Old Dec 16, 2012, 01:36 PM
likidysplit is offline
Find More Posts by likidysplit
Joined Jul 2008
I know Bart10 didnt intend for his Design to be done this way .
But , I hope he likes it ! I am nearly ready to start cutting .
Yes i am very fortunate to be able to use my cnc machine to cut these models out
We will see what the model looks like in person very soon !
If you guys see anything i need to change before i start "PLEASE LET ME KNOW"
as quickly as possible ...
Thank you !
likidysplit is offline Find More Posts by likidysplit
Old Dec 16, 2012, 01:44 PM
Themax222 is offline
Find More Posts by Themax222
Maxime 737NG
Themax222's Avatar
Belgique, Région Wallonne, Rebecq
Joined Dec 2010
Looks Amazing !
One small question/remark : The cockpit is drawed on your plan, Won't the machine follow that line and just cut the cockpit from the fuselage ?
Regards,
Maxime.
Themax222 is offline Find More Posts by Themax222
Old Dec 16, 2012, 01:50 PM
Joined Jul 2008
You are seeing what i wanted you to see . The drawing looks better to the eye when you see the cockpit drawn on the plan .
The cockpit will be cut solid then painted . It will be fine , trust me !
Old Dec 16, 2012, 01:55 PM
Maxime 737NG
Themax222's Avatar
Joined Dec 2010
Great ! Same applies to the wings separated or not from the horizontal fuselage.
Looking forward to your results
Maxime
Old Dec 16, 2012, 02:11 PM
mammuth is offline
Find More Posts by mammuth
WWII combat fan
mammuth's Avatar
Huddersfield
Joined Jul 2008
Don't forget to leave some foam to attach the horns to the ailerons.
Think how you want to strengthen the elevator halves - you might want to leave some foam there as well.
The Rudder - place for the horn might need to be a bit higher so it will not be in the way of the Elevator at any point.
Good luck - get those parts cut and show us some pictures
mammuth is offline Find More Posts by mammuth
Old Dec 16, 2012, 02:21 PM
Joined Jul 2008
Very good catch there mammuth on the ailerons and the rudder horn foam ! THANK YOU
I will make the required changes ..........
Elevator will have a flat carbon joiner so that's not an issue .
Thanks again for your input .
Old Dec 16, 2012, 03:15 PM
Bart10 is offline
Find More Posts by Bart10
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
I think that You can cut it in this way. (I delete some triangulars because You will have to cut places for canalizers).
Don't forget about motor's slope.
I think that You and me are Eon's designers. Not only me or You so I think that this is joint project. After maiden flight I would like to share plans with my and Your name.
Bart10 is offline Find More Posts by Bart10
Old Dec 17, 2012, 11:08 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Why so much side and down thrust
Andycap is offline Find More Posts by Andycap
Old Dec 17, 2012, 12:36 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Because now I'm having an Extra 300 and this model has got similar down thurst but maybe I exaggerated.
Old Dec 17, 2012, 12:41 PM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
We have fully symetrical wings and your motor is on the centre line of wings and tailplane so zero downthrust should be required at this stage of the design
Old Dec 17, 2012, 01:44 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I like the design, but I think that you could mill a little bit more without strength problems.
Free
Free is offline Find More Posts by Free
Old Dec 17, 2012, 03:06 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I agree with andycap. I wouldn't use any downthrust or right angle on the motor. These planes are designed to fly neutral, and should do well with "0" thrust angle.
Minor trim can be done with the radio, and battery placement.
aerolite
aerolite is offline Find More Posts by aerolite
Old Dec 18, 2012, 08:00 PM
Joined Jul 2008
I agree - 0-0 degree thrust on all axis ..........
I just ran a test cut "NO FOAM IN THE MACHINE" to make sure all ran good with no glitches ((didnt want to wast foam if i had something wrong)) .......All is good !
I will put foam in my machine tomorrow after work and cut the Plane !
Thanks for everyone's input !
Old Dec 19, 2012, 07:59 PM
Joined Jul 2008
My machine is running ! Just finished cutting the wing .
Still a ways to go so wish me luck
I must admit though , this first one will be a bit smaller than it was designed for ......
Old Dec 19, 2012, 10:03 PM
Joined Jul 2008
Well , after seeing the parts right here in front of me ..... There are some changes to make to the code ! One thing is i don't like the Brakes at all !
Discussion French F3P-C and F3P-B schedules for 2012-2014 lsky Indoor Pattern/F3P 2 Apr 12, 2012 05:39 AM
Discussion Flightpower Eon vs Eon-X Seahawk82 Batteries and Chargers 89 Jan 14, 2010 06:34 PM
Discussion New F3P servos, Testing! rapghsi Indoor Pattern/F3P 90 Aug 24, 2007 04:45 AM
Eon Olympia? Tominator Scale Sailplanes 2 Dec 20, 2004 02:34 PM
NE Sailplanes EON Blitz SchiessCo Aircraft - Electric - Airplanes (FS/W) 0 Nov 29, 2001 03:09 PM
