Old Dec 01, 2012, 07:34 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Joshua,
Thank you very much! Your Smoothie is gorgeous!
I should receive mine next week, so you may well get deluged with questions, sir!
Ah Clem is offline Find More Posts by Ah Clem
Old Dec 01, 2012, 07:46 PM
N99JH is online now
Find More Posts by N99JH
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
No problem AH. You are more than welcome to ask anything you want and I will do my best to help.
Best Regards
Joshua
N99JH is online now Find More Posts by N99JH
LA Ming is offline
Find More Posts by LA Ming
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
Oh my, that Brodak is indeed a GORGEOUS Smoothie!!!
This thing has GOT to go on my "want" list.
Andre
LA Ming is offline Find More Posts by LA Ming
Old Dec 01, 2012, 07:58 PM
The Kiwi is offline
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
OS Max 40s
One of my all time favorite 40s is the old Max-H model that was available at the same time as the Max-S 35 (early 70s to early 80s). I still have a couple of them today. I also have a couple of different kinds of OS FP 40s, one in the older style iron piston, steel cylinder, and at least one from the aluminum piston, nickel plated brass cylinder period.
I do not have an LA-40. That one was supposed to work pretty well for stunt and sport. My Max FP 40s needed some really old-fashioned fuel to run nicely on any sport or stunt type model (a lot of oil, and half of it castor = 12 - 12 - 10 - 66).
The Kiwi is offline Find More Posts by The Kiwi
Old Dec 09, 2012, 03:59 PM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
All of the parts have shown up for the Smoothie (lines, handle, spinner, etc.).
I went out and purchased some GMA Fuel to test the O.S. .40 (just ran it three times-looks like it was hardly ever run and starts beautifully!).
Now I just need to get some time to assemble the airplane...
I would like to have it ready by this Friday, if possible.
Time is the only issue!
Old Dec 11, 2012, 11:15 AM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
The Smoothie is partially built.
The elevators and flaps are attached.
The motor mount has been drilled and the motor test fit.
The landing gear mount, which several people I trust have told me is somewhat weak, has been fiber glassed from the inside (to try to stand up to my bouncy landings).
The wing and tail are still not attached to the fuselage.
I am hoping to have it ready by Friday, but I do not know if time will permit.
Old Dec 11, 2012, 06:52 PM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
Don't rush-weather forcast is not good for So Ca late this week. I really want to see your new plane.
tigreflyer is offline Find More Posts by tigreflyer
Old Dec 11, 2012, 07:59 PM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
Just trying to get it completed. I have to work a bit at a time, due to other things.
I finished the landing gear today, and painting the inside of the engine and fuel tank compartment with heated (thinned) epoxy.
Also installed a fine scale pilot (yellow rubber duck with dredlocks).
Started trimming the covering from the areas of the fuselage where the wing will seat (so as to be gluing wood to wood).
Test installed the pushrod from the bellcrank to the flap horn.
Will be test fitting the tail tomorrow and adjusting the elevator clevis.
Not too much to do, at this point.
Also received an assembled RingMaster Jr. from Ebay in the mail, but have not had a chance to open it yet.
Old Dec 12, 2012, 08:26 PM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
The wing is on.
The tail is on.
The motor is in.
I need to get some polyurethane to seal the Monokote Trim so it does not peel off (as an old friend I met again at Whittier advised me to do).
Old Dec 13, 2012, 05:08 AM
N99JH is online now
N99JH's Avatar
Hartsville, SC
Joined Apr 2006
Originally Posted by Ah Clem View Post
The wing is on.
The tail is on.
The motor is in.
I would suggest that you use Luster Kote made by Great Planes to seal the trim. It is made just for that and available from yourLHS in a spray can.
Old Dec 13, 2012, 05:13 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I think he want to paint a little bit along the edges of the trim to seal them?
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 13, 2012, 09:47 AM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
"I think he want to paint a little bit along the edges of the trim to seal them? "
That is exactly it, sir!
Old Dec 13, 2012, 09:53 AM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
The wing fillets fit well.
The tail fillets did not come close to fitting.
Anyone else have this issue?
Old Dec 13, 2012, 03:57 PM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
The Smoothie is finished!
(except for the tail fillets).
The control handle is wooden, so I stained it to seal it.
Engine has been test run in the plane.
Lines are set up.
Depending on weather and work, it should fly tomorrow.
Old Dec 14, 2012, 11:42 AM
LA Ming is offline
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
Best of luck on your maiden flight!
Sold Brodak Baby Flite Streak nib Mendo Aircraft - Fuel - Airplanes (FS/W) 4 Jul 08, 2012 11:54 AM
Help! plans for Smoothie or Mini Sport Edjahar42 The Builders Workshop 6 May 25, 2012 11:35 AM
Sold Balsa USA Smoothie Kit Un-Opened Box 52" Span 40-50 2-Stroke Sport R/C FlyinPhilsPhotos Aircraft - Fuel - Airplanes (FS/W) 0 Mar 14, 2012 08:28 AM
Discussion Brodak ARF Smoothie dankar04 Control Line 1 Sep 14, 2009 09:18 PM
Smoothie Maiden and Mixing question dpoles Parkflyers 7 Jul 01, 2004 02:07 PM
