Old Jan 21, 2013, 01:14 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
I plan to have a symmetrical airfoil tail, mainly for looks and balance. But if I find the pendulum effect comes into play ill make a hole in it and install a variable pitch tail prop to keep the craft level in all circumstances. that way I only need roll compensation on the cam mount so the tilt can just be used for tilting. Ill never run out of tilt that way. Had it before on a quad that used the tilt servo for lining up shots and compensation, in forward flight the mount tilted up to compensate and I ran out of control to point the mount up. not a big issue unless I was going for a level view at speed but still a pain.
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Jan 23, 2013, 03:02 AM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Originally Posted by Freakazoid View Post
Has anyone ever used an active tail? As in servo mounted so it tilts to compensate pitch axis movement?
I suppose that could help it fly straight and narrow when you keep a bit of headway on it.
yep, just dont try flying backwards, it would tilt to make any error worse !
matwelli is offline Find More Posts by matwelli
Old Feb 03, 2013, 08:24 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
So now im at the stage of setup and tuning.. (yes finally)
And straight away I run into an issue, a WHOLE lot of servo jitter, even when its not armed.
As an added bonus, servo values remain at 1500 when I arm it and move it around while connected to multiwiigui.
And the hits just keep coming, theres a buncha I2C errors because hobbyking neglected to include some decent multiwii defines.
Oddly enough the sensors all seem to be functioning in the multiwiigui.
I have this board: http://hobbyking.com/hobbyking/store...dProduct=27108
Hooked up as shown here:
... anyone?
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 03, 2013, 08:47 AM
Joined Jun 2007
are you using digi servos? if not, get some!
CJ
Old Feb 03, 2013, 08:57 AM
Freakazoid's Avatar
Joined Dec 2004
Im using metalgeared analogs. Digis are stupidly expensive I think?
EDIT: Oh wow, prices on those got shot to hell huh? I see em for barely 5 bucks now.
Which one do I need though? Prefferably a drop-in replacement for a standard MG90/HXT900 servo.
Old Feb 03, 2013, 09:11 AM
Joined Jun 2007
Id go e-max 12g digi metal geared. I can get them locally for about 7. I use them on everything now, Planes, Multis, Gimbals. most flight controllers output a PWM signal that has such a fast refresh rate that they'll fry analogue servos.
CJ
Old Feb 05, 2013, 08:19 AM
Freakazoid's Avatar
Joined Dec 2004
Can anyone tell me where I could adjust servo throw in multiwii firmware?
I cant have them doing maximum throw, it makes the mechanism bind.
Also, is there a minimum strength/speed I should look for when picking a digital servo?
Old Feb 05, 2013, 08:42 AM
Freakazoid's Avatar
Joined Dec 2004
http://www.hobbyking.com/hobbyking/s...dproduct=14279
Would these make good candidates to replace these?
http://www.hobbyking.com/hobbyking/s...g_0_10sec.html
Same size and strength, also metalgeared, but the digital one is faster.
I really hope going digital is gonna solve my servo flip-out issue though..
Don't wanna blow 20 bucks on nothing.
Old Feb 05, 2013, 11:28 AM
Joined Jun 2007
If the torque is the same go for it (at work ATM so I can check). As for adjusting the throw. Move the pushrod in a hole on the servo arm. You'll get better torque and resolution than you would if you just limit the endpoints.
CJ
Old Feb 05, 2013, 01:38 PM
Freakazoid's Avatar
Joined Dec 2004
It doesn't work like that with this mechanism.
Moving the ball joints closer to the middle will make the balljoints at the top bind even sooner.
Old Feb 05, 2013, 01:44 PM
Joined Jun 2007
Could you fashion a little adapter block that would screw into where the motor mount ballpoint is, then 90 degrees round the block refit the ball joint so that its on the same axis as the servo arm ball joint. Almost like an 'L' shaped piece (to get the idea). That would prevent binding.
CJ
Old Feb 05, 2013, 03:08 PM
Freakazoid's Avatar
Joined Dec 2004
Yes I know what you mean and it would indeed fix the problem, no I cant make one because I dont that that kind of tools. :')
Old Feb 16, 2013, 04:58 PM
Freakazoid's Avatar
Joined Dec 2004
Soooo anyone recommend a digital servo from hobbyking I could use on this puppy?
http://hobbyking.com/hobbyking/store...dproduct=14279
This one any good?
And also, what if the digital servos end up jittering too, what would I change to fix it?
Old Feb 17, 2013, 01:25 AM
Joined Jun 2007
If the digi servos jitter send them back :P. On the bench, on a servo tester they shouldn't make a sound when still. Oh and braid the servo leads if your getting some interference from the ESC wires. You'll be fine. And that HK servo looks good to me . Best off reading the HK reviews at the bottom of the page. Luckily HK don't screen them so if a product is rubbish you'll read all about it :P.
CJ
Old Feb 17, 2013, 01:50 AM
Freakazoid's Avatar
Joined Dec 2004
The plain analog servos dont jitter on their own either, its the firmware doing that..
Discussion A method to the madness: How to balance 3 bladed props midiman007 Multirotor Talk 6 Apr 19, 2015 12:44 PM
Cool New Shipping Method: The Best Method Ever boredom.is.me Trader Talk 10 Jul 27, 2012 11:21 PM
Discussion am so mad lost 90$ burro breath Flying Wings 30 Jul 14, 2007 07:21 PM
so mad I could spit nails! dalbert02 Electric Plane Talk 35 Feb 24, 2004 07:30 AM
I Am So Mad!!! adam_jorgensen Electric Heli Talk 19 Jul 19, 2002 04:49 PM
