Old Nov 30, 2012, 04:10 PM
Subdave is online now
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
Build Log
Boomin Beaver Helicopter Tug!
Well if that did not get your attention nothing will.
Well in my ultimate quest for the best rescue tug I have yet another master plan.
(Cue the evil laughter)
Although my Toot 14" logging tug worked out great and is extremely maneuverable.
It kind of morphed into a pulling tug.
I want something even smaller and more maneuverable.
My answer is I hope, a 12" version of a 14' Bronc tug.
That would make the scale 1/14.
Odd scale but since I am building more for size and function it is not a problem for me.
I have always wanted to build a Bronc as I think they are so homely they are cool!
Now where most Bronc's are driven by a Z drive in the bow. (Front wheel drive)
My plan is to use another drive system I have always wanted to try, a Voith eggbeater type.
I acquired an old Graupner unit a few years ago for another project but I want to use this system in pace of the Z drive.
I also will be using a bow thruster mounted in the stern.
So I guess it will be a stern thruster.
This should give helicopter like maneuverability.
The Voith will move the tug just like the main rotor of a heli as the Voith is just like a swash plate in the way it works.
The stern thruster will work just like a tail rotor.
I will set up the radio the same way.
In a normal Voith set up two drive units are used so the boat can spin.
But using the stern thruster like a tail rotor should do the same thing.
I am in the design stage now.
I found a set of plans I like.
I plan to construct the hull similar to how the real one is made, but where 1/4" sheet steel is used I will be substituting sheet fiberglass.
Great stuff that I get from McMaster in different sizes and thicknesses.
The tug is called the Boomin Beaver! I love it!
Hopefully I have it all worked out.
Time will tell. Dave.
Subdave is online now Find More Posts by Subdave
Old Dec 01, 2012, 07:30 AM
Subdave's Avatar
Rochester NY
Joined Mar 2005
Here is the tug.
Old Dec 01, 2012, 11:57 AM
Subdave's Avatar
Rochester NY
Joined Mar 2005
Here are some photos.
I designed and made a stern thruster.
I have a photo of the Voith drive.
And a photo of the drive parts sitting on a full sized plan of the tug.
Old Dec 01, 2012, 12:39 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Should prove very maneuverable.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Dec 02, 2012, 02:58 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Rescue Tug
I have found that my LITTLE, 1/24th Truckable Towboat, works great. PLUS, it has two push knees, so it stays attached to what I am recovering, much better. The guy's in the club, think it works great, and my turning radius, is way under your boom boat. It's 12'' long, and only 5.5'' wide, weighs 3.75 lbs. I have not driven a better recovery boat yet! CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Dec 02, 2012, 04:03 PM
Greg W is offline
Find More Posts by Greg W
AKA Mr Pita
United States, NY, Rochester
Joined Apr 2007
what will that voith drive do to my conning tower when you run over my sub that you're trying to rescue? Greg
Greg W is offline Find More Posts by Greg W
Old Dec 03, 2012, 07:37 AM
Subdave's Avatar
Rochester NY
Joined Mar 2005
Very nice rescue tug.
But my Bronc should be able to spin on its own axis. Can't get much tighter than that.
Well Greg the tug actually sits quiet low in the water and will have a shroud around the blades.
The front pusher extends down as low as the drive as well.
So I don't think there is any extra damage potential.
Unless I add spikes like the real one instead of rubber pads.
I could actually put the hydraulic spike arm on the front and harpoon the subs and targets. Dave.
Old Dec 03, 2012, 08:44 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Subdave
That is the early drive, and they have TWO problems. One, they leak water into the boat, and two, the shafts are High Carbon Steel, and they rust, freezing up the unit. Changing the "C clips" on the blades, to SS helps. As does, using a PLASTIC FRIENDLY, waterproof grease. Most all of the tugs around here that had them, are long retired, or were switched to Z-Drives. CaptCB
Old Dec 03, 2012, 09:22 AM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
If there's anyone who knows how to keep a model dry, It's Subdave.
D
CaptDH is offline Find More Posts by CaptDH
Old Dec 03, 2012, 10:28 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Quote....This should give helicopter like maneuverability.
Ermmmm.... a helicopter moves in 3D a boat in 2 (U-boats in 2 D) so the question is can it fly?????
Sharky1dk is offline Find More Posts by Sharky1dk
Old Dec 03, 2012, 11:38 AM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I am sure it could sink...
Old Dec 03, 2012, 12:27 PM
Subdave's Avatar
Rochester NY
Joined Mar 2005
That is true!
Hhmmmmm!
But we prefer submerge to sink.
I guess I should have said helicopter like in its X and Y axis travel.
Thanks for the tip on the SS C clips. CaptCB
I did know about the leaking problem as when I got mine it was seized.
Very poor design on their part using the motor shaft bearing as a seal.
I toyed with trying to add an O ring but not enough room.
What I did was pack the bearing with Stuph and waterproof drive shaft lube.
I also sealed the motor mount flange with RTV.
Hopefully this will keep out most of the water.
I am fascinated with anything cool and unusual like the Voith drive so it is more an experiment.
I am sure the Z drive would be a better option for practicality.
But what is the fun in that! Dave.
Old Dec 03, 2012, 01:12 PM
Ivanho is offline
Find More Posts by Ivanho
Ivanho's Avatar
Joined Apr 2008
Some of Dave's submarines have been known to fly... literally. Flying a tug should be no problem for him, particularly if he installs the usual brushless power plant.
Greg, your safest bet would be to just stay in port while SD is patrolling.
Ivanho is offline Find More Posts by Ivanho
Old Dec 03, 2012, 01:34 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Interesting enough there are a couple of Bronks mthat do have mini Voith drives on them. Although the prefered method is a quick acting Zdrive system that makes theses things behave like a Texas tavern bull ride..... wild and better be hanging on!
keith S is online now Find More Posts by keith S
Old Dec 03, 2012, 04:56 PM
Subdave's Avatar
Rochester NY
Joined Mar 2005
Thanks Keith.
It is cool to know some of them do have Voith drives.
Must be the ultimate bumber car ride.
I started on the hull today.
I used 1/8" fiberglass sheet for the top and bottom.
The sides are 1/32" sheet.
I am using standoffs to keep the top and bottom in the proper place until I wrap the side sheets around and epoxy them. Dave.
New Product CMP Beaver vs Eflite Beaver velyter Waterplanes 3 May 07, 2012 06:20 AM
Discussion Boomin winds for the weekend! TFLG Slope 26 Mar 04, 2007 08:37 PM
Discussion Lake Hills is BOOMIN' TFLG Slope 9 Dec 30, 2006 12:31 AM
Boomin At Torrey Bill L Slope 10 Dec 14, 2003 12:19 PM
Boomin lift at Cardiac TFLG Slope 14 Nov 21, 2002 02:20 PM
