets in here. Take care.
Don
Old Dec 07, 2012, 10:34 AM
Theuns
Joined Sep 2011
I know the finishing epoxy well. I buy my resins from a place that supply to the full size aircraft industy. It is way cheaper than using hobby stuff and I get batch #'s and epiery dates with the epoxy. I also get my glass cloth and micro balloons/flox from them.
The hobby industry sometimes uses the exact same stuff in smaller qualtities for loads more $.
As for the small chips in the gelcaot, I usually just fill and sand them if they are small enough. The hassle comes in when trying to touch up the paint. It becomes rather hard to do and get an absolutely glass smooth finish.
I just had a look and it seems the epoxy in the boom has cured, always a good sighn LOL!
Theuns
Old Dec 08, 2012, 05:46 AM
Theuns
Joined Sep 2011
Hi.
I have done the basic repair to the boom inside top with a glass tape over my epoxy base. It surely is far from pretty but it will do.
The hole in the boom has also been filled from the inside with 2 layups of epoxy glass and will be a base to fill against.
I will use the lost plag tecnique for the rear boom extention.
Theuns
Old Dec 08, 2012, 10:09 AM
Keyrigger's Avatar
Joined Sep 2009
That looks good and solid. Nice work.
Don
Old Dec 09, 2012, 02:23 AM
Theuns
Joined Sep 2011
Solid but still light enough LOL!
Here is the plug I made for the 6" boom extention.
I made a 4 way spine and 1/4 round formers from 3mm balsa, planked it with 1,5 mm balsa and then filled and sanded the the shape I needed.
Put on some PVA to help get it out the glass and did a 2 layup of 63gr glass followed by a single layup of very fine cloth to help reduce the filler needed to smooth it out.
When cured I will fill.sand and prime ready for instenaltion on the rear boom. Luckly this shape could not be easier to make :-D
Theuns
Old Dec 09, 2012, 05:28 PM
Keyrigger's Avatar
Joined Sep 2009
You mean that 6" of the boom was missing? I know that with some chassis, you need to cut back the end of the boom but maybe an inch or so, not 6". Nice job making the plug and extension.
Don
Old Dec 10, 2012, 01:14 AM
Theuns
Joined Sep 2011
Yea , the boom seems to be to short for the mechanics. Not exactlty sure why, but it should be better this time I hope.
More acurately it needs a 4" but I made a bit extra to give some thing to work with where I need to attach the the boom.
I will first do all the filling /sanding before removing the plug as it is more solid that way and less likely to get damaged.
Theuns
Old Dec 10, 2012, 08:04 AM
Theuns
Joined Sep 2011
I got the extention sorted, I am pleased with it. Ity has been epoxied to the boom and now I will have to smooth it all out , that is going to be "fun" !
Theuns
Old Dec 13, 2012, 12:40 AM
Theuns
Joined Sep 2011
Wow, eventually I can upload pix!
OK, the extention is glued on and mostly blended in, some small holes to still fill and sand. Same with the big hole in the rear dogbox.
Nearing the priming phase :-)
Theuns
Old Dec 13, 2012, 09:52 AM
cant get right !!!
trucker41's Avatar
Joined Sep 2012
wow looks like you do some good work !!!
Sold Ares MD 500 CX 100 bruff Aircraft - Electric - Helis (FS/W) 3 Nov 02, 2012 01:13 AM
For Sale Ares Micro MD 500 helicopter bruff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Nov 01, 2012 08:34 PM
Sold MD 500 Body tkoguy Aircraft - Electric - Helis (FS/W) 0 Oct 13, 2012 01:46 PM
Sold SOLD--Trex 450 Pro with Align MD 500 fuselage rc4u Aircraft - Electric - Helis (FS/W) 2 Sep 21, 2012 12:30 AM
Sold *** Align 500 ESP with MD 500 Scale Body/Magnum PI *** Rudderman98 Aircraft - Fuel - Helis (FS/W) 1 Apr 01, 2011 05:18 PM
