Old Dec 02, 2012, 09:58 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Originally Posted by Stupot46 View Post
Interesting discussion.I think it was nmasters(Norm)who posted a link to a paper saying that a square cut,or even concave( that would take some doing!)trailing edge performed better than a knife sharp one.I'll seeif I can find the post.
We see this theory put to the test on a almost weekly basis
I fly with a group of hard core and excellent world class pattern guys .
(Not including me- -I no longer compete thanks to a degenerative eye thing )
But anyway the theories about what needs streamlining and what does not continues .
Most of the results are simply obvious-
Shifting drag aft has alwas been a good idea - since the invention of the bow and arrow - no math /tunnel results needed here .
Years back we played with the location of canopies on simple pattern planes
depending on where the canopy was placed (front to rear) the model would change from a smooth stable flier to a tail wagger -
Nothing to do with "spirialing prop wash (hogwash)" just simple disturbances which cancelled the vertical fin's stabilizing .
Along came bigger better F3A and IMAC stuff and the old tail wag showed up on some designs
the quick fix was a strip of something on the rudder TE- anything change a low stabilizing force of the fin
It's all compromise - just like airfoils on wings -
change something - something else is usually improved OR screwed up.
I guess I could calculate it -- but obvious is obvious and I can't count past 15.
richard hanson is offline Find More Posts by richard hanson
Old Dec 02, 2012, 12:22 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
I apologize for not having completely read this thread, and I also apologize because I'm way too busy to hang out in this subforum.
But, there seem to be some severe misconceptions bounced around on this thread.
Let's look at that drag on the back end thing, with respect to tail wag.
If the plane is perfectly in line with the airflow, then that drag simply provides a retarding force on the plane. It does not provide any yaw component (minor caveats that the plane actually looks like a conventional plane).
Now, let's say the plane is yawed. The drag from the vertical tail is now offset to the side of the center of mass. That drag is in the direction of the freestream... So that drag provides a restoring force, roughly proportional to the yaw angle for sufficiently small angles.
What happens if one puts a long rod of some mass on a frictionless pivot at its center of mass, attaches a long rope to one end, stands back, and tries to pull the rod into alignment with the rope? The rod oscillates back and forth. That's essentially the contribution of drag. It doesn't dampen the oscillation but instead contributes slightly to its continuance. For those into the physics of it, it is just another variant of the harmonic oscillator problem with little in the way of damping.
There is another force that is roughly proportional to the yaw angle for sufficiently small angles. That is the lateral lift of the vertical tail. The vertical tail is a low aspect ratio wing. As is typical for wings, its 'lift' is generally an order of magnitude or so higher than its 'drag' for small angles. So that lateral lift generates a lot more force than the drag. The drag is a red-herring.
A plane turned on its side uses the fuselage as the (very low aspect ratio, inefficient) primary wing. The vertical tail acts as a horizontal tail. If one wants the plane to be stable in this orientation, the same stability rules apply as for any other orientation. One doesn't want to move the CG to affect stability, as both the stability when in normal flight orientation and the stability in knive edge are tied to the same CG. What one can do instead is things like move the canopy (moving some of the main "wing" backwards or forwards) or adding/removing area on the vertical tail (increasing/decreasing its size and moving its aero center).
BTW, the drag on the back for arrows analogy is wrong as well. Arrows are just like any other missile. If one wants the front to stay in front of the back, then there has to be positive stability and/or spin. Arrows typically use both. An arrow with a lot of drag added to the back is a flu-flu; its purpose is to prevent the arrow from going a long way, not solely to stabilize it. FWIW, arrows are stable with field or target points, with no fletching at all. That is because the CM is still in front of the neutral point, due to the point having a higher density than the shaft. It is just a lot harder to shoot such an arrow accurately.
Gerald
G_T is online now Find More Posts by G_T
Old Dec 02, 2012, 12:30 PM
Joined Oct 2007
GT you really should do some hands on testing
The turbulance from fuselage canopies does, in easily demonstrable insances - setup a condition where the fin will not hold the craft "on line" - what happens is a very nice oscillation. simply changing the flow by repositioning the canopy will stop or change the oscillation-
OR adding some drag at the rudder TE will fix the problem
Done his test/ fix over years .
Call my interpretation wrong if you will bu tI do know how to fix basic problems.
Old Dec 02, 2012, 12:33 PM
Joined Oct 2007
Gerald
The retarding upsets the oscillation - try it .
Old Dec 02, 2012, 01:17 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
If anyone wants to look it up, the term is weathercock stability.
