how do i use a standalone UBEC?
http://www.hobbyking.com/hobbyking/s...BEC_3A_5v.html
im gonna buy this for the HK 40-50 amp opto ESC's. im trying to figure out how it works. |
![]() "You then plug in ESC to throttle channel and the UBEC Rx plug to any spare Rx socket ... as all + / - pins of Rx are common." |
United States, OR, Portland
Joined Jan 2012
Option #2 if no open Ports on RX:
Release the pin locks from the BEC rx plug & slip them into the two open slots on your opto ESC plug (if ESC has built in BEC remove & cap +/- leads, then replace them with leads from the stand alone BEC). ~psguardian |
| Thread Tools | |
| Discussion How do i know if i need a UBEC? | xfatdannx | Electric Ducted Fan Jet Talk | 9 | Jul 10, 2012 10:50 AM |
| Question how much overlap do you use with lam film?? | grfcon | Slope | 5 | May 01, 2012 04:47 PM |
| Help! How should I do? Spektrum JR modul to be used on a Sanwa/Airtronics radio??? | marell01 | DIY Electronics | 0 | Mar 22, 2012 05:37 AM |
| Discussion UBEC 6 channel rx,six channels used,where do I put the UBEC lead? | Matt Halton | Electric Warbirds | 6 | Apr 03, 2008 11:34 AM |
| Discussion UBEC 6 channel rx,six channels used,where do I put the UBEC lead? | Matt Halton | Radios | 1 | Apr 03, 2008 02:43 AM |
