Espritmodel.com Heli Air
Old Nov 29, 2012, 01:06 PM
Joined Oct 2012
Anyone do CAD drawings for others?
I need to find someone who can turn several of my drawings into CAD drawings.
Preferably in the Houston area with TurboCad.
Thanks.
bayou_city_boy is offline Find More Posts by bayou_city_boy
Old Nov 29, 2012, 02:55 PM
Denver, CO
Joined Dec 2005
Might help if we know, if this is a simple drawing of a part, or something complicated.
Roto Rob is offline Find More Posts by Roto Rob
Old Nov 29, 2012, 03:42 PM
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
2s, 3d?
It takes me 20 to 30 hours to reproduce a pdf airplane plan.
Is this for the hobby or for profit?
rick.benjamin is offline Find More Posts by rick.benjamin
Old Nov 29, 2012, 06:30 PM
Joined Oct 2012
I have hand drawn plans that I would like to convert to CAD. I am trying to design a couple of easy to build control line airplanes to teach Boy Scouts how to scratch build.
just need 2D plans.
They are 18" wingspan using Cox .049 engines. Mostly 1/8" balsa sides with carved 1/4" balsa tops and bottoms.
Will print out on 11x17 paper with wings split in half.
I am thinking about using the solid balsa 1/8" airfoil sheets for the wings for strength. No wing to build. Just glue to pieces together top and bottom for a symmetrical airfoil.
I would like to get brought up to speed on TurboCad if anyone in Houston is using it. I used Cadvance and AutoCad in the past to design x-ray rooms but it's been a while.
Don
Old Nov 30, 2012, 01:10 PM
Joined Oct 2012
Also I don't mind paying for help as long as the cost is reasonable.
Old Nov 30, 2012, 02:28 PM
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Can you scan your hand drawn drawings and attach them to a post ?
And what sort of time scale are you thinking about ?
Fubar 123 is offline Find More Posts by Fubar 123
Old Nov 30, 2012, 11:08 PM
Denver, CO
Joined Dec 2005
I'd be willing to do one of them. I have more free time in the winter.
Old Nov 30, 2012, 11:22 PM
Joined Oct 2012
Rough draft
This is my first draft. The final draft will be cleaner. Wingspan is 18" and length is 16".
The wing airfoil shown is an idea of a high lift wing with high drag to keep the speed down. I'm thinking the thinner solid wing would allow the plane to fly too fast for beginners.
I will be experimenting with 2 solid 1/4" balsa airfoil planks glued bottom to bottom with and extra 1/8" sheet between them to thicken the wing up. But that means a lot more sanding and weight.
Everything but the wing is 1/8" balsa for strength. I want to use laminated 1/8" sheet for the upper and lower forward fuselage for strength.
If I go with the built up wing it will be 1/16" ribs, 1/8" upper and lower spars and 1/16" leading edge sheeting with 1/16" trailing edge.
The engine will be basic Cox .049 with a back plate mount and 1 oz fuel tank. I am thinking a TD will be too fast for beginners.
I am open to suggestions to improve the design also but don't make fun of the old drafting rule and velum paper! That's what us ole' schooler's cut our teeth on and what they used to designed the space shuttle with!
Old Dec 01, 2012, 12:22 AM
Joined Jan 2011
Hey they still teach on velum, even though CAD is whats prevalent. You learn a lot of neat techniques that translate into using software, its just easier with software. I was actually looking for all of my drafting tools from when I was in school today, was saddened when I couldn't find them. I'm gonna have to pick up a few basic things (compass, rule, french curve, various triangles) its fun sometimes to just draw something. I think my favorite was doing perspective drawings in school. Tough to pull off right, now with 3d modeling its as simple as a couple clicks.
SRWitt is offline Find More Posts by SRWitt
Old Dec 01, 2012, 12:30 AM
Joined Oct 2012
Loved perspectives. Even took some art classes to help! I have done a lot of CAD dwgs in the past but it just isn't the same as with good ole' lead!
Old Dec 08, 2012, 03:10 AM
MB326 Dino Driver
Macchi326Driver's Avatar
Newcastle, NSW Australia
Joined Dec 2006
Pilot Plans?
G'day,
Just found this thread and thought I would jump in ,.. I was wondfering if anyone would be interested in doing some Pilot plans?,.. I don't have the skills, for CAD, nor a CAD program,.. but if anyone is interested in putting some old Pilot kits into CAD I could either post up, or send some plans, they are in PDF format,.. I am not looking at selling them,.just wanting to relive my old days and get some pilot kits going, and more so,.. share some good plans,..
Jeremy
Macchi326Driver is offline Find More Posts by Macchi326Driver
Old Dec 08, 2012, 04:41 AM
Denver, CO
Joined Dec 2005
How complicated are they. I don't have much time, but could probably do some.
Old Dec 09, 2012, 10:18 PM
Joined Dec 2012
I use 3d modeling software for a living. I would be willing to produce 2d drawings as well as any any custom parts you might need. I have done a lot of motor mounts and custom tools on an FDM machine I have access to. So I'd be willing to help out anyway I can just pm me and we can work something out.
Pipercubohio is offline Find More Posts by Pipercubohio
Old Dec 18, 2012, 12:07 PM
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
I've been doing AutoCad for 20 years and have found, almost without fail, most people unfamiliar to the skill are stunned at the ultimate cost to produce a fairly average complexity drawing. A drawing that takes 3 hours can justifiably range in price from $50 to $300, depending on how hungry the individual is doing the work.
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old Dec 19, 2012, 12:26 PM
Living to Build'em and Fly'em.
Mr.GFC's Avatar
Joined Jul 2011
And then there are those (myself included) that know just enough about AUTOCAD that enjoy doing it when it concerns RC Aircraft, to do it for free.
I've been converting all of my blueprints to CAD, including the laser cutting layouts, so that they are easy to get into.
All of the ribs are correct, because I design the wings in Compufoil3d, so that the jig holes, lighting holes and such are always dead on.
Mr.GFC is offline Find More Posts by Mr.GFC
Question REquest for CAD drawing of eFlight 25 motor rcav8r2 CAD/CAM 3 Nov 07, 2012 08:34 AM
Anyone got a cad drawing of a GWS IPS motor? Ben_E Indoor and Micro Models 3 Sep 18, 2004 03:09 AM
Anyone got a cad drawing of a GWS IPS motor? Ben_E Parkflyers 0 Sep 17, 2004 06:06 PM
Anyone have CAD drawing of GWS IPS drives? Steve McBride The Builders Workshop 1 Oct 08, 2002 11:20 AM
CAD drawing or some other for the eLMH? Tom Viper Electric Heli Talk 3 Nov 25, 2001 05:25 PM
