Old Jan 30, 2013, 10:11 PM
bluffman is online now
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Point fermin Rubio
bluffman is online now Find More Posts by bluffman
Old Jan 30, 2013, 11:29 PM
TRISME is offline
Find More Posts by TRISME
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Originally Posted by bluffman View Post
So Tom you have flown it twice, where is the video
http://www.rcgroups.com/forums/showt...7#post23986800
Very short vid.
Tom
TRISME is offline Find More Posts by TRISME
Old Jan 31, 2013, 11:48 AM
Tick Point is offline
Find More Posts by Tick Point
Tick Point's Avatar
Joined Mar 2008
1/32" Ply bagging help needed
How-do, rednecks?
I'm baggin' a zephyr wing for slopemeno and ain't never used no ply.
At the TE, do I bevel the ply a little, a lot, or none at all?
How much ply should meet behind the foam core? 1/4in? 1/8?
Am I expected to sand both upper n lower surfaces to a thin TE AFTER it comes out of the bag to return it to the airfoil shape?
Cloth TE's aren't as thick and don't give me this issue.
After bagging the ply, I will make a Poplar LE and bag it again with 4oz cloth, veil.
Oh, I'll also include a peel-ply hinge to score down to.
Do I need to use mylar over the ply bagging phase? wouldn't hurt I reckon.
Any advice on this here new endeavor?
Dave-Bob
Tick Point is offline Find More Posts by Tick Point
Old Jan 31, 2013, 12:14 PM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Let the top skin hang past the edge of the bottom skin about 1/4" at the TE. The bottom skin should extend a little past the edge of the foam and then the top skin extends a little past that. That way you don't have both skins stopping right at the TE, giving you a 1/16" thick TE. Hope that makes sense. You can then block sand it to a nice thin edge before bagging the glass over it.
One thing though - doing it this way will make your ailerons pretty heavy and heavy ailerons are more prone to flutter. The nice thing is you don't have to do so much shaping, but balsa ailerons will be a lot lighter.
slopeiron is offline Find More Posts by slopeiron
Old Jan 31, 2013, 12:45 PM
Tick Point's Avatar
Joined Mar 2008
Excellent info Slopeiron.
With the offset ply at the TE, I think the mylar might get in the way, so I shouldn't use the molars for the first bagging, right?
I imagine a strip of blue tape could hold the off set in place (add slits to it to help bleed out excess resin).
I haven't made balsa ailerons yet. I'll need to experiment some before I use it on this core.
Any significant difference between Poplar and Bass? Poplar's easy to get and is considered a "hard wood".
Old Jan 31, 2013, 01:28 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Like Russ said, Ply ailerons are very prone to flutter so make sure you have beefy linkages with as little slop as possible. Bass wood is more flexible than Poplar and less prone to snapping. But Poplar is a good second choice if you can't get Basswood.
TFLG is offline Find More Posts by TFLG
Old Jan 31, 2013, 02:12 PM
Tick Point's Avatar
Joined Mar 2008
I shutter to flutter
I don't want this one to flutter by.
Are you suggesting a glassed wing but a wood aileron? More steps for painting...less redneck! Hmmmm.
More than one way to skin a zephyr!
It's like a 5 hour drive to the zephyr build for me (and I'm not hitch hiking).
Feel free to refer me to a build log that does a ply wing.
Since I can bag glass, what's plywood gonna do better?
Old Jan 31, 2013, 02:27 PM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
The ply will make it a lot tougher. A glass over foam wing will shatter easily. You might consider going with 1/64" ply instead of 1/32". It will be a lot lighter and still plenty strong. Also, you don't need to use mylars when you are bagging the ply skins on. You only need the mylar to give the glass a nice surface.
If you wanted to go with balsa ailerons, you could cut the TE of the cores off and then bag the ply skins onto what is left of the wing. After the skins are on, tack on some balsa aileron stock on and shape it to match your airfoil. Then bag glass over the whole thing afterward. Then cut the ailerons off and hinge them.
Old Jan 31, 2013, 02:29 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Like this
http://www.rcgroups.com/forums/showp...&postcount=224
Old Feb 02, 2013, 09:43 PM
67econoline is offline
Find More Posts by 67econoline
Nothing to see here...
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
My wing fillet is ready.
I could fuss over it forever. So tonight I am going to give a final sand. The clean her up and glue the elevators /ailerons on. The tomorrow Solartex and Monday primer
Rubio Ray
67econoline is offline Find More Posts by 67econoline
Old Feb 02, 2013, 09:49 PM
Joined May 2011
Description:
Find the mistakes Fella's soon there will be no turning back...
Or at least it will be tougher ...
Rubio Ray
Old Feb 02, 2013, 09:56 PM
Twyl is offline
Find More Posts by Twyl
Silent Flight
Twyl's Avatar
United States, CA, Cypress
Joined Jul 2005
Looks good to me Rubio!
Nice work
-Jonathan
Twyl is offline Find More Posts by Twyl
Dick J is online now
Find More Posts by Dick J
Dick J's Avatar
United States, CA, Lake Forest
Joined Jun 2008
Looks great Rubio ! very nice work Going to be pink ?? he he just kidding ! ???
Dick J is online now Find More Posts by Dick J
Old Feb 02, 2013, 10:00 PM
Joined May 2011
WOW !!!
You guys are FAST..!!
Description: Name: ImageUploadedByTapatalk1359864032.689295.jpg
Description:
Rubio Ray
Old Feb 02, 2013, 10:05 PM
Dick J's Avatar
Joined Jun 2008
That Zepher is one sexy plane Plan out your paint really well my friend !
Discussion GoPro 3 on the Zephry jeffscholl Aerial Photography 3 Nov 25, 2012 07:26 PM
Wanted maxi swift or zephry fpvme Aircraft - Electric - Airplanes (FS/W) 2 Sep 26, 2010 10:37 PM
Redneck vasectomy... a true story! Sparky Paul Life, The Universe, and Politics 2 Feb 20, 2002 09:27 PM
Cool Irish and redneck... Don Sims Humor 0 Jan 02, 2002 07:15 PM
