Old Dec 25, 2012, 07:57 AM
redC5 is offline
Find More Posts by redC5
redC5's Avatar
United States, GA, Clarkesville
Joined Jul 2010
"A spline is a smooth curve passing through a given set of points.
Splines are useful for creating irregular-shaped curves, for example, drawing contour lines for geographic information system (GIS) applications or automobile design."
Comes in handy for tracing around irregular curves.
I have been using ACAD for hobby purposes for 15+ years and I discover something new almost every time I use it.
Great fun to me!!!
redC5 is offline Find More Posts by redC5
Old Dec 25, 2012, 07:09 PM
BJ64 is online now
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Thanks for the explanation
I'm wondering if that's the same meaning in DevFus Foam in the 'Splines' section. I took it as meaning drawing a set of lines parallel to the former's cross-section so that you produce a hollowed-out fuze core rather than a solid one.
Maybe it's referring to the type of line being used rather than the actual process of forming a hollow fuze?
BJ
BJ64 is online now Find More Posts by BJ64
Old Dec 25, 2012, 08:35 PM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Devfusfoam uses splines to form section shapes. The control points changes the spline to fit the shape of the formers.
p901P901 is offline Find More Posts by p901P901
Old Dec 26, 2012, 11:27 PM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
Originally Posted by BJ64 View Post
Merry Christmas, guys.
BTW - what exactly are "splines"?
I hear them referred to quite often, but I'm not exactly sure what is meant by them.
Are they perhaps those squiggly types of line you can click on/add 'nodes' (control-points) to, then push and pull the line to make it contour a complex curve?
BJ
Those would be splines. It is the CAD equivalent of drawing something with a french curve.
SRWitt is offline Find More Posts by SRWitt
Discussion Vintage & Old-Timer Plans PRE 1977 PLANS ONLY Mooney_Driver Vintage & Old-Timer Designs 665 Mar 16, 2016 02:26 PM
Discussion Photos of an old home undergoing an effort to save it. Navy Jet Mech Aerial Photography 10 Nov 19, 2012 05:38 AM
Wanted old swash for 450 clone is fine anybody got an old beater swash?? blueindian Aircraft - Electric - Helis (FS/W) 0 Sep 29, 2012 11:29 PM
Question Suggestions for an old timer build using an FS20 or 26. mrcosmo Vintage & Old-Timer Designs 31 Apr 14, 2012 08:45 AM
CG on an old CL/FF plan J Morgan Electric Plane Talk 3 Dec 20, 2002 08:29 PM
