Old Dec 06, 2012, 12:23 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Easier yes, but it's not aluminum . Which is what look I'm after.
pencon is offline Find More Posts by pencon
Old Dec 10, 2012, 09:06 PM
pencon is offline
Joined Dec 2008
Completed wing with sheeted aileron. I found a new source for sheet aluminum .005 thick roll 12 inches by 3 feet so the sheeting has now become way easier and quicker .I also replaced any tape I had on the plane because you could see the foam beading through it after scotch briting the surface .The second pic I took on an angle with a light shining from the side so it looks a lot more pronounced and there are still a couple of pen lines to half scuff off .
Old Dec 10, 2012, 09:51 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Looking very good.
Just check your 6 for a seeker up the pipe.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 11, 2012, 12:54 AM
pencon is offline
Joined Dec 2008
If this was done on a fiberglass wing , it wouldn't look nearly as lumpy .With the foam you pretty much have to crimp in the edges of the sheeting a bit so you don't have sharp edges coming loose. I'm going to sheet my Mig21 wing like this , but it's glassed balsa over foam core and the aluminum sheets will sit much flatter .This plane is practise sheeting for my Mig Wing .Still going to fly this though . Thinking of toying with a functional intake splitter plate to adjust the intake volume with the dial knob on my Radio .I sure hope my Futaba Fast 7 will get it 's signal through this sheeting .
Old Dec 11, 2012, 07:16 AM
cyclops2 is offline
Joined Mar 2003
Always go to the antenna trailing behind the plane. Or better. String it from the top of the vertical stabilizer to the cockpit area. The excess can be neatly coiled up in the cockpit.
A full distance range check with 2 cell phones is mandatory for metal & Carbon Fibre planes.
Old Dec 11, 2012, 10:16 AM
pencon is offline
Joined Dec 2008
My Futaba is a 2.4 ghz with a couple of 3 inch antennas . From what I've read the FASST systems are more reliable than the JR spectrum 2.4s .But definitely will range check .
Old Dec 11, 2012, 10:34 AM
cyclops2 is offline
Joined Mar 2003
I still am doing MHZ. ....
Old Dec 11, 2012, 11:05 AM
pencon is offline
Joined Dec 2008
deleted
Old Mar 25, 2013, 05:14 PM
pencon is offline
Joined Dec 2008
Another shot , Had some al tape on it but that didn't look so good so now it's all .005 sheet .
For Sale Huge Scratchbuild 90mm F-4 Phantom (Not complete- close) FlyJumper Aircraft - Electric - Jets (FS/W) 1 Jun 01, 2012 05:29 AM
Discussion Flying Heavy Metal Airplane Models. epoxyearl Scale Fuel Planes 57 Apr 13, 2012 06:21 AM
Alert Turnigy Turbine Engine released! not really... vettster Electric Ducted Fan Jet Talk 1 Mar 05, 2012 11:04 AM
