This thread is privately moderated by jgalexander, who may elect to delete unwanted replies.
Old Nov 30, 2012, 08:22 PM
jgalexander is offline
Find More Posts by jgalexander
Trader Rating: 838
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Trader Rating: 838
Sold
TamJets 90mm EDF, Wemotec Midi Fan, Neu 1415 2y motor, Castle Creations 85HV ESC
TamJets 90mm EDF, Wemotec Midi Fan, with Neu 1415 2Y motor, Castle Creations 85HV ESC in the tailcone.
User Data:
Here's some performance data from one of Corsair Nut's posts in the TJ90 thread. Speeds above 150mph in a Jet Hangar Hobbies F-86:
http://www.rcgroups.com/forums/showp...7&postcount=17
http://www.rcgroups.com/forums/showp...9&postcount=54
Specs:
Specs courtesy of Tam:
Tamjets 90mm Midi fan
Our TJ90 is basically a shrunk down version of the TJ100. It shares all the same parts as the TJ100. The best part about our TJ90 is the very light weight, rigid carbon fiber shroud and the aluminum motor body for cooling. With all these nice features, we are able to run at high power without over heating the motor. This fan was made for guys who want to run high power and fly back to back without having heat problems. This is the most high power reliable fan unit and also very efficient.
Test Data:
Lipos: 10s
Watts: 3119
Amps: 83.1
RPM: 48076
Thrust: 8.6 lbs
Efflux Velocity: 210mph
Exhaust tube: 72mm
NeuMotor 1412 2Y
http://www.tamjets.com/original/prod...4362dd2dbc08c9
$850 new from Tam, $425 shipped from me with Paypal, or $400 if paid by money order, check, etc.
Ships USPS insured with tracking and signature confirmation.
Thanks for looking,
Josh
Here's a video of the same setup in a 1:12 F-16. Excellent speed and vertical
Skip to 1:20 and 2:30 for some nice fast-pass action
Tamjets F-16 TJ90 midi rotor.wmv (4 min 36 sec)
jgalexander is offline Find More Posts by jgalexander
Sold TamJets 90mm EDF, Wemo, with Neu 1415 2y motor, Castle Creations 85HV ESC jgalexander Aircraft - Electric - Jets (FS/W) 7 Nov 28, 2012 04:52 PM
Sold TamJets 90mm EDF, Wemotec Midi Fan, Neu 1415 2y motor, Castle Creations 85HV ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 2 Nov 19, 2012 09:36 PM
Sold TamJets 90mm EDF, Wemotec Midi Fan, Neu 1415 2y motor, Castle Creations 85HV ESC jgalexander Aircraft - Electric - Jets (FS/W) 0 Oct 22, 2012 06:59 PM
Sold TamJets 90mm EDF, Wemotec Midi Fan, Neu 1415 2y motor, Castle Creations 85HV ESC jgalexander Aircraft - Electric - Jets (FS/W) 0 Oct 15, 2012 06:33 PM
Sold TamJets 90mm EDF, Wemo, with Neu 1415 2y motor, Castle Creations 85HV ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Sep 12, 2012 04:22 PM
