Old Dec 11, 2003, 07:29 PM
Doc Data is offline
Find More Posts by Doc Data
United States, FL, Starke
Joined Apr 2002
Weston Hype 3D
Does anyone know the actual wing area for this plane? They don't list it on the website and RCUniverse has it at 1,520 sq in and I doubt that.
Dave
Doc Data is offline Find More Posts by Doc Data
Old Dec 12, 2003, 06:44 AM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
Hype 3D
Wingspan: 61"
Length: 62"
Weight: 5-6.5 lbs.
Airfoil : Symetrical
Wing area : 1025 sq.in.
Wing loading : 12-15 oz/sq.ft.
Empty weight : 61 oz.
For More info go to www.EspritModel.com
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Dec 12, 2003, 07:12 AM
Doc Data is offline
Joined Apr 2002
Thanks.
You give the weight as 5 -6.5 lbs. Is the the electric setup or slimer setup? The reason I ask is that I have seen other adds, on line and in Fly RC mag where they give the weight as less than 5 lbs.
Dave
Old Dec 12, 2003, 07:15 AM
Palm Bay, FL, USA
Joined May 2001
weight
I do not think so, the plane which has empty weight 61oz. can end up under 5 lbs.
The best thing, just add everything up. radio, battery, motor
Site Sponsor
Old Dec 12, 2003, 07:23 AM
mitchellj is offline
Find More Posts by mitchellj
UK
Joined Oct 2001
Thanks - I have been looking for these figures for motocalc
mitchellj is offline Find More Posts by mitchellj
Old Dec 12, 2003, 07:50 AM
Doc Data is offline
Joined Apr 2002
Adding I can handle. However, you must have accurate numbers for an accurate answer. How did you get the 61 oz for the empty kit? (and, please, do not think I am being nasty here. I'm just trying to make sure). Sometime in 2004 I will by a large 3D gase plane for e-conversion. It will be either the Hype, the U-can-Do 46 or the Flip 3D. I to go with the lowest wing loading.
http://www.modellbau-usa.com/Merchan...ry_Code=PLANES
FLy RC Mag, Feb 2004 issue, Pg 40.
Have you already or can you weigh the actual kit? It would be of tremndous help.
Dave
Old Dec 12, 2003, 01:32 PM
DavidWillis is offline
Find More Posts by DavidWillis
DavidWillis's Avatar
Keighley,West Yorkshire, UK
Joined May 2001
I can tell you what my hype 3d weighs.
6.5lbs
thats with the following
16 sanyo 3300 sub C nimh cells
Jeti advance controller
Mega 45/3e motor
4 x s3003 servos
Multiplex IPD rx
5 cell 700 maH AAA rx pack
carbon undercart
Wheels & spats
14x8 APC-E prop
And boy does it fly...
David
DavidWillis is offline Find More Posts by DavidWillis
Old Dec 12, 2003, 02:36 PM
Doc Data is offline
Joined Apr 2002
David,
Your info helps a lot but I can't find anything on a Mega 45/3. Is that the Jeti 45/3?
Dave
Old Dec 12, 2003, 04:21 PM
AndyMb is offline
Find More Posts by AndyMb
AndyMb's Avatar
Maribor, Slovenia
Joined Oct 2002
Try Mega 22/45/3 or 22/45/3e
It's the same size as Jeti 45/3, but better and capable of 32 cells (geared).
Andrej
AndyMb is offline Find More Posts by AndyMb
Old Dec 12, 2003, 04:33 PM
Doc Data is offline
Joined Apr 2002
I prefer Hackers. I'm just trying to figure out the actual weight. I prefer a plane that does not land like a flying brick!
Dave
Old Dec 12, 2003, 05:02 PM
AndyMb is offline
AndyMb's Avatar
Maribor, Slovenia
Joined Oct 2002
Hm....
I would try a B50-10L 6.7 and 16 cells or lipo.
Andrej
Old Dec 12, 2003, 05:18 PM
Joined May 2001
Sorry - forgot the 22/ bit !
The Hype at this weight DOES NOT land like a brick !
in no wind, it's a brisk walking pace; bit of a breeze, almost vertical. Totally docile.
just measured; ave chord is 18", span 81"
Can out fly me comfortably.
Still learning 3D, but getting their !
David
Old Dec 12, 2003, 06:15 PM
Palm Bay, FL, USA
Joined May 2001
The numbers I used are my own.
I just took the plane from the box and put it on the scale.
Empty weight 61 oz. is correct.
Zb/Esprit
Site Sponsor
Old Aug 15, 2004, 08:41 PM
KatManDEW is offline
Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
It's taken all summer, but I think I've finally worked all the bugs out of my Hype 3D conversion, and today for the first time I was able to fly it without a seperate receiver battery pack. I haven't weighed it fully assembled but I tkink I'm closer to 7 pounds. I started with a Hacker B50-11XL at 5.2:1, but the gearbox huffed twice in six flights and the last time it was replaced with a beefier 6.7:1 gearbox. So my current setup is as follows;
Hacker B50-11XL at 6.7:1
22x10 prop (soon to be 22x12)
6s4p, 8200 mah Thunder Power lipoly
KatManDEW is offline Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
I had to extend the landing gear to run the 22 inch prop with the 6.7:1 gearbox...
Wanted Weston Hype 3d Benph Aircraft - Fuel - Airplanes (FS/W) 0 Oct 09, 2006 02:24 PM
Discussion Weston Mini Hype 3D Goody54321 3D Flying 10 May 23, 2005 12:32 PM
Wanted-weston hype 3d birdseed Aircraft - Electric - Airplanes (FS/W) 0 May 13, 2004 07:41 PM
Weston HYPE 3D maiden flight jmannerberg Sport Planes 10 Sep 22, 2002 02:09 AM
