Old Dec 07, 2012, 12:30 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Fair enough - and thanks for replying.
Was worth asking in here though.
Someone with that kind of knowledge might just read it and be able to point me in the right direction.
BJ
BJ64 is offline Find More Posts by BJ64
Old Dec 07, 2012, 09:33 AM
RCROBBY is offline
Find More Posts by RCROBBY
Laser Cutter Guy
United States, PA, Greensburg
Joined Oct 2009
Originally Posted by BJ64 View Post
I've asked this in another thread (slow response), so I hope you don't mind me asking it again in here.
I'm new to CAD/CAM & CNC, but I'm looking for some simple and cost-effective software that will allow me to input some accurate cross-sections, arrange them as per the offset's (spacings) on the plan, and then CNC hotwire the fuselage foam sections from there (to end up with a plug to mold from).
I've had a look at DevFus and DevFus Foam etc. - but they seem to go the other way. i.e. input a 3-view and create the cross-sections from that. As well as the 'virtualized' 3D fuze sections.
I need to find something that will accept my cross-sections + known spacings and produce to a 3D solid and cut from there.
The 'long hand' way to do it, of course, is to cut all the cross-sections in something like 3mm ply, cut the foam to the required spacing, and manually hotwire around each 'sandwich section'. But that's a lot of scroll-sawing, smooth-filing etc. of ply, then arranging that lot to build up a set of foam sections. If I could do away with the woodwork, and just use a CNC hotwire to produce the foam sections, it should end up saving me a heap of work.
Any info would be greatly appreciated.
BJ
Look at this one... http://www.gmfcsoft.com/
RCROBBY is offline Find More Posts by RCROBBY
Old Dec 07, 2012, 11:32 AM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
SRWitt,
I too have been playing with that particular plane in TurboCad. I am setting mine up to be laser cut. Between that and many other projects, I'm not making much headway, on any of them. Most of my work has been on a Tackhammer. Neat little 1/2 A. Good luck.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Dec 12, 2012, 03:04 AM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
So I havent started building my 22" span mockup build, maybe tomorrow, its cold outside in the garage as of late. But I have been working on the cad drawings for the scaled up version. I've also fixed the fuselage side patterns after scaling, I went from 1/16th formers and vertical/horizontal stabilizers on the 22" span, to 1/8" for the 33" span, slots needed modification. The only real work left is drawing up the motor I'm going to use to make sure it fits in the front of the plane, layout the wing, and figure out the servo and battery trays, I am also having to think out how I will build up the cowl, Ive got side/top profiles, not sure If Ill make some formers to fill with foam then carve/hollow or if I'll go with a firewall and nose former and build it up with sheet. Vacuforming is a little out of my range of capabilities at the moment.
Heres a shot of the wing rib/structure. The red areas at the LE/TE on top and bottom are 1/32" sheeting, the light blue is 1/4x3/16 spars the purple is 1/16" sheer webs, the off yellow areas top and bottom between the main spars and TE will be 1/32x1/4 cap strips, the light blue at the TE is 1/8x1/8 spar, with a 3/16x5/8 TE. I've taken the rib profile from the Telemaster 400 drawing, and have scaled it to have the chord proper for the CUB model. I still have to lay out the actual wing structure and modify the CUB tips to work with the new rib profile.
Once I get the actual wing layed out, the rib will be modified to show the cuts for ailerons/flaps.
SRWitt is offline Find More Posts by SRWitt
Old Dec 12, 2012, 08:54 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
On a plane this size you wouldn't need a vacuum system to make a cowl. Just make your cowl plug to the shape you want it then use your heat gun and a clean empty soda bottle. Slowly heat it up and the plastic of the bottle will shrink right around your plug.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Dec 13, 2012, 07:13 PM
SRWitt is offline
Joined Jan 2011
Some pics of the 22" span mockup of the original plan.
Old Dec 13, 2012, 07:22 PM
Flying Low
Joined Mar 2012
Looks good
Old Dec 14, 2012, 01:30 PM
SRWitt is offline
Joined Jan 2011
The wings are being built.
Old Dec 20, 2012, 07:50 PM
redC5 is offline
Find More Posts by redC5
redC5's Avatar
United States, GA, Clarkesville
Joined Jul 2010
I have ACAD R-14 and have converted a PDF drawing to a .DWG file.
The lines need a lot of cleaning up and I quess I need to "Explode" the drawing to get individual parts.
My question is how do you "Trace" the drawing without have to redraw each part???
Julian
redC5 is offline Find More Posts by redC5
Old Dec 21, 2012, 09:23 AM
RCROBBY is offline
Laser Cutter Guy
Joined Oct 2009
Julian
You have to redraw each part. This is time consuming as you probably already know. While re-drawing it though, it gives you the chance to make updates and add thinjgs like tabs and lightning holes.
Old Dec 21, 2012, 12:39 PM
redC5 is offline
redC5's Avatar
Joined Jul 2010
Thanks for the reply.
Is there a method to "smooth" out lines?? I have been creating another layer and tracing in the new layer and end up with jagged lines on curves. Is there a simple way to smooth them out??
Old Dec 24, 2012, 09:20 AM
RCROBBY is offline
Laser Cutter Guy
Joined Oct 2009
In Acad, you can use polylines and 3 point arcs to make smooth features. Fillets are good for taking the edge off as well.
Old Dec 24, 2012, 05:03 PM
redC5 is offline
redC5's Avatar
Joined Jul 2010
I have figured out how to use the 3 point arcs. I will give the polyline a try.
Julian
Old Dec 24, 2012, 05:53 PM
SRWitt is offline
Joined Jan 2011
Julian
Unfortunately converting from PDF to Cad this is typical. Lots of jagged lines. I import the image as an image and trace everything using a combination of lines, arcs, and splines. I try to fit 3pt arcs where I can, but alot of times a spline is a lot easier to work with.
Old Dec 24, 2012, 07:35 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Merry Christmas, guys.
BTW - what exactly are "splines"?
I hear them referred to quite often, but I'm not exactly sure what is meant by them.
Are they perhaps those squiggly types of line you can click on/add 'nodes' (control-points) to, then push and pull the line to make it contour a complex curve?
BJ
Discussion Vintage & Old-Timer Plans PRE 1977 PLANS ONLY Mooney_Driver Vintage & Old-Timer Designs 669 May 29, 2016 11:41 AM
Discussion Photos of an old home undergoing an effort to save it. Navy Jet Mech Aerial Photography 10 Nov 19, 2012 05:38 AM
Wanted old swash for 450 clone is fine anybody got an old beater swash?? blueindian Aircraft - Electric - Helis (FS/W) 0 Sep 29, 2012 11:29 PM
Question Suggestions for an old timer build using an FS20 or 26. mrcosmo Vintage & Old-Timer Designs 31 Apr 14, 2012 08:45 AM
CG on an old CL/FF plan J Morgan Electric Plane Talk 3 Dec 20, 2002 08:29 PM