DPATE is offline Find More Posts by DPATE
Old Dec 02, 2012, 02:19 PM
Joined Oct 2007
Look for some old codger who flew the Phil Kraft Kwik Fly models and experienced the "Quick Fly waggle".
The problem occurs simply because an absence of dihedral/sweep etc., creates a setup which is easily upset and when the craft yaws very slightly as it will-- the momentum carries it till the greater pressure DIFFERENCE starts it moving back the other way. and so on-- IF conditions are right - the waggle is a nice slight side to side movement.
Nothing requiring windtunnel testing - or textbook searching.
Oscillation is a subject which is seen in lots of applications
Old cars with poor steering damping were notorious for developing a "shimmy" or in some cases an extreme lock to lock wheel excursion.
On n on -- just an other common problem .
Old Dec 03, 2012, 11:10 PM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
Logan4169 is offline Find More Posts by Logan4169
Old Dec 04, 2012, 07:48 AM
Joined Oct 2007
Not in plank glider class-
Next question.
Old Dec 04, 2012, 09:20 AM
Joined Nov 2011
Old Dec 04, 2012, 09:39 AM
Joined Oct 2007
I will bow out -
apparantly the concept that stability can be changed with simple changes, is a litle esoteric.
Old Dec 04, 2012, 10:05 AM
Joined Nov 2011
Old Dec 04, 2012, 12:07 PM
Joined Oct 2007
The problem was simply about selecting a good fin
I just included examples about stability.
Your opinions notwithstanding --
Old Dec 04, 2012, 01:51 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Aerodynamics is aerodynamics, It doesn't matter if it's a plank or a pattern model.
Adding drag does make a model more stable. There's simply no doubt about that. Anyone that has flown a control line combat model that is a bit twitchy on its own knows that it'll settle down when there's a full leader and streamer attached to it. The effect is directly noticable by the pilot and it is VERY noticable at that.
GT, unlike your pulled string analogy the effect of drag through aerodynamic means isn't the low loss spring like pull that you'd get from your described setup with a string and direct pull. Instead the drag from a blunt tail trailing edge would tend to have a more viscously damped like force. So I suspect that it would not result in a resonance situation such as you described. And certainly the pull on a combat model's tail by the streamer would be a very strongly damped sort of pull that aids in promoting stability rather than resulting in a resonant effect. THis is again borne out by the doggy nature that is given to the combat models with streamers attached and how much they perk up and become quicker reacting as the streamer is cut away.
Still, stability through drag isn't the optimum way to do things if high speeds are the desired goal. I can appreciate it being used as a trimming option where speed doesn't really matter but I tend to not fly designs of that sort too often.
BMatthews is offline Find More Posts by BMatthews
Old Dec 04, 2012, 02:17 PM
ShoeDLG is online now
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
Drag on a tail fin certainly adds stability. Displace the tail laterally and the drag will create a torque that will want to restore the tail to its original position.
Bruce, I've got to side with GT on the question of damping. Although intuition might suggest that drag (something that tends to dissipate energy) would have a damping effect, I think in this case it will not significantly damp small yaw excursions (if at all). The restoring torque due to the drag on the trailing edge of a fin is equal to the drag times the lateral displacement. Unless the drag acting on the trailing edge drops as the tail picks up a yaw rate back toward the center, it will not provide any damping.
So unlike the stabilizing side force acting on a tail fin (which WILL drop due to yaw rate back toward the center) the drag force acting on a tail fin will not provide significant damping. It would not be difficult to set up a simple experiment to demonstrate the difference.
ShoeDLG is online now Find More Posts by ShoeDLG
Old Dec 04, 2012, 02:30 PM
Joined Oct 2007
Having seen and fixed this problem is stuff ranging from the old models -like the Kwik Fly and other models such as the little Quicky types and and on current models - Ithought the idea of increasing drag at center -especially applicable to a design such as the plank - with it's straight wing and extremely short moments .
Wouldn't have mentioned it if I had not tried it in various apps .
Question Flat-bottomed airfoils.. FlyBoy20 Beginner Training Area (Aircraft-Electric) 9 Nov 30, 2012 02:39 PM
Discussion Aerodynamics of flat plate control surfaces behind normal airfoils digiex_chris SPAD - Simple Plastic Airplane Designs 22 Jun 27, 2012 01:54 PM
Question Flat airfoil flightmaster909 Foamies (Scratchbuilt) 8 Apr 19, 2012 11:11 AM
Discussion Shaped or Flat? 62pilot Foamy EDFs 2 Apr 06, 2006 05:40 PM
55" Spitfire - or when does a flat airfoil stop flying Ralph A. D'Amelio Scale Kit/Scratch Built 18 Oct 24, 2004 10:11 PM
