Old Nov 30, 2012, 10:16 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
DLE 55 or DLE 55 RA ?
Think I'm gonna get a Extreme Flight 88" Edge. Will be my first gasser. The RA has 1,000 more RPM's and rear exuast. The RA is $70 more. Will I notice a difference ? Do I need this extra RPM ? And would it sound different. I appreciate any input. I shoulda put this in Engines, sorry.
Dale 813 is offline Find More Posts by Dale 813
Old Dec 01, 2012, 05:09 AM
yankphan is offline
Find More Posts by yankphan
yankphan's Avatar
United States, FL, Cape Coral
Joined Jan 2011
Both engines are great... Less chopping up your cowl with the ra... The ra will be a little louder. Either way...can't go wrong.
yankphan is offline Find More Posts by yankphan
Old Dec 27, 2012, 08:26 PM
Dane McGee is offline
Find More Posts by Dane McGee
Sho Nuff Combat Pilot
Dane McGee's Avatar
United States, TX, Greenville
Joined Mar 2008
The RA comes with a pitts style muffler, so its a wash.
Get the RA
Dane McGee is offline Find More Posts by Dane McGee
Old Dec 28, 2012, 04:22 AM
bladebender is offline
Find More Posts by bladebender
United States, MI, Waterford Charter Township
Joined Apr 2008
Get the RA troy built has 10% off right now .To many cowls cut up with side exaust
bladebender is offline Find More Posts by bladebender
Old Dec 28, 2012, 05:45 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
Reports have discussed the RA's muffler as loud and some tell of it's falling apart. Might be a consideration if you are at a noise sensitive field. The older 55 generates the same power at a lower rpm, allowing it to pull more pitch and generate less noise. I am a big fan of DLE engines so the comments are for information only, not any attempt to disparage.
Lifer is offline Find More Posts by Lifer
Old Dec 28, 2012, 07:00 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Yeah. I ended up buying a buddies plane that already had the regular DLE55. I love it. I noticed that the RA style has a Pitts style muff but the piped don't extend far enough to exit the cowl. So making the person add extensions.
Old Dec 31, 2012, 12:11 PM
rica1 is offline
Find More Posts by rica1
United States, CA, Chula Vista
Joined Apr 2005
An extra 1,000 rpm's is nice. The RA will fit in a narrower cowl but it's going to be louder (problem if to loud at your field). These may be worth the extra money to you.
You may want to check the measurements of both engs from your firewall to the prop hub for best cg on your plane. Let us know what you decide.
rica1 is offline Find More Posts by rica1
Old Jan 02, 2013, 02:06 PM
Sewerdude is offline
Find More Posts by Sewerdude
United States, IN, La Porte
Joined Apr 2008
1000 more rpm? Come on. Maybe 100-200 rpm increase.
Sewerdude is offline Find More Posts by Sewerdude
Old Jan 03, 2013, 04:03 PM
yankphan is offline
yankphan's Avatar
Joined Jan 2011
The RA comes with silicone muffler down tube extensions. I have both engines and prefer the RA... Can't notice a differnence in power but I do like the RA better because there is a lot less cutting of the cowl.... Much cleaner look.
Old Jan 07, 2013, 12:05 PM
rica1 is offline
Joined Apr 2005
Can you tell us if there is an RPM increase with the RA and if so, how much?
Old Jan 08, 2013, 10:53 AM
ChrisCYWG is offline
Find More Posts by ChrisCYWG
Joined Sep 2010
When you guys talk about cutting off excessive cowl.. this only really pertains to if you don't use an after market wrap around Pitts muffler vs the sidemount correct? I have a few planes that I will be starting shortly that I will be installing the DLE motor on and really want to limit the amount of cowl hack... The rear mount is an added benefit right away as it eliminates the need for an aftermarket muffler...
ChrisCYWG is offline Find More Posts by ChrisCYWG
Old Jan 12, 2013, 06:40 AM
19pointbuck is offline
Find More Posts by 19pointbuck
19pointbuck's Avatar
Canada, MB, Carberry
Joined May 2012
DLE 55RA vs DLE55 mounting
I bought a used AW Pitts Python in which didn't come with a engine. The firewall has been drilled for a DLE55. I haven't decided which DLE to buy yet, but I did see on a site were it looks like the firewall bolt pattern is different between the rear exhaust and the side exhaust. Can someone comfirm this for me or is the difference enough to redrill the firewall without the holes beening so close together and weaking the firewall? thanks(new to gas n gaints)
19pointbuck is offline Find More Posts by 19pointbuck
Old Jan 22, 2013, 02:05 AM
fupshaw383 is offline
Find More Posts by fupshaw383
"Air to Ground in No Time"
fupshaw383's Avatar
USA, NM, Las Cruces
Joined Feb 2011
Yes. There is a big difference in the bolt pattern for the RA. I'm building a Top Flight giant Corsair built for the regular 55. The RA is wider in all directions. Any one got the new bolt pattern by chance?
fupshaw383 is offline Find More Posts by fupshaw383
Old Jan 22, 2013, 06:32 AM
dgiatr is offline
Find More Posts by dgiatr
Joined Apr 2010
hi, i would like to ask if the new type dle 55 will swing a 24x8 3 blade prop and at what rpms.
does anybody know;
thanks. i like using fiala 3blade props.
dgiatr is offline Find More Posts by dgiatr
Old Jan 23, 2013, 08:10 AM
fupshaw383's Avatar
USA, NM, Las Cruces
Joined Feb 2011
does anybody know;
I have a BME 50cc that will swing 22x8 and 22x10 with little issues. The 22x8 is optimum. I am intalling the DLE55RA on a bird I am building right now planning on using 23x8. I think a 24x8 may be pushing it a little depending on your altitude, type of flying and other factors.
For Sale FS or trade DLE 30 for a DLE 55 scottiesoccer1 Aircraft - Fuel - Engines and Accessories (FS/W) 3 May 02, 2015 07:51 AM
Wanted Pitts Muffler for DLE 55 or DA50 mmclaug858 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 23, 2012 05:57 PM
Sold J'tec dle or dla 55 wrap around muffler mike wiese Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 10, 2012 05:47 PM
Wanted DLE 30 --- DLE 55 --- Saito 180 flyingstickers Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 22, 2012 11:32 AM
Wanted Wanted DLE-55 & DLE-20 cncmachine Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 14, 2012 11:20 AM
