Old Nov 29, 2012, 07:12 AM
chambo88 is offline
Find More Posts by chambo88
1 can never have 2 many planes
chambo88's Avatar
Australia, QLD, Surfers Paradise
Joined Sep 2011
Build Log
my largest model! FA-18 epp 900mm pusher
last build for myself (for real this time) before i go back home, wanting to build something that starts to test my building skills in terms of inovation and efficient building.
have chosen to do one of my all time fav's, the FA-18.
the major thing for me to accomplish on this model will be a fully articulating elevator surface, such as the real hornet.
alternative add-ons to think about are flaps, airbrakes (rudder and panel brake) and maybe a clear plastic canopy..
also want to incorporate a removable wing as this will be a fairly large model to trying to haul it on a back pack along with 4 others models on my ride to the park would be interesting
ordering the parts and foam today and drawing up some plans.
predicted specs:
wingspan: 900mm
lenght: 1300mm
weight AUW: (predicted) 750-800g
motor: DTM 2836 3000kv Outrunner Motor
esc:TURNIGY plush 60AMP
prop: 5x5 or 6x5 apc-e
servos: x6 9g's
battery: 3000mah 3s
more coming soon!
chambo88 is offline Find More Posts by chambo88
Old Nov 29, 2012, 07:24 AM
essadiq is offline
Find More Posts by essadiq
essadiq's Avatar
Joined May 2012
Originally Posted by chambo88 View Post
last build (for real this time) before i go back home, wanting to build something that starts to test my building skills in terms of inovation and efficient building.
predicted specs:
wingspan: 850mm
lenght: 1240mm
weight AUW:
motor: D2826-6 2200kv Outrunner Motor
esc:TURNIGY plush 40AMP
servos: x6 9g's
battery: 1300mah - 2200mah 3s
more coming soon!
thanks chambo .
i wanna know if i can use 6*5 with the 2200 kv motor
because in the specs in hobbyking they say only 5*5
and thank u for the thread
essadiq is offline Find More Posts by essadiq
Old Nov 29, 2012, 07:29 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
yeah it should be fine. i have used a 7x4 with this motor and it ran perfectly fine.
7x4 drew 30 ish amps at WOT
5x5 drew 17-18 amps at WOT
so a 6x5 would be in the 25amp range i would assume.. and you may find its better than the 7x4 becuase of the smaller diameter could give higher top rpms and therefore increased speed while keeping low end torque
Old Nov 29, 2012, 09:40 AM
Marlbororman is offline
Find More Posts by Marlbororman
United Kingdom, England, Hull
Joined Aug 2011
i run 6x4 on all my 2826 2200kv motors, fine and good pull and speed too.plus longish flight times with 2300 mah loongmax lipo`s
Marlbororman is offline Find More Posts by Marlbororman
Old Nov 29, 2012, 10:49 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
sounds good.. will try it out as well thanks for the tip!
Old Nov 29, 2012, 11:50 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
ok so stage one complete! plans are cut out and just waiting on foam and parts now! this is guna be a big light bird. hehe
Old Nov 29, 2012, 01:45 PM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
so progress on the full moving horizontal tail section.
using 5mm alloy rod with a 2mm steel push rod as the arm, the alloy rod will go through the tail fuse and also into the elevator a fair way and the steel rod will have a nylon arm attached to the end which will attach to the elevator push rod to the servo.
so far it seems pretty sturdy and rigid.
here are some pics to show the idea of it all and its rrange of movement.
Old Nov 30, 2012, 05:03 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
as u all can imagine im still waitin on parts, so more progress on what i can do while im waiting.. have the programing for the control surfaces done and dusted.
elevators operate independant of each other and have mixing with the ailerons as well ailerons have a single stage of flaps. initially i wont be installing flaps to try and save weight and also so i can learn the plane in the air.. maybe later on i might put a set in and mix a second stage of flap for super slow landings
here is the vid of the programing in action
order-
up elevator x2
down elevator x2
right aileron
left aileron
up elevator > left aileron
up elevator > right aileron
down elevator > left aileron
down elevator > right aileron
flaps down and back up..
fa-18 control surface programing (0 min 25 sec)
Old Nov 30, 2012, 05:32 AM
Joined Aug 2011
i used cf rod and tube, and drilled a servo horn to slide onto the cf rod then pinned the horn to the cf rod too. had a horn work loose on a previous f18 and lost it nose in. above set up is same on my 150% jetset f18 too. works a treat.
Joined Aug 2011
there is a lot of force on them big tail surfaces
Old Nov 30, 2012, 06:11 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
yeah i reckon there will be, thats why im using a seperate servos for each elevator, also the servo arms will be quite long and ill tune the servo throw limits to a lower maximum, the extended arm will increase the torque of the servo on the elevator surface, hopefully enough..
Old Nov 30, 2012, 06:13 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
also the reason i went with alloy and steel can give up the weight for peace of mind..
Old Nov 30, 2012, 09:46 AM
Joined Aug 2011
I like the idea of seperate elevator servo`s , gives elevon and aileron mixing options. i ran linked elevon/ailerons on the su37, had max throws set up for some wicked moves
Old Dec 01, 2012, 07:12 PM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
foam arrived this morning! so started cutting and shapping since im still waiting on the parts. here are the pics of the progress as it happened
Old Dec 02, 2012, 06:10 AM
iceaxe is offline
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
Mark this is brilliant cant wait to see this in the flesh
iceaxe is offline Find More Posts by iceaxe
Build Log My attempt at little EPP pusher - opinions needed! ffranck Foamies (Scratchbuilt) 42 Jul 19, 2014 09:28 AM
Build Log ME-262 Schwalbe epp twin pusher chambo88 Foamies (Scratchbuilt) 57 Sep 19, 2012 01:56 PM
Discussion EPP Slofly Pusher Cat lb4185 Foamies (Scratchbuilt) 2 Aug 04, 2012 08:53 AM
Sold EPP Mig-29 Fulcrum Pusher Jet kuczy Aircraft - Electric - Airplanes (FS/W) 3 Jul 03, 2012 12:30 AM
Discussion FA-18 Profile Pusher Build frednjess Pusher Prop Jet Models 18 Jun 01, 2011 02:30 PM
