Old Nov 30, 2012, 10:44 AM
freezywilly is offline
Find More Posts by freezywilly
Joined Jan 2012
Final comment the msrx is fbl. What the f48 will bring to the party is tbd.
Choose what is easiest for you to buy and support.
freezywilly is offline Find More Posts by freezywilly
Old Nov 30, 2012, 05:40 PM
jameschen072 is offline
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
Originally Posted by Balr14 View Post
Based on your images and review, I'd like to offer some comments:
Long, narrow blades have higher tip speed than wider shorter blades and will provide more stability. This will make the heli somewhat less responsive. The greater tendency to roll is because this blade configuration is not as easily influenced by the flybar. Remember, this 45 head design directs movement to the head and the flybar retards it.
If you are getting 8 minute flights there's nothing to indicate the motor is inefficient. In fact, swinging those long blades requires more torque than you would get from a coreless motor with no armature.
Thanks for that Balr14,
Was just basing my comment on the experiences I've had with the super fp and how switching the motor to a comparable coreless one vastly improved performance and flight time. The reason why I said it was inefficient was because the motor got quite hot even in the very cold weather that we're having here these days. I agree that 8 minutes is pretty good though.
Might give swapping motors a try just for the sake of experimentation I guess
Your comment on the long thin blades providing more stability and less responsive flight characteristics is accurate. That is the experience one gets when flying the f47. I really hope the fbl version would be a better flyer..fingers crossed
jameschen072 is offline Find More Posts by jameschen072
Latest blog entry: The Fei-Lun FT011 Review
Old Dec 02, 2012, 07:25 PM
The flightless bird
Joined Aug 2004
I think what the F48 will have as an advantage is its price.. Which definitely is going to be cheaper than comparable blade helis. That said, it's really up to the programming too... This being their first fbl bird, they'll have to make sure that they do a mighty good job.
Old Dec 02, 2012, 09:54 PM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
From this review, what I understand is that while the build quality is good, the flying quality is maybe not that great. The v911 has some wild servo throws at DR and handles wind very nicely. I think I'll keep my v911.
What I need is a FBL 4 ch. to use as a simulator for 6ch FBL. Hopefully the F48 will fit the bill. I'm surprised that they have not been able to release it yet, in time for this year's shopping season.
Lentar is offline Find More Posts by Lentar
Old Dec 03, 2012, 12:02 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I disagree with the premise that the "flying quality is not that great". You aren't going to have the stabilization effects of a very latent 45 flybar when you decide to move on. Once you get away from this design you will experience a lot characteristics you probably won't like, but that's the cost of performance. Blade shape and design plays a huge part in determining flight characteristics. You aren't going to learn anything by getting another heli with exactly the same properties as what you had before. So this is very pertinent experience. Any time I can learn something that improves my skills, I count it as a good experience. Especially if you are older. You would be amazed at how quickly skills you don't use deteriorate.
This wasn't meant as a dig at you Lentar, you just brought up a good talking point.
Balr14 is offline Find More Posts by Balr14
Old Dec 03, 2012, 06:08 AM
GuardianLegend is offline
Find More Posts by GuardianLegend
Joined Jul 2012
Ordered one cant wait now :/
GuardianLegend is offline Find More Posts by GuardianLegend
Old Dec 03, 2012, 09:15 AM
Lentar is offline
Joined Oct 2012
Your opinion is always appreciated!
What I need is an indoor heli that I can use as something of a FBL CP simulator. I was looking at the SP 127, but it seems to have bad user reviews. I will have to wait for the F48 or v922 (it should not be too pricey, so Walkera and Blade are out).
Old Dec 03, 2012, 05:07 PM
Aiolos is offline
Find More Posts by Aiolos
Trying to fly
Joined Dec 2012
F47
Newbie here,I just ordered one last night..time will tell.This is my first heli so I think it's a good choice from what I,ve read
Aiolos is offline Find More Posts by Aiolos
Old Dec 06, 2012, 08:28 AM
saintpipo is offline
Find More Posts by saintpipo
Joined Feb 2012
Can use F45 TX to control F47
saintpipo is offline Find More Posts by saintpipo
Old Dec 06, 2012, 10:38 AM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Is that a hope or do you know something we don't?
The tx that comes with the F47 looks the same as the one that came with my x200 quad, which is NOT backward compatible with the x100 nor the F45.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Dec 07, 2012, 04:39 AM
The flightless bird
Joined Aug 2004
I believe there are 2 versions of the F45, the newer of which may be compatible with the F47. That is just speculation though... as g said, the F45 that most people have here has a different protocol to the F47
Old Dec 07, 2012, 04:47 PM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
regards . . . g
Just received my F47. The transmitter is the size of the V911 transmitter and has a different protocol then the F45.
After only 2 batteries in the advance setting, I would say that the F47 is more docile, less affected by ground effect, is a lot quieter, accelerate vertically faster and hover a lot better then the V911. Every movement are slower, the throttle is lagging, the forward momentum is greater and the tail is slower to compensate then a V911. Fell a lot heavier. The servo arms are set short for now.
Except for the tail blade leaving the motor shaft easily, my F47 didn't suffer from few wall crashes.
A good candidate for precision landings and living room winter flying....
fauconnier is offline Find More Posts by fauconnier
Old Dec 07, 2012, 09:57 PM
Aiolos is offline
Trying to fly
Joined Dec 2012
Glad to here it,I was trying to get out of the mainstream of what everyone else buys then I seen the F47 thought it looked "cooler"than the rest plus the reviews all seemed mostly positive...any chance of vids with yours?
Old Dec 08, 2012, 02:50 PM
fauconnier's Avatar
Joined Jul 2012
Jameschen, you said that the tail hold very well, are you sure ? A full throttle, full battery, will make my F47 spinning 100 % of the time. When flying fast/full speed outdoor, most of the time the tail doesn't hold perfectly, making the F47 doing half spins to compensate. A pity. Although, the fast forward flying is more rectilinear, and may be faster, then a V911. The nose drop less but slowly the F47 is taking more speed. Fell like a bigger helicopter.
Old Dec 10, 2012, 10:23 PM
The flightless bird
Joined Aug 2004
fauconnier, the tail holds very well for me, did you check the trim? did you initiate the gyro correctly?
Discussion MJX F47 - baby brother to the F45 gordonzo Micro Helis 110 May 01, 2014 09:22 AM
Mini-Review The RC EYE One Review ***Updated: Short flight video! *** jameschen072 Mini Multirotors 195 Aug 06, 2013 08:45 AM
Discussion MJX X100 Review ***Updated: Video*** jameschen072 Mini Multirotors 143 May 02, 2013 10:34 PM
Mini-Review Walkera CB100 Review with pictures and video coming soon Tom Z Micro Helis 46 Jul 24, 2010 10:42 AM
