Old Dec 12, 2003, 02:35 AM
splatman is offline
Find More Posts by splatman
Vertical Wake
splatman's Avatar
visalia ca
Joined Dec 2002
which is better for foam sheeting---3M 77 or probond?
Have a big can of the old-formula 3M 77. Should I use this or probond for sheeting a large foamie?
splatman
splatman is offline Find More Posts by splatman
Old Dec 12, 2003, 02:47 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
ProBond is better, different. While the 3M leave no time to reposition the skin (tacks instantly) ProBond allow this as its gluey for a while. Cure time about the same.
ProBond also expand a little so you get bettet skin contact. Last plus is it wont wear of age or hot/humid conditions. 3M can delaminate if left direct in the sun for too long.
Haldor is offline Find More Posts by Haldor
Old Dec 12, 2003, 06:56 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I whole heartedly agree with Haldor. I actually lost the washout angle on a wing panel. Was fine when built, then later relaxed to nuetral. Caused some intense moments..
Steve
St. Martin is offline Find More Posts by St. Martin
Old Dec 12, 2003, 07:05 AM
splatman is offline
Vertical Wake
splatman's Avatar
visalia ca
Joined Dec 2002
Thanks for the advice, gentlemen! I will invest in a bottle of probond. Will this work without vac-bagging? I intend to put wieght on the wing blanks (lined with wax paper). Should i put the PB on the skins or foam?
Old Dec 12, 2003, 07:08 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Apply the PB to the skins. A very thin layer is all that is necc. Spread it thin with a plastic card. You only need to wet it.
Steve
Old Dec 12, 2003, 08:41 AM
Jim Miller is offline
Find More Posts by Jim Miller
Parkton, MD
Joined Dec 2000
Do a couple of tests first
PU glue works well but I needed a little practice. I used Gorilla Glue since I've seen reported that it doesn't foam as much. My first test was a thin layer on balsa squeegied pretty well and some white beaded FOME with no added water. I didn't care for the amount of adhesion. It stuck very well to the balsa but didn't penetrate the FOME well.
Second test was a more generous layer of PU (didn't squeegie it as thin) and some water on the FOME. It stuck well but lifted the wood a bit even though it was weighted during cure.
Last test was a well squeegied layer of PU on the wood and a sponge dampening of the FOME and I got great adhesion on both.
BTW, all tests were also done at the same time with 1/64 ply. I cut the FOME down layer by layer until I got to the glue joint to see what was really going on.
Very instructive and only took a few minutes to set the tests up.
jtm
Jim Miller is offline Find More Posts by Jim Miller
S3003 or S148 which is better for a 2M glider? arukum17 Sailplane Talk 9 Oct 25, 2005 06:42 AM
Question Himax 2015 or 2025--which is better for this application? spencer6891 Power Systems 14 Jan 25, 2005 12:23 AM
3mm depron or 3mm EPP? which is better for shockflyer clone? Ronbo 3D Flying 5 Jun 02, 2004 02:12 AM
Which is Better for Glassing Foam WB Polycrylic or WB Polyurethane? Talon Driver The Builders Workshop 15 Apr 18, 2004 11:25 AM
geared or direct drive; which is better for small sailplanes? jbrundt Electric Sailplanes 9 Aug 27, 2003 01:46 PM
