Old Jan 09, 2013, 09:51 PM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Tom excellent job
bluffman is offline Find More Posts by bluffman
Old Jan 09, 2013, 10:03 PM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Looks great Tom!
slopeiron is offline Find More Posts by slopeiron
Old Jan 09, 2013, 10:17 PM
TRISME is offline
Find More Posts by TRISME
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Originally Posted by dutchydawg1 View Post
nice looking linkage Rubio, but what are the brass tubes for ?
(No comment here 'cause I did the same thing)
TRISME is offline Find More Posts by TRISME
Old Jan 09, 2013, 10:19 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Looks good, Now paint the front bit of the canopy black!
TFLG is offline Find More Posts by TFLG
Old Jan 09, 2013, 10:20 PM
67econoline is offline
Find More Posts by 67econoline
Nothing to see here...
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
Don't I need the brass to hold it all in place till the elevators all glued up??
I have not built this type of tail before.
I am muddling through.
I will admit the tail part scares me.
But I don't think I used it on the cobra. But it was all one pice by the time it went on.
I saw Toms and he had a brass tube.
Description:
So I followed.
I had tough time soldering it till I used a torch
I need to get one of those small ones for jobs like that.
What should I do Dutchy??
67econoline is offline Find More Posts by 67econoline
Old Jan 09, 2013, 10:23 PM
Joined May 2011
I could grind it off...
Rubio Ray
Old Jan 09, 2013, 10:28 PM
TRISME is offline
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Thanks guys. The checkers actually came out a lot better than I thought. I had some bleed through spots though. Do I dare try to clean them with solvent, or scrape it, or just make friends with them? Trim tape? I was thinking of a 1/8" silver stripe behind the spinner, and a bigger one around the canopy to make it look like a frame. Under the L/E of the stab is smudged, maybe a 3/8"silver stripe tapering to nothing at the wing fillet? Suggestions welcome.
Tom
Old Jan 09, 2013, 10:30 PM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Tip top Tom. That paint scheme looks fast just sitting there.
rockbus is offline Find More Posts by rockbus
Old Jan 09, 2013, 10:34 PM
TRISME is offline
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Attachment 5436304
So I followed.
I actually unbent my elevator linkage after it was soldered up and added those brass tubes. then re-bent the angles to fit in my already hinged and drilled elevator halves. (full disclosure, since I'm fessing up here!) DOH!
Sorry to lead you astray Rubio.
Old Jan 09, 2013, 10:36 PM
Dick J is offline
Find More Posts by Dick J
Dick J's Avatar
United States, CA, Lake Forest
Joined Jun 2008
Nice job Tom looking good !!!!
Dick J is offline Find More Posts by Dick J
Old Jan 09, 2013, 10:38 PM
dutchydawg1 is offline
Find More Posts by dutchydawg1
dutchydawg1's Avatar
Nor. Cal.
Joined Jan 2004
just go with whatever works.
dutchydawg1 is offline Find More Posts by dutchydawg1
Old Jan 09, 2013, 10:39 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Rubio, Leave the brass tubes. But you don't really need them on future builds on these little planes.
Tom, make friends with you runs unless they are really bad. Trim tape might look ok, but it has a nasty habit of pealing off unless you clear coat over it.
Old Jan 09, 2013, 10:41 PM
TRISME is offline
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
from about the high point of the canopy forward, 1 1/2" or so?
Old Jan 09, 2013, 10:47 PM
Joined May 2011
Thank You Brian,
I thought they were used to hold it in place till the elevators were on.
Live and learn
Rubio Ray
Old Jan 09, 2013, 10:50 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Whatever looks good to your eye. My clear canopy is about 3" long.
Discussion GoPro 3 on the Zephry jeffscholl Aerial Photography 3 Nov 25, 2012 07:26 PM
Wanted maxi swift or zephry fpvme Aircraft - Electric - Airplanes (FS/W) 2 Sep 26, 2010 10:37 PM
Redneck vasectomy... a true story! Sparky Paul Life, The Universe, and Politics 2 Feb 20, 2002 09:27 PM
Cool Irish and redneck... Don Sims Humor 0 Jan 02, 2002 07:15 PM
