Old Nov 30, 2012, 12:35 AM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
Help!
3 axis FBL heli: Is my servo arm and swash maladjusted?
Hi,
I just changed the pitch servo as well as arm. I powered up the servo and attached the arm so that it was horizontal to the long axis of the servo. I measured the distance between the servo arm and the connecting rod to ensure it was the same as before.
1. With the heli powered up, the swash is tilted forward (1st picture attached)
2. Now the servo arm is horizontal to the ground, but not to the long axis of the servo (2nd picture)
Do I have a problem?
Lentar is offline Find More Posts by Lentar
Old Nov 30, 2012, 06:42 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
Swashplate should be level
Originally Posted by Lentar View Post
Hi,
When I put on a servo I power up the heli and with the gear switch down I put the arm on as parallel to the ground as possible. Then I turn off the power and hold the arm in position while I tighten the screw so as not to strip the gears.
When powered up the swashplate on my Wasp is parallel to the ground, as I would think it should be if the 3 axis gyro is working properly. Don't know if it makes a difference, but are you sure your trim is centered?
Just checked my manual. Look on page 12. The swashplate should be level. You'll probably have to adjust the linkages.
Pa flyer is offline Find More Posts by Pa flyer
Old Nov 30, 2012, 10:11 AM
Lentar is offline
Joined Oct 2012
Is your servo arm parallel to the ground like mine is in the picture, or is it parallel to the long axis of the servo?
Old Nov 30, 2012, 10:21 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
How did you level the servo arm? Did you do it from the transmitter or from the gyro? And how did you set zero pitch on the TX while you were setting it up? Did you just leave the stick in the middle or did you actually set the TX to go to zero pitch?
Hajile is online now Find More Posts by Hajile
Old Nov 30, 2012, 10:27 AM
Lentar is offline
Joined Oct 2012
As you can see in the pictures I put up, my servo is not mounted horizontally. So should I level the arm to be parallel to the long axis of the servo (I have drawn a line and label on the 3rd picture to clarify what I mean by this) or to the ground horizontal (again labelled this)?
Old Nov 30, 2012, 10:36 AM
Lentar is offline
Joined Oct 2012
My transmitter is fully programmable, and I set the manufacturer recommended 5 point values (which are % values) for pitch and throttle. It seems to have zero pitch at throttle mid point. To level the servo arm, I powered up the heli with the transmitter on. I then attached the servo arm to be parallel to the long axis of the servo (see the third picture with labels to see what I mean by the long axis of the servo).
I thank you for your help and interest!
Old Nov 30, 2012, 11:33 AM
Joined Jul 2012
The TX may be programmable but when using a 3 axis gyro, you can't use the trims on the TX to level it.
If you can't access the trims from the gyro, then you can't truly level the servo arms, all you can do mount them as close to the desired angle as you can, and then screw/unscrew the links to level the swashplate. All trims and subtrims on the TX must be zero.
Old Nov 30, 2012, 11:45 AM
Pa flyer is offline
Joined Aug 2012
Parallel to the ground,etc.
Mine is parallel to the ground and just for the heck of it I measured the length of the linkages and compared to the manual's specs. None of them were the same as the manual's specs with the swashplate level. I think the specs are basically just a ballpark guide. Since because of the ribs on the servo post you can't always get a perfectly horizontal arm position when installing it the linkages have to be adjusted to level the swashplate.
Old Nov 30, 2012, 11:47 AM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi from second pic ,the elevator servo looks to be up a few degrees about the
same as swash .the circled servo is very close to level ,.level the elevator servo ,should get rid of a lot ,if not all of forward swash tip swash tip
mdugas is offline Find More Posts by mdugas
Old Nov 30, 2012, 12:30 PM
Lentar is offline
Joined Oct 2012
By elevator servo, do you mean the rear one (to the right in the picture?). It is exactly how it came from the factory. The only change I made was to replace the circled one after the original one got stripped. Does that make any difference?
Old Nov 30, 2012, 12:33 PM
Lentar is offline
Joined Oct 2012
Yes they are. I'll re-adjust the servo arm and see what I get. This servo arm is different from the original, but I used the exact same distance to mount the servo rod.
Old Nov 30, 2012, 02:28 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
The flybarless controller is in control of the servo. So to level the arms you need to either connect the servo direct to a receiver to find center, use a servo driver, or follow the instructions for the flybarless controller.
Since the servo's are mounted on an angle the arm needs to be perpendicular to the main shaft, at the servo's center of travel. If a little off due to the splines, that can be adjusted for on the flybarless controller.
Roto Rob is offline Find More Posts by Roto Rob
Old Nov 30, 2012, 02:35 PM
Lentar is offline
Joined Oct 2012
After adjusting the link rod. Much better but not perfect. So is the swash level enough?
Old Nov 30, 2012, 02:55 PM
Pa flyer is offline
Joined Aug 2012
Try it
Try to hover it and you'll know. I think you'll get a little forward movement in a hover, but there's only one way to find out. You have the training gear so you should be alright. Good luck.
Old Nov 30, 2012, 05:48 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
No its going to fly poorly, at best. The swash needs to be level at Zero pitch.
You really need to follow the instructions for you flybarless controller.
Alert Targethobby is selling FBL 3-axis heli gyro @$59.90 minihawk Hot Online Deals 0 Jun 22, 2012 12:53 AM
Sold SOLD Trex 500 heli parts - swash leveler, fbl pitch tool jabull Aircraft - Electric - Helis (FS/W) 1 Jun 09, 2012 10:18 AM
Sold Trex 600 FBL swash driver arms ScotY Aircraft - Electric - Helis (FS/W) 0 Apr 16, 2012 03:20 PM
Sold SOLD Trex 500 Align FBL swash control arms $17 Tomy. Aircraft - Electric - Helis (FS/W) 3 Jun 22, 2011 05:10 PM
Question Walkera sub-micro 3 axis/FBL reciever in a bigger heli? Bugman Jeff Micro Helis 5 Jan 20, 2011 12:56 PM
