Old Nov 29, 2012, 08:13 PM
TOWHOOK is offline
Find More Posts by TOWHOOK
TOWHOOK's Avatar
Tennessee
Question
Styrene hull to Fiberglass hull
I am getting ready to build a model of a British police boat and I have a styrene hull that I would like to use as a plug to make a fiberglass mould. What the best way to go about doing this? At this point, the hull is just unpainted white styrene (or plasti-card) that has been vac-formed.
TOWHOOK is offline Find More Posts by TOWHOOK
Old Nov 29, 2012, 08:43 PM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
I'm pritty sure that the poly resin will destroy the hull you have, maybe epoxy would be better, a little pricy though.
P31 is offline Find More Posts by P31
Old Nov 29, 2012, 09:40 PM
dostacos is offline
Find More Posts by dostacos
some what irregular
dostacos's Avatar
Diamond Bar, California
Joined Feb 2004
cover the hull with a separator of some type {like a very thin coat of Vaseline} then use plaster bandage {hobby shops have rolls kind of the stuff} soak and wring out most of the water and NEATLY lay on the hull. when it has set, pop the two apart put the plaster wrap in sand so it will not change shape, Vaseline the inside again then fill with 20 minute casting plaster {hobby shops and craft stores also carry this} the mold can be worked while it is still moist. the final smoothing can be done with a wet cloth and polish really smooth. I would then let the mold dry when ready more Vaseline and lay your fiberglass. when set, unless you have some serious under cutting it should come off
dostacos is offline Find More Posts by dostacos
Old Nov 29, 2012, 10:41 PM
P31 is offline
P31
P31
Joined Dec 2011
Yep, thats it.
Old Nov 30, 2012, 12:47 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I've always wondered how to do that, but never tried anything.
Guess I'll just sit back and watch what develops---.
der kapitan is offline Find More Posts by der kapitan
Old Nov 30, 2012, 07:29 PM
TOWHOOK is offline
TOWHOOK's Avatar
Tennessee
Well Kap, what I was thinking, was give it a couple of coats of gloss paint, spray it with pva and then do a gel coat layer followed by a few layers of mat fabric or chopped mat. who knows? wait and see I guess.
Old Nov 30, 2012, 07:32 PM
TOWHOOK is offline
TOWHOOK's Avatar
Tennessee
Yeah, I have heard that polyester resin will eat styrene for breakfast also. Epoxy was the direction I was leaning in.
Old Nov 30, 2012, 08:14 PM
Joined Jun 2005
I'd go using your idea, Towhook. If you seal off the plastic well enough, polyester will do it for a mold. No need to use epoxy---.
Old Nov 30, 2012, 11:43 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
If you use too much resin, you may get the hull too hot. Make sure it is shored up so it doesn't move.
D
CaptDH is offline Find More Posts by CaptDH
Old Dec 01, 2012, 03:33 AM
nhp651 is offline
Find More Posts by nhp651
Near Fleetwood, lancashire, UK
Joined Jun 2009
D
it's not the resin that goes hot........it's the chemical reaction between the resin and the catylist.......and even using a low percentage of catylist to resin to make a slower reaction time, you will still get heat, and no amount of "barrier cream" or other barrier agent will stop a reaction between styrene and resin if it wants to get through..............DO YOU WANT TO TAKE THAT CHANCE even if only 25% when other methods can be used........I know I wouldn't.
nhp651 is offline Find More Posts by nhp651
Old Dec 01, 2012, 06:59 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
You ruined a good one of these :-
Followed with one of these :-
And a lot of these :-
And definately loads of these :- Neil.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Dec 01, 2012, 07:18 AM
Joined Jun 2005
A lot of negatives coming in from all sides---.
Have any of you "experts" actually worked with fiberglass?
Or are you casting about theories---?
Old Dec 01, 2012, 07:57 AM
Circlip is offline
Joined Apr 2010
You really need to see the Tee shirt, watch the Video etc. ??
I can vouch for two replies.
Regards Ian.
Old Dec 01, 2012, 08:56 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
I would use Dostacos way FIRST. That way there in not a big outlay of cash and the original will still be around to try a differnet way if you so desire.
Heat is a major factor with the polyester way.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Dec 01, 2012, 09:31 AM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Epoxy does not stick to styrene very well. An example is after mixing and using epoxy in a styrene cup (not foam plastic) let the remainder set up in the cup. After dry you can just pop it out and the cup is ready for another batch. Poly resin will eat foam plastic such as used by the r/c aircraft guys. Epoxy won't. Do use a barrier such as vasiline or a wax to make removal easier.
charlie eaton is offline Find More Posts by charlie eaton
New Product 1/24 Truckable Towboat hull in fiberglass CaptCB Scale Boats 475 May 01, 2015 12:21 AM
Sold Dumas Fiberglass Hull Tug pmisuinas Boats (FS/W) 9 Apr 06, 2012 03:41 AM
Question 1/24 Truckable Towboat hull in fiberglass CaptCB Micro and Sub-Micro Boats 3 Apr 01, 2012 12:11 AM
For Sale 1/144 Admiral Scheer/Graf Spee fiberglass hull FightingSteel1 Boats (FS/W) 2 Mar 28, 2012 01:58 PM
Help! want to fiberglass a styrene hull givemeprops09 Dock Talk 14 Sep 14, 2010 11:33 PM
