Old Nov 30, 2012, 05:04 PM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Arduino Based CL Timer for Speed
Hi Everyone !
I want to show you my DIY - Timer made of an Arduino Nano Board.
Still in development, but it already works a bit.
It is designed for Speed Applications, but with other software it would be possible to use it for everything else.
Flight time in the Video is shortened for testing.
The LED means :
Red - Akku connected
Yellow - initialising of the controller (blink) and accelerating or braking (steady)
Green - Full Throttle (steady) end of flight (blink)
Weight is 17g.
It is planned that the accelaration stops at a adjustable throttle to grab the speed pole and place the fork for a time.after that it will go to full throttle, like a reso would do after whipping. It is already programmed but yet not tested.
You can adjust :
amount of accelaration ( that you have a softer start)
Plateau time
Plateau speed ( plateau means the "reso" imitation)
It`s missing the start switch, have to buy one first. It is possible to connect it to the bellcrank as a shutoff.
Here is the link to the video :
F2G Fesselflug ElektroSpeed Timer auf Arduino Basis (0 min 51 sec)
Oh, battery was weak, so it didn`t reach top RPM`s.
Best regards and ever tight lines ,
Sebastian
flyinglog is offline Find More Posts by flyinglog
Old Nov 30, 2012, 09:14 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
These flyers in Switzerland could use it!
Speed Elektro (0 min 40 sec)
coriolan is offline Find More Posts by coriolan
Old Dec 01, 2012, 03:34 PM
JimnAz is offline
Find More Posts by JimnAz
Joined Mar 2007
This looks really interesting. Do you have the code for it you would be willing to share?
JimnAz is offline Find More Posts by JimnAz
Old Dec 03, 2012, 10:19 AM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hi Everyone !
Here is the code.
Have much fun building !
It would be wise to add a additional switch to prevent the motor from accidental running.
The code is the Version with the "plateau" . It is now tested and runs fine.
Change the file extension from .txt to .ino, then it will work
Best Regards,
Sebastian
Old Dec 03, 2012, 11:32 AM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello again.
Something went wrong with the text in the other File .
Please use the new one.
Just copy&paste it to the Arduino IDE.
Regards, Seb
Old Jan 07, 2013, 11:15 AM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello !
New Hardware update !
No potis anymore and just one RGB LED. But now i have extra a button to start the engine besides the Main switch. Main Switch also acts as a energy shutoff, when linked to the bellcrank.
Pen is for size comparison .. .. ?..
Now much better for installation.
Have to do the Software now.
Best Regards, Sebastian
Old Jan 08, 2013, 10:01 AM
saab2 is offline
Find More Posts by saab2
United States, CA, Carson
Joined Dec 2012
Great stuff..
I am thinking to get C/L in electric as well...will update you guy when I am done with it..
saab2 is offline Find More Posts by saab2
Old Jun 26, 2014, 03:50 PM
mpoduje is offline
Find More Posts by mpoduje
mpoduje's Avatar
Santiago, Chile
Joined Mar 2005
Hello !!
I'm very interested in your arduino based timer, i want to develop my own timer for F2B.
I'm a a newbie in arduino projects, but i want to build my own timer and i will buy a arduino nano board.
I think your code is the same that i need to F2B timer.. i need to control the speed, the time and one switch to start. I think in other functions like a delay between the start button and start engine, in order to have time to run to the handle. Other function may be a signal before engine stop.
Thanks for your code, i will try to start.
mpoduje is offline Find More Posts by mpoduje
Old Jun 10, 2016, 11:39 AM
trevizan is offline
Find More Posts by trevizan
Joined Jun 2016
Flyinglog, thanks for sharing the project. I made the timer and it worked fine.
Could you share the timer software with buttons? (No potis anymore and just one RGB LED).
I practice C / L in Brazil, f2b.
Thanks for sharing the project.
trevizan is offline Find More Posts by trevizan
Old Jun 10, 2016, 06:24 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello !
I will see what i can find on my HDD.
I did not write it to the end, because i now use a 2,4 ghz RC-Car Transmitter in my left hand, much easier to fly when you are alone and more than enough for my low , fast on/of flying
For F2B i would recommend a "real" timer with G-Force sensors to control Motor RPM.
Best regards,
Sebastian
Old Jun 11, 2016, 04:49 PM
trevizan is offline
Joined Jun 2016
Thanks very much,
Discussion Arduino based IR tag module for combat sh4nce Combat 38 Feb 18, 2015 04:02 PM
Help! Engineering student and first arduino based build? cad2blender UAV - Unmanned Aerial Vehicles 3 May 17, 2012 07:59 AM
Discussion What are the Orange Rx pin configuration for a Arduino based quad? Drone Reasearch Multirotor Talk 6 Jan 24, 2012 09:04 PM
Discussion Wrist Mounted Ultrasound Arduino Based Sonar for the Blind rcgroupie DIY Electronics 2 Aug 24, 2011 01:25 PM
