Old Nov 29, 2012, 12:03 PM
tbroeski is offline
Find More Posts by tbroeski
Afton VA
Joined Sep 2002
Build Log
Molded wing repair with urethane foam
I've seen a lot of guys give up or do a crappy job on hollow wing repairs. It's really not that difficult with the right stuff.
Materials:
Dixi cup
mixing stick
Sandpaper
plastic (old bottle will do)
Two part Urethane (not the squirt foam)
Tape
Catalog or Phone book (only for large holes)
CA
Sucker (big type)
White putty
Paint (some auto paint stores will scan your wing for a perfect match and put in regular spray can)
Picture is of tree impaled wing tip. All the way to spar, but no structural damage.
tbroeski is offline Find More Posts by tbroeski
Old Nov 29, 2012, 12:07 PM
tbroeski is offline
Afton VA
Joined Sep 2002
CA parts
CA in what parts you can. This was a fairly hard hit, but I managed to find a couple pieces.
Old Nov 29, 2012, 12:16 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Bend Plastic
Bend some plastic or mylar to match the airfoil.
I sometimes use an undamaged wing to bend it with a little heat. Not too much heat or you can damage the other tip.
NOTE: be sure to wax or use mold release. You can also use the silcone release paper from your covering. I used to throw a lot away, but now I keep it.
Remember, the leading edge is not necessarily sharp, so don't just fold it.
Old Nov 29, 2012, 12:21 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Sucker
Sometimes if I have to get up into the middle of a wing, I use a flavor injector. With the foam, you have to drop it in a jar of lacquer thinner immediately after use. This one has made it through a number of repairs and is still like new.
The other tool I use is a Sucker. The larger holed ones work great. For the narrow repair I used it, but for the larger hole, I just poured the foam in.
Old Nov 29, 2012, 12:27 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Mix the foam
Once you have everything ready, you can mix the foam. Equal amounts of A and B.
NOTE: It is better to use too little than too much. A tiny bit goes a long way.
I opted to do one hole at a time, since you only have a minute or so to work.
I did a quick mix (a couple of seconds) and sucked it up into the tube. It will start coming out right away, so work fast.
Old Nov 29, 2012, 12:32 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Cover with plastic
Once you have the foam in, tightly attach the plastic. For the first hole, I just taped it.
On the second hole, I used a catalog the help secure it. Again, be sure it is waxed (on the inside). You can do a simple test. If masking tape won't stick to it, it is okay.
Old Nov 29, 2012, 12:44 PM
tbroeski is offline
Afton VA
Joined Sep 2002
A little white putty
After it sets, remove plastic. I usually wait about 30 min, but it only takes about 10. The main thing is to not take off the plastic too soon, or it will pull off some of the foam. If done right, you have an almost perfect surface.
A little white putty and block sanding and it's almost done.
Old Nov 29, 2012, 12:56 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Prime
I primed, sanded, primed, both top and bottom. I didn't have any gloss black, so have to wait for the final picture of the whole job. Needs a tiny bit more sanding on the leading edge.
Weight (with servos) before repair, 7.5 oz
After repair, 7.7 oz (could probably have used a bit less putty if I had waited a little longer for the foam to set on the big repair. Could also have used some lightweight filler before using the white putty.) Two tenths of a ounce isn't too bad for such a large repair.
I have the foam kit for sale here:
http://www.rcgroups.com/forums/showt...5#post23524420
Believe me, a little goes a Long way.
Old Nov 29, 2012, 10:48 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Just a cosmetic patch? Fibers still broken and therefore structural integrity compromised?
jkettu is offline Find More Posts by jkettu
Old Nov 30, 2012, 06:31 AM
tbroeski is offline
Afton VA
Joined Sep 2002
Not much "structure" in front of the spar. You want the airfoil shape to match. Since it is solid foam, it has as much structure as you would need.
Old Dec 03, 2012, 07:51 AM
tbroeski is offline
Afton VA
Joined Sep 2002
It is also great for those leading edge dings. If done right, it has a hard smooth surface.
Old Dec 06, 2012, 07:24 AM
tbroeski is offline
Afton VA
Joined Sep 2002
The foam needs to be contained to have much structure. Coming out of a dixie cup actually gave it structure. Here's a video of the stress test after 20 or more hits (trying to make a video). I've burned it, spray painted it and hammered it.
I will stress again to make sure there is a place for the foam to go. Inside a hollow wing is fine, but if you put it between ribs or something, it will need a release hole, or lot of weight and a good form.
hamer foam (0 min 11 sec)
Old Dec 06, 2012, 04:23 PM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
burned It? it IS highly toxic???? YOU OBLIVIOUS NEED A BIGGER HAMMER, come on.... SWING
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Dec 06, 2012, 05:06 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
If brute force doesn't work, you're not using enough.
Wazmo is online now Find More Posts by Wazmo
Old Dec 06, 2012, 05:33 PM
tbroeski is offline
Afton VA
Joined Sep 2002
Don't eat it, smoke it or sleep with it.....
For Sale Urethane Foam -- Repair Kit, Etc. tbroeski Aircraft - General - Miscellaneous (FS/W) 5 Jan 24, 2013 03:11 PM
Sold Urethane Foam -- Wing Repair Kit tbroeski Aircraft - Sailplanes (FS/W) 20 Dec 06, 2012 12:25 PM
Discussion Molding foam: Thermaforming vs. liquid urethane spencer6891 Foamies (Scratchbuilt) 7 Jun 28, 2012 05:29 PM
Discussion Anyone play with this Liquid Urethane Expanding Pour Foam videorov Composites Fabrication 1 Mar 31, 2012 02:15 AM
Discussion How to repair dents on solid core molded wings GaryO Hand Launch 5 Mar 20, 2012 09:15 PM
