Old Dec 01, 2012, 08:39 PM
efast is offline
Find More Posts by efast
Joined Nov 2012
Nine Eagles 776 Sky Climber RC Glider balance charger flashing RED
the balance charger is flashing RED, with a beeping sound, for the Nine Eagles 776 Sky Climber RC Glider . I have a 15V 4A SkyRC adapter feeding the balance charger.
see link:
https://dl.dropbox.com/u/55140017/NE...th%20sound.wmv
any help would be appreicated
efast is offline Find More Posts by efast
Old Dec 02, 2012, 07:30 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Welcome to RCG.
After reading the abbreviated instructons on page 5, I suspect that
the flashing red light and beeper indicates the battery is at less than 2.7 volts.
"When a Li Po battery voltage is under 2.7v, the charger will not continue to charge the Li Po battery for it is over discharged." Page 5.
http://www.hobbyking.com/hobbyking/s...F_Mode_1_.html
rick.benjamin is offline Find More Posts by rick.benjamin
Old Dec 02, 2012, 10:35 PM
scottsdalejohn is offline
Find More Posts by scottsdalejohn
United States, AZ, Scottsdale
Joined Dec 2012
Did you resolve the issue?
Just purchased a Sky Climber an have the same issue you describe - I noted that the battery is close to 12v out of the box - perhaps that is the issue
scottsdalejohn is offline Find More Posts by scottsdalejohn
Old Dec 03, 2012, 12:23 AM
efast is offline
Joined Nov 2012
Originally Posted by rick.benjamin View Post
Welcome to RCG.
i actually havent even plugged the batteries in yet. I just plug my 15V adapter into the balance charger and I am getting the flashing RED with beeping sound.
sound like the balance charger is receiving incorrect power input?
Old Dec 05, 2012, 11:29 PM
Joined Dec 2012
mine is working ... i was using a noname 12 dc power supply that was actually putting out in excess of 15V. when I switched to a 12v battery all was well.
I'm guessing that you will have to hook-up the battery for it to play nice
Old Dec 06, 2012, 12:41 AM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
My rule:
1. Battery connects to the charger, then
2. Charger connects to the power supply.
In that order.
Old Apr 08, 2015, 03:46 PM
hermit81 is offline
Find More Posts by hermit81
Ukraine, Kyiv city, Kiev
Joined May 2014
small vid
New Nine Eagles 776B Brushless 2.4GHz 4CH Airplane Sky Climber (RTF) (8 min 14 sec)
hermit81 is offline Find More Posts by hermit81
New Product Nine Eagles Sky Climber chuckf Electric Sailplanes 512 Apr 08, 2015 03:46 PM
Wanted Nine eagles sky climber. 70frankie Aircraft - Sailplanes (FS/W) 1 Jun 21, 2012 08:43 PM
Wanted Nine eagles sky climber 70frankie Aircraft - Electric - Airplanes (FS/W) 4 Jun 21, 2012 04:20 PM
Sold Nine Eagles Sky 500 Ultra Micro Glider 500mm RTF alanmeyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 May 24, 2012 05:15 PM
Found Nine Eagles Sky Climber skydvejam Aircraft - Sailplanes (FS/W) 2 Mar 30, 2012 03:58 AM
