Old Nov 30, 2012, 07:31 PM
Hmerly is offline
Find More Posts by Hmerly
Hmerly's Avatar
United States, AL, Huntsville
Joined May 2012
A30 10XL V2 - 900kv coming apart
I've got an A30 10XL V2 900kv motor and recently noticed that if I pull on the end where the shaft protrudes from I can pretty much take the motor apart. I've pulled the casing off and can push it back together. It does take a little effort, but seems out of the ordinary. I certainly can't do this on any of my other motors. Is this motor destined for the garbage bin? Is the locking mechanism, whatever it was, damaged or missing? Thanks to anyone with any ideas.
Hmerly is offline Find More Posts by Hmerly
Old Dec 03, 2012, 07:36 AM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
hmerly - It sounds like your motor may be missing the C-Clip from the motor shaft, or possibly some loose set screws?
Either way, Hacker stocks replacement parts - give us a call at Aero-Model at 480-726-7519 and we'll figure out what you need!
FL62 is offline Find More Posts by FL62
Old Jan 19, 2013, 11:56 AM
Hmerly is offline
Hmerly's Avatar
Joined May 2012
I noticed my Hacker A30-10xl v2 's can is moving. If I use my hands I can nudge it back and forth. It is coming into contact with the mounting plate where the wires come through. Is my motor dead or can this be fixed? Any idea what has happened?
Old Jan 20, 2013, 09:26 AM
FL62 is offline
FL62's Avatar
Joined Feb 2004
Hmerly, as I mentioned, please give us a call.
It is difficult to say what the fate of your motor is without seeing it.
The problem you are describing could be from a number of things - bent can from a crash, failed bearing, bent front plate, etc.
Wanted Hacker A30-10XL V2 (900kv) rclab1 Aircraft - Electric - Power Systems (FS/W) 0 Nov 28, 2012 08:01 PM
Discussion Hacker a30-10xl-v2 900kv problem Hmerly Power Systems 1 Oct 25, 2012 09:11 AM
For Sale Hacker A30-10XL 900KV $35.00 YellowJacketsRC Aircraft - Electric - Power Systems (FS/W) 2 Jun 29, 2011 08:05 AM
For Sale A30-12XL V2, A30-10XL, Pulso 2820/14 sgomes Aircraft - Electric - Power Systems (FS/W) 4 Jun 23, 2011 12:32 PM
Sold Hacker A30-10XL 900Kv Brushless motor SOLD!!! Chad1979 Aircraft - Electric - Power Systems (FS/W) 1 Feb 27, 2009 08:44 PM
