Old Dec 01, 2012, 04:58 PM
SkyRaptor is offline
Find More Posts by SkyRaptor
Brazil, São Paulo, Campinas
Joined Apr 2010
Powerlab 8 V2: System Softstart
Hi guys,
I have bought a brand new PL8 to a friend of mine and in the first test, after 10 seconds of charge, the charger stopped and showed the message: #15 System Softstart
So far I have setup more than 10 PL8 - I own 2 myself - and know how to do it..
I tested the same power supply and battery with other PL8 and it worked fine.. Actually I transferred all the configs/preset from the working one to the faulty one and nothing, same issue.
Anything I could try before return??
Alex.
SkyRaptor is offline Find More Posts by SkyRaptor
Old Dec 01, 2012, 06:14 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I would double check the connections to power supply, especially if it does not repro and low current settings. Also if you are sharing the power supply with another charger, try running it by itself.
Gregor99 is offline Find More Posts by Gregor99
Old Dec 01, 2012, 08:56 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by SkyRaptor View Post
Hi guys,
Alex.
Hi:
What are you using to connect the PL8 to the power supply? Meaning what connectors, wires, etc?
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Dec 02, 2012, 05:16 AM
Joined Apr 2010
Thanks Gregor, the issue happens even charging at low current and running alone in the power supply. I tested charging a single 6S battery at 10A and the issue is there.
Originally Posted by Tim Marks View Post
Hi:
Hi Tim, I have replaced the stock EC5 for a better 4mm bullet (4.0mm "Super Bullet" Solid Gold Connectors). I'm electrical engineer and ran some tests to check how good this connector performs. They have a resistance of about 0.25 mOhms, I mean, a voltage drop of 15mV for 60A.
Running at full power (60A), you have less than 1W of losses per connection - they don't even get hot. All PL8 I've got for my friends (10+ units) I replaced the stock for this 4mm and all performing great. I even suggest Revolectrix to run some tests and think about this connector because almost all power supplies in the market have 4mm output.
Alex.
Old Dec 02, 2012, 05:37 AM
Joined Apr 2010
By the way, when I powered it on for the first time, there was an error logged: "Cell No Add Up".. looks like the charged was used before.. Does Revolectrix run End of Line tests ?? This SoftStart error shows up after about 10 seconds of charge.
Old Dec 02, 2012, 10:37 AM
Tim Marks's Avatar
Joined Mar 2008
Hi:
Yes, the last test run at the factory is to hook up a battery and charge it for a few minutes. It is not unusual for a Safety Code to get logged during Factory testing.
But it sounds like you need to get an RMA started for that unit. Please contact Howard Matos (howard@fmadirect.com) to get the ball rolling.
Tim Marks
Old Dec 02, 2012, 12:39 PM
Joined Apr 2010
Thanks Tim, I have sent him an email.
I just wanna note this is the only unit I have got with problems - So far I have bought 23 units for my friends - we are all replacing the competitor's chargers by PL8 - and all units are performing really great.
Such great and fast support is what we expect from companies like FMA/Revolectrix.
Best Regards
Alex.
Old Dec 04, 2012, 04:06 PM
Joined Apr 2010
Hi Tim,
I have sent an email to Mr. Matos on Sunday and to Support yesterday and so far no answer at all.
Could you please help me again.
Alex.
Old Dec 05, 2012, 10:20 AM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Hi Tim,
Alex.
Hi,
Sorry, no emails received. Please try again:
Howard Matos is offline Find More Posts by Howard Matos
Old Dec 05, 2012, 11:11 AM
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by Howard Matos View Post
Hi,
Hi:
You can also cc my email tim@fmadirect.com If something comes through, I can forward it on to Howie.
Tim Marks
Sold Cell Pro Powerlab 8 Charger V2 with acc $200.00 shipped fltekdiver Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 22, 2012 09:11 PM
Question iChargers 3010B vs PowerLab 8 v2 paphman Batteries and Chargers 15 Jun 16, 2012 08:21 PM
Sold Powerlab 8 V2 Combo 1 With Mpa Balance Board newheliguy81 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 12, 2012 07:01 PM
Wanted Powerlab 8 v2 ChrisMH Aircraft - Electric - Batteries & Chargers (FS/W) 1 May 17, 2012 03:33 PM
Wanted PowerLab 6 or PowerLab 8 v2 Charger JC Spohr Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 08, 2012 08:54 AM
