Espritmodel.com Heli Air
Old Nov 30, 2012, 09:55 AM
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
Eon F3P- testing
Hello Everyone!
I designed new F3P airplane for contests. Now, I haven't got enough money to test it but maybe anybody has proper equipment and free time? I think that it will fly great.
Wingspan: 96,9 cm,
Lenght: 100,3 cm,
All area: 56,09 dm^2,
Aera of wings and stabilizer: 36,35 dm^2
Weight~130g
Project have been made in Sketchup 8 (free). I can send it or plans.
Best regards,
Bartek
Bart10 is offline Find More Posts by Bart10
Old Nov 30, 2012, 10:09 AM
Bart10's Avatar
Joined Apr 2010
Update.
I increased the horizontal stabilizer's area.
All area: 57,67 dm^2,
Aera of wings and stabilizer: 37,93 dm^2.
As you can see, additional, small wings and generators have the wedge angle that directs the air on stabilizers. Model should be very slow and very, very stable in all positions.
Old Dec 02, 2012, 01:44 PM
Joined Jul 2008
I would like a closer look at your Design .
Send me either the SKP or plan and i will cut on my cnc machine and we will see what this plane looks like for real and not just a 3d interpritation !
Do not send email ..... i dont use that account anymore. PM me and i will give you a current email
likidysplit is offline Find More Posts by likidysplit
Old Dec 03, 2012, 11:03 AM
Bart10's Avatar
Joined Apr 2010
I sent PM.
Old Dec 04, 2012, 02:01 PM
Bart10's Avatar
Joined Apr 2010
Has the work started? Have You cut parts?
Old Dec 04, 2012, 05:35 PM
Joined Jul 2008
Yes ,
I got the email when i got in from work . I already have all the parts from your SKP lay'd out
in a new skp file ... I found you didn't add tab's or slots to your design so im adding them now Also the pie shaped cutout for the elevator was missing , so i put it in .....
I will cut it out on my machine in the next day or so ... Thanks for sending me the file .
Also when im finished with the drawing , I can make you a proper PDF plan if you wish !
or DXF
Old Dec 05, 2012, 08:18 AM
Bart10's Avatar
Joined Apr 2010
Great! I would like the PDF plan, of course. Could You post pictures of the building progress (in future)?
Old Dec 06, 2012, 06:06 PM
Joined Jul 2008
I will !
Old Dec 06, 2012, 07:31 PM
Joined Jul 2008
Here is a screen shot of what the plans will look like.
But i do have a couple questions . Should i seperate the wings from the fuse for you ? It would make for less paper wasted if you only had to print half a wing .
also im confused as to the size and placement on the canalizers , are they
horizontal like the fuse or do they have a slight negative angle at the front ?
I did add some airbrakes just because !
Old Dec 07, 2012, 07:57 AM
Bart10's Avatar
Joined Apr 2010
Don't separate the wings, please. The canalizers should be in the same place as in project (look at red crosses). Angle: 2,3 degrees and -2,3 degrees.
How did You make plans? (what program)
Old Dec 15, 2012, 09:38 AM
Joined Jul 2008
Bart10
you have email !
Old Dec 15, 2012, 10:05 AM
Bart10's Avatar
Joined Apr 2010
I saw it. Thanks a lot. Any progress in building?
Old Dec 15, 2012, 12:16 PM
Joined Jul 2008
Not yet have i cut anything , work got bad last week so i was unabel to work much on the files ......
But on the other hand ! Yes i plan to Pink it out as you say
Here is a sample pic of the wing.
Old Dec 15, 2012, 03:37 PM
Bart10's Avatar
Joined Apr 2010
Really great!
Old Dec 16, 2012, 10:42 AM
Maxime 737NG
Themax222's Avatar
Belgique, Région Wallonne, Rebecq
Joined Dec 2010
Wow ! Great work so far ! Can't wait to see your model printed out Looks promising.
And what a luxury to be able to use a CNC. I just have spend a few days cutting out a plane nicely
Maxime.
Themax222 is offline Find More Posts by Themax222
Discussion French F3P-C and F3P-B schedules for 2012-2014 lsky Indoor Pattern/F3P 2 Apr 12, 2012 05:39 AM
Discussion Flightpower Eon vs Eon-X Seahawk82 Batteries and Chargers 89 Jan 14, 2010 06:34 PM
Discussion New F3P servos, Testing! rapghsi Indoor Pattern/F3P 90 Aug 24, 2007 04:45 AM
Eon Olympia? Tominator Scale Sailplanes 2 Dec 20, 2004 02:34 PM
NE Sailplanes EON Blitz SchiessCo Aircraft - Electric - Airplanes (FS/W) 0 Nov 29, 2001 03:09 PM
