Thanks Dragan.
I've just started using this online plotter, it's not a totally comprehensive list of airfoils but it has some good ones and seems to print out quite accurately on my printer. I printed on to tracing paper and then used french curves to transfer (and cut) the rib shapes. Not the most accurate method ever but good enough for something like this. |
Nice Beancraft
![]() This one is still in build but it will be for indoor. Over here there is a regular competition at Impington and a new one at the BMFA Indoor Scale Nats in Nottingham in April. They are built to the 14g minimum so I'm aiming for 12 or 13g plus a bit of nose weight. Quote:
) which gives you an idea of the size. Stretch winding is the key but it does land with quite a few turns still on (If it doesn't hit the wall! )
USA, IL, Wheaton
Joined Oct 2010
Yak
Thanks for the info. Looks like Impington is roughly 30 feet high. Your Cub was flying well untill the wall flew into it. The 14 gram minimum makes a decently robust plane, probably closer to the original intent of the event. Over here, most winning indoor Bostonians are closer to the 9 gram AMA minimum. The winner at the Racine meet was Anton Telford, with an average of 88 seconds for the 2 best flights. A photo of his plane was posted on the Eagles' web site. It seems smaller than mine, with a smaller tail. Otherwise, Tony's workmanship and experience counts a lot. Nobody was flying the flat style Bostonians that day. I've seen a 2 minute flight at the Racine site. http://kenanne.50megs.com/BongEagles...s/Slide027.htm Keep 'Em Flying Joe |
USA, IL, Wheaton
Joined Oct 2010
Your Bostonian is looking good. What sort of motor are you planning? I'm assuming it's a 6 inch prop, so maybe a long loop of 3/32 would work.
I've posted a thread on the Comet Phantom Fury I've built with a similar airfoil. Ribs are shown below. It needs a bit rearward CG, but some of that might be from the tail volume, which I need to calculate. I added a top spar but don't have your front turbulator. It's much bigger than my Bostonian, and i've gotten a good climb but I need to improve the glide. http://www.rcgroups.com/forums/showp...21&postcount=1 |
| Thread Tools | |
| Poll Do you think a chief designer of RC planes can design and build real plane? | jcervantes11 | Chit Chat | 16 | Jul 02, 2012 08:52 PM |
| Gallery Record heat in March for Boston area CIty and water shots | sweatyfingers | Aerial Photography | 7 | Apr 01, 2012 03:28 PM |
| Discussion Walt Mooney Boston Revere Speedster build | scigs30 | Free Flight | 9 | Apr 12, 2010 10:32 PM |
| Question Easy build, Easy fly Blu Beagle replacement? | nikg | Foamies (Scratchbuilt) | 2 | Aug 14, 2009 09:20 PM |
