Old Dec 01, 2012, 12:57 PM
pmullen503 is online now
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
Build Log
Flying Fish.....video added
I wanted to do some sort of zoomorphic airplane and after looking at birds, bats, and dragons, I came across a photo of a flying fish. The body reminded me of the fuselage on my Ki-46 Dinah. Since I already had the fuselage mold, I decided this would be a good choice.
The pectoral fins (wings) will be about 54", I'll use the pelvic fins as stabilators. At the moment, I'm thinking just AET for controls. I'll use a curved KF3 wing.
I dusted off the Dinah molds and a couple hours later I had the fuselage shells molded. I glued in a couple 3 mm bamboo rounds (from a roll up blind I found at a home center) to add some compressive strength to the tail area.
pmullen503 is online now Find More Posts by pmullen503
Old Dec 01, 2012, 01:40 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
subscribed.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Dec 01, 2012, 02:57 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
I'm flying with this fish...
djacob7 is offline Find More Posts by djacob7
Old Dec 01, 2012, 03:08 PM
Disco Stew is offline
Find More Posts by Disco Stew
I ask a lot of questions.
Canada, AB, Airdrie
Joined Aug 2012
This one I gotta follow
Disco Stew is offline Find More Posts by Disco Stew
Old Dec 01, 2012, 07:31 PM
b36roxs is online now
Find More Posts by b36roxs
Joined Sep 2006
Awesome I've always wanted to see this!
b36roxs is online now Find More Posts by b36roxs
Old Dec 01, 2012, 08:12 PM
Joined Sep 2008
Got the internal structure in place and the halves glued together. The shells are made from $tree foam. The weight of the 30 in long shells alone is only 26g (excluding the tape covering.) I'll leave the tape on (the tape is essentially the female mold of the forming process) until I'm ready to cover it with kraft paper and WBPU to keep it from getting too beat up.
I decided to angle the stabilators (fins) down 15 degrees. I had originally drawn them with more down angle with the idea that I could use them like an inverted V tail and get some yaw control. But that would put them in the dirt on every landing so that wasn't going to work. The current angle will keep them just off the ground. I'm hoping the plane will rock forward on landing, saving the fins. Plan B will be to add some wire skid landing gear to keep them well off the ground if they are getting too beat up.
Old Dec 02, 2012, 05:59 PM
Joined Sep 2008
I pulled the tape off and block sanded the fuselage smooth. Then I gave it a coat of WBPU to harden it up.
Next, I covered the fuselage with lightweight kraft paper and WBPU.
Old Dec 02, 2012, 11:57 PM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
How about a slight variation on the fuselage...
(Stumbled onto this pic and just had to add it here)
Old Dec 03, 2012, 12:34 AM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
Oh no! Not another one!
(Hope you guys don't mind).
Old Dec 03, 2012, 04:44 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Loking forward to the maiden flight of your lovely flying fish
am a flying fish fun too
regards
Sam
20110626_19de2cdd186ef6b8c1d081rlNuRiaHGl_jpg_thum b
samwei1950 is offline Find More Posts by samwei1950
Old Dec 03, 2012, 10:36 AM
Joined Sep 2008
Creepy!
Sweet!
regards
Sam
Cool!
Old Dec 03, 2012, 11:05 AM
Snuffleupagus is offline
Find More Posts by Snuffleupagus
Snuffleupagus's Avatar
Boston, MA
Joined May 2003
This is looking to be a great build. Subscribing!
Snuffleupagus is offline Find More Posts by Snuffleupagus
Old Dec 03, 2012, 03:43 PM
Commander Clumsy is offline
Find More Posts by Commander Clumsy
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
regards
Sam
Whatever we try, the Chinese will have done it before.
Specifications, plans, other things you care to share?
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Dec 03, 2012, 04:25 PM
Joined Sep 2008
The "plan" I'm working from is in the first post. The fuselage is from an earlier build. Check that thread to find out more about the heat formed foam technique. The fuselage is about 30" long.
Wingspan will be about 54", approximately 300 sq in. Weight 16 to 20 oz. depending on the motor and battery I use. I'll pick that once I get the air frame built and see where I am on CG.
I'm kind of designing as I go but I'll try to post anything that doesn't seem obvious.
Old Dec 03, 2012, 06:42 PM
Joined Sep 2008
Wings
I'm making the wing from $tree foam using a standard KF3 airfoil with steps at 50% and 75%. I tested out a way to make a curved wing on my old Supercub. I did my best to break it and it held up so I'll use the same method here.
The building board is a piece of 1/4" plywood screwed to a heavier backing board with the outer 8" curved upward. The pieces are glued together on the board and weighted down with sand bags while the glue dries. The top piece was rolled over some pipe to form the leading edge before being glued down.
After the glue was set, I cut slots for the 1/8" plywood dihedral brace.
Discussion flying fish, started any ideas micka80ella Foamies (Scratchbuilt) 3 May 31, 2012 04:10 PM
Help! 7006 Flying Fish A-6 change frequency Gavo Racing Boats - Electric 0 Apr 18, 2012 07:24 AM
Discussion Flying and fishing not Fly-fishing. DWA Slope 16 Jul 26, 2010 08:50 AM
Yippee! New HD Fish (yes, flying fish) hybris 3D Flying 12 Apr 27, 2004 10:42 PM
