No, the use of the flap changes the distribution of the circulation and that adds not more or less drag than the same movement of birds. The only difference is the distribution of the proportion of the induced drag and the profile drag.
Birds use much less change of profile drag for control than human airplanes. I still don´t know what you will tell us ![]() Control with the the induced drag? Stabilization without the side surfaces at low measure of stability is not a problem with sweep, not much more is needed. The problems start with the control. Control only with induced drag is possible. Prof. Karl Nickel flew with a ULA (no Horten, elliptical lift distribution) without side surfaces only controlled by changing the induced drag with soft, twistable elevons in 1980´s. If the idea is a twistable wing or something similar, the following links will perhaps be interesting for you ![]() http://das-nurfluegelteam.de/flex_flue.html http://www.stephanb.rchomepage.com/d...y.html#anker2b (look for "Twisteuse") Regards, Uwe. |
| Thread Tools | |
| Question Prop Type - Any Effect On Gain? UPDATE: RESULTS | Earl E Adobtr | Hoverfly Technologies | 5 | May 19, 2012 12:12 PM |
| Discussion More Stability = More Control | andrewd523 | Micro Helis | 5 | Mar 13, 2007 03:52 AM |
| Discussion More Stability = More Control | andrewd523 | Mini Helis | 2 | Mar 12, 2007 11:45 PM |
| Discussion More Stability = More Control | andrewd523 | Electric Heli Talk | 1 | Mar 12, 2007 11:04 PM |
| Control Line DS potentially more efficient than Soaring DS? | steingold9 | Modeling Science | 10 | Mar 06, 2004 04:51 AM |
