Old Dec 01, 2012, 08:42 AM
northernmike is offline
Find More Posts by northernmike
Joined May 2011
Sailmaking with Icarex - help?
Hi folks.
I recently came into a small amount of Icarex and am interested in making some suits for my micro magic fleet.
How do I glue this stuff to itself?
- Mike
northernmike is offline Find More Posts by northernmike
Old Dec 01, 2012, 10:35 AM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Double sided sticky tape; the sort with no backing material. It comes in rolls with waxed paper separation. If its too wide lay the sticky part on a clean glass sheet and cut into strips of the desired width. My local Chinese store has usually got it and no sewing seems to be required.
martin richards is offline Find More Posts by martin richards
Old Dec 02, 2012, 08:20 AM
Joined May 2011
Martin thanks!
Which one is the best?
My local art supply has "acid free", and others - some about $4, some more like $13 per roll.
Mostly 3M products.
Here in Toronto I should be able to find whatever you can recommend - any favourites?
Old Dec 02, 2012, 10:00 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
Mine is unbranded Chinese stuff. Dirt cheap. But it stands up to the weather well with no signs of it unsticking. My sales are polyester, though. I think Icarex is polycarbonate on one side at least, but it should stick just as well.
Old Dec 02, 2012, 11:45 AM
foxwyck is offline
Find More Posts by foxwyck
USA, VA, Powhatan
Joined Nov 2010
Sail panel tape
If you can't find it locally
www.midwestmodelyachting.com
1/4" x 60 yds. Super-Stick Seamstick tape for Sail Panels
Item # 364 $4.75
In Canada maybe www.leadingedgehobbies.com in Kingston might have it.
foxwyck is offline Find More Posts by foxwyck
Old Dec 02, 2012, 01:10 PM
Joined May 2011
Has anyone tried 3M #665 ? Got a roll today, looks promising.
Old Dec 02, 2012, 03:55 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
I use tape from Radio Yacht Supplies Australia - they ship globally I think
I bought:
Double sided self adhesive tape 6mm (sail seams) $7.90 AUD
Double sided self adhesive tape 9mm (sail seams) $11.85 AUD
www.rysa.com.au
Look under the sailmaking section
mrpenguin is offline Find More Posts by mrpenguin
Old Dec 05, 2012, 05:23 PM
Joined May 2011
First efforts. How can I remove the wrinkles? (the sails were cut flat... just enough tension to smooth the material)
Old Dec 05, 2012, 09:26 PM
Joined Mar 2012
I removed wrinkles from spinaker material with a cool iron.
Practice on some scraps first. Be careful.... Maybe put a cloth over the top (tea towel or something) and iron through that ?
I am not sure exactly what Icarex is - if it is like mylar (rattly etc) this may not work and could be disastrous. If it is more like material (ripstop etc) then the cool iron should be ok.
Before you make more sails, iron the material first then make the sails....
Old Dec 06, 2012, 09:06 AM
KoneWone is offline
Find More Posts by KoneWone
KoneWone's Avatar
Germany
Joined Mar 2009
Confirmed "hot iron" does not work (she is still being whipped for that one) but for some reason ironing brown wrapping paper over sails does the trick with higher temperatures.
Experiment on scraps first please !!!
KoneWone is offline Find More Posts by KoneWone
Old Dec 06, 2012, 10:05 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
The Icarex P31 is polyester coated on one side with polycarbonate. There is a newer type, PC31, in the same weight coated on both sides with polycarbonate. It is supposed to be much more wrinckle resistant and tougher than Mylar. It is also apparently used as a covering material for RC gliders.
Old Dec 06, 2012, 03:53 PM
Joined May 2011
I was thinking a warm bath might loosen it up. Worth a try? Nope. Will have to track down an iron, I suppose.
Old Dec 06, 2012, 07:45 PM
waboats is offline
Find More Posts by waboats
Joined Jan 2007
The Brown Paper using a cool Iron is a long process..
What I found most useful is to weight each corner of the sail slightly (a few grams) then let hang for a few weeks.. I sometimes fix the Boom in place then hang them.
You can spray the sails with plain water but the material absorbs very little.
Avoid steaming or anything too hot..
Use those Orange Fleuro ones for a few weeks while you wait for the wrinkles to fall out..
I've Lost Count how many sets I have hanging.. VAM, Steve A, Graphite, Bob Wing, RYSA, BG Sails, Housemartin, Graupner, amongst other sail makers.
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Dec 30, 2012, 04:58 PM
Joined May 2011
Second try.
Discussion Trouble shooting Sailmaking A.B. Sailboats 7 Mar 25, 2012 09:31 PM
Discussion Sailmaking for dummies alurpal Sailboats 3 Jan 17, 2007 10:57 PM
Discussion covering with icarex? where's thread? Joel K. Scholz Electric Plane Talk 1 Mar 12, 2006 12:18 PM
Broadseaming Block/Sailmaking Board Al Stein Sailboats 2 Dec 30, 2004 04:16 PM
Please help: looking for Icarex - Ripstop Polyerster Allan_A Electric Plane Talk 1 Dec 02, 2004 10:42 AM
