Old Nov 30, 2012, 02:22 PM
grapo is offline
Find More Posts by grapo
grapo's Avatar
Joined Jan 2012
Build Log
F86 Sabre with JetCat P20SX
Hello,
I start build F86. Based on foam F86 from HobbyLobby - wingspan 1400mm
grapo is offline Find More Posts by grapo
Old Nov 30, 2012, 02:52 PM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
A P20 will fly this bird just fine, but I would absolutely mount the turbine much closer to the CG and und a thrust tube from grumania. Installed in the right way a thrust tube might even increase the thrust (amir@hab.se sells test and tune benches for P20SX) In that way you will save 1lb+ on the AUW and keep the thrust :-)
I know me and a friend have been flying these kind of planes with turbine power for a while :-)
henke is offline Find More Posts by henke
Old Dec 01, 2012, 10:12 AM
grapo is offline
grapo's Avatar
Joined Jan 2012
This plane is from foam and build in the exhaust and turbine in CG - very danger for heat :-(
In this case I do like this - the weight of the turbine is cca 300g and I put only the batery forward and that will be fine for right CG.
Today I started my turbine first time - SUPER all was work well
Old Dec 01, 2012, 12:33 PM
henke is offline
henke's Avatar
Joined Jan 2001
P20 Weights 372grams. It's no problem with the heat inside the fuselage. A turbine is not very hot, only the exhausts are :-)
Old Dec 02, 2012, 02:22 PM
grapo is offline
grapo's Avatar
Joined Jan 2012
Hello,
there is a link on first start turbine in plane:
http://www.youtube.com/user/GrapoAirTech
Old Dec 04, 2012, 09:16 AM
grapo is offline
grapo's Avatar
Joined Jan 2012
The last check of fuselage before welding together
Old Dec 04, 2012, 09:17 AM
grapo is offline
grapo's Avatar
Joined Jan 2012
complete plane and view on cocpit
Old Dec 04, 2012, 03:38 PM
Arruda is offline
Find More Posts by Arruda
Joined Sep 2011
Grapo, how did you insulate the turbine from the plane’s walls?
Arruda is offline Find More Posts by Arruda
Old Dec 05, 2012, 05:42 AM
grapo is offline
grapo's Avatar
Joined Jan 2012
Nothing special, the space between the turbine and wall of fuselage is enough for cooling. I add only the aluminium foil on exhaust part - during start there were little bit higher temperature - I have a 5 test runs of turbine and no problem
Old Dec 13, 2012, 12:14 PM
grapo is offline
grapo's Avatar
Joined Jan 2012
Today I finished the marking and stencils on the plane. When will be right weather I start with taxiing
Old Dec 22, 2012, 04:20 AM
grapo is offline
grapo's Avatar
Joined Jan 2012
Finally - maiden flight :
F86 Sabre - JetCat P20SX turbine - Flight (6 min 41 sec)
Sold HK Fiberglass 90mm F86 Sabre RCFEVER Aircraft - Electric - Jets (FS/W) 2 Oct 02, 2012 12:00 PM
Discussion Zo fly F86 sabre tigermoth Foamy EDFs 19 Aug 19, 2012 11:19 AM
Discussion E-Flite BAe hawk, or F86 Sabre F27QFlyer Electric Ducted Fan Jet Talk 32 Jun 16, 2012 07:58 PM
Sold F86 Sabre 35mm EDF Micro Jet EPO (PNF) strangerb43 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Feb 26, 2012 03:43 PM
