Old Nov 29, 2012, 11:34 PM
prop bender is online now
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
Help!
3 mm rod
Could any one tell me where a good source of 3 mm rod can be found? These Align tail shafts are too short Thanks in advance. Ed
prop bender is online now Find More Posts by prop bender
Old Nov 30, 2012, 08:30 PM
IFHELI is offline
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
I buy 3mm main shafts to make my tail shafts
IFHELI is offline Find More Posts by IFHELI
Old Nov 30, 2012, 11:16 PM
USA, CA, Red Bluff
Joined Dec 2007
Good idia! Thanks. Ed
Old Dec 01, 2012, 02:36 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Ejector pins!
plastixs.com, 3mm ejector pins. Very hard, very smooth, and a closer fit in the tail bearings and tail slider. I have a tail rotor shaft made by Steve (Kauaiguy) from an ejector pin and it seems unbreakable - it's survived four crashes so far!
2Doggs is offline Find More Posts by 2Doggs
Old Dec 01, 2012, 04:19 PM
USA, CA, Red Bluff
Joined Dec 2007
Hey thanks 2doggs, I'll check that out allso. Ed
Old Dec 03, 2012, 03:34 PM
Beachcomber is online now
Find More Posts by Beachcomber
Savannah, Ga, USA
Joined Feb 2009
If you're looking for a 3 mm aluminum shaft, try a fabric store and ask for a 3mm knitting needle. It's tapered on one end, but hopefully it's long enough so you can just cut that off. Can't remember if they are solid or hollow.
Beachcomber is online now Find More Posts by Beachcomber
Old Dec 03, 2012, 03:46 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
Ah, maybe that explains why HK 450 shafts are so soft and bendy..... they're made from knitting needles!
Old Dec 03, 2012, 04:48 PM
USA, CA, Red Bluff
Joined Dec 2007
Yea! And their feathering shafts too
Rant How many 3 MM motor shafts have you ..... Bill Smudge Electric Plane Talk 12 Feb 29, 2012 02:50 PM
Question Who sells 3 mm X 6 mm prop adapters for 3 blade GWS? cyclops2 Electric Plane Talk 5 Dec 13, 2010 09:42 AM
Question RFM Spinner for 3.2 mm shaft on Hacker B20 Motor with only 3.0 mm shaft? AEMontoya High Performance 1 Dec 28, 2009 03:57 PM
Wanted wtb carbon fiber rods 3.5 and 4.5 mm siryan Aircraft - General - Miscellaneous (FS/W) 0 May 15, 2008 11:05 PM
AC prop adapters for 3.0 mm and 3.2 mm shafts Dr Kiwi Power Systems 10 Apr 03, 2004 01:02 AM
