Dec 12, 2003, 07:49 AM
Gladstone, Queensland, Australia
Joined Nov 2002
Hi,
If you are after a 25ish powerplant that is not expensive (see brushless li-poly etc) I would start with 10 cells and a geared magnetic mayhem or endo. As the chute flys very slowly you would gear for a relatively low pitchspeed with a large diameter.
You could probably fudge some figures in motocalc. If the chute is 24" x 62" it is 10.3 square ft @ 40oz = 4.6 oz/ per square ft.
Good luck & post some photos!!
Regards
Phil
