Dec 03, 2012, 10:54 AM
United States, CA, El Cajon
Joined Mar 2012
dude, the name you made this thread is 'rudder issue', and you talked about you rudder. And in a sense, relatively, the rudder does move side to side.
But still then, are you getting cyclic control on the ground but not in the air. On the ground do you have aileron control on both sides? If so, but it doesn't work in the air, it could even be that the servo seems to work until a load is put on it. Maybe a weak servo motor. Does the servo smell burnt? I have some 9g servos i used for a rudder until each one got looser and looser (holding the tail), and eventually gave out, they still seem to work fine on the bench but wouldn't hold in flight. They smelled burnt too.
