Old Nov 30, 2012, 12:16 PM
Dannyboy85 is offline
Find More Posts by Dannyboy85
Dannyboy85's Avatar
United Kingdom, England, Southport
Joined Jan 2011
A used DX6i is 50 and orange receivers are 3 why not do it the right way. There is no way I would spend all that time swapping planes....
Dannyboy85 is offline Find More Posts by Dannyboy85
Old Nov 30, 2012, 12:54 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
And, these receivers are not heavy duty items - plugging and unplugging the servos a lot will eventually cause issues with the plug itself, break the pins off the board, etc...
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 30, 2012, 04:10 PM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Solentlife is correct and says what I've said. I totally agree with all he says.
Rebinding will not help in any manner. If you use a 9x you still have to switch the Tx to the model concerned. If your Tx has switches (HK T4 or modified T6), setting them for a different model is no different from switching the 9x to the correct model (model memory) or using the computer to reprogramme the T6.
In all cases the Tx is talking to and Rx it was previously bound to. The only question is, is it saying the right things.
Mac50L is offline Find More Posts by Mac50L
Old Nov 30, 2012, 04:38 PM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Like a lot of newbie questions this falls into the category of, 'if you had to ask, you don't want to go there'.
If you know how to do it, you don't need to ask.
How you going to learn then? The hard way by messing it up like most of the lessons in this sport.
flydiver is offline Find More Posts by flydiver
Old Nov 30, 2012, 05:00 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by berts View Post
hobbyking 2.4ghz 6ch [hk-t6a v2]
my hobby king turnigy9x v2 has 20 model memory's, i have a RX in each plane 10 so far...
fastfwd is offline Find More Posts by fastfwd
Old Nov 30, 2012, 05:53 PM
BigIron357 is offline
Find More Posts by BigIron357
25+ years of RC flying
BigIron357's Avatar
United States, FL
Joined Aug 2012
Originally Posted by solentlife View Post
The art of 'really trimming' a model seems to have gone ... our old ways of correcting the surfaces after a trimming flight was good and still is good practice today. I had a whole hangar of planes I flew on my 3 Tx's ....
Nigel
That is so sad but I guess I've seen it with my own eyes. My flying buddy has been flying RC for over 5 years and can't fly a trim flight on a plane by himself. And after watching me trim fly his Parkzone F4U, he asked me flat out what I was doing with the clevises on the ailerons and elevator! Once I explained, he still didn't get it and said that he just uses the transmitter to set the trims. I never did get a straight answer from him on why he needed to repeat trim flights on several of his models. Maybe he relies on the transmitter too much.
I remember the days when reversing a control direction simply meant switching to the other output arm on a servo or maybe moving a control horn to the opposite side of a rudder or something. There was no such thing as reversing a servo, so setting it up right the first time was required. I guess that's too difficult for some folks nowadays.
As for me, I now have 3 planes on the drawing/building boards and will set those planes up just like I've done in the past.
BigIron357 is offline Find More Posts by BigIron357
Old Dec 01, 2012, 01:57 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Really interested how you have 20 memory's on a 9x ? You can have 20 Rx's bound to it - but you will still only have the standard 8 memory slots .....
The standard 9x (whether Turnigy, Imax, Eurgle or the real name FlySky) has only 8 memory slots.
The er9x I believe has 16 or maybe more.
Second the 9x doesn't have model match - means that any slot still triggers any Rx bound to the 9x.
Nigel
solentlife is online now Find More Posts by solentlife
Old Dec 01, 2012, 01:58 AM
solentlife's Avatar
Joined Jan 2010
Many thanks ... I was beginning to wonder if I was alone then !!
Nigel
Old Dec 01, 2012, 09:59 AM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Originally Posted by hoghead5150 View Post
that radio has no model memory. so it will only bind to one receiver at a time.
if you had 2 planes (or 10 it doesn't matter), you could install receivers in all of them. BUT when you get ready to fly one, you will have to bind the transmitter to the receiver. then if you wanted to fly another plane, you would have to rebind the transmitter to that planes receiver.
Again, this is completely wrong advice. The transmitter doesn't bind to the receiver--the receiver binds to the transmitter. I have four receivers bound to my non-computer DX5e transmitter, Slow Stick, UM T-28, Vapor and Radian. With any of these planes, I switch on the TX, switch on the Rx, check servo direction and neutral trim, hit the throttle and fly--no binding necessary again for any plane I fly.
To repeat. It is the receiver which remembers which transmitter it listens to. This is called binding. The transmitter (with a few exceptions) has no clue and doesn't need to know which plane is bound to it.
The only thing special about model memory is that you tell the transmitter which plane you're flying and it remembers your settings for that plane. Everybody thought that was way cool until they inevitably chose the Vapor when they were flying the MiG 21. CRASH! Then the hotshot radios actually received an ID signal from the receiver to tell them what plane (or at least what receiver. If you switch the receiver from one plane to the other all bets are off) it's attached to and if you pick the wrong model the radio won't fly it.
That's it. You can bind a thousand planes to any transmitter--computer, non-computer, doesn't matter.
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Dec 01, 2012, 12:04 PM
Rocket Programmer
Joined Jul 2007
Yup, I have both the Mini Vapor and regular Vapor bound to the same memory slot in my DX7 - saves me a memory slot, and those two planes are very similar, so it was easy to mechanically adjust them both so they agree on the trim settings.
Old Dec 01, 2012, 12:56 PM
keef30 is offline
Find More Posts by keef30
United Kingdom, England, Compton
Joined Feb 2008
I have a HK T6A V2 TX and 4 planes all with HK receivers...
I just stuck a paper sticker on the back of the TX with the servo direction switch setup for each plane, and the normal trim setup.
I must say i prefer the older style trim sliders anyway.
The only problem is HK dont make a micro RX that works with thier TX. One of my planes should really have a micro RX... In the end i just took the casing of the standard HK RX, put some heat-shrink over it and changed the connector pins for right-angle ones (as i'm a dab hand with a solder sucker!). I only fitted new right-angle connectors for the connections i needed - the rest i just removed completly...fitted in the plane no problem...
keef30 is offline Find More Posts by keef30
Old Dec 01, 2012, 02:59 PM
Mac50L is offline
Joined Oct 2011
I put the sticker on the plane near where the battery plugs in so it is seen as the plane is connected.
Switches on the T6A? Have you put switches on yours too? On the front like a T4A? They both use the same plastic case so the slots are there for switch fitting.
I must say I prefer the older style trim sliders anyway.
You can trim them without looking at the screen on the Tx to see how far you have gone. Really sensible that "old" technology. Trimming by feel.
Old Dec 02, 2012, 06:32 AM
keef30 is offline
Joined Feb 2008
Sorry Its a T4A....
Help! Separating retract power from Rx battery...will this work mewannafly Power Systems 9 May 05, 2013 11:35 AM
Sold 6 channel DSM2 RX's for sale 25 Each trevjonez Aircraft - General - Radio Equipment (FS/W) 9 May 28, 2012 09:50 PM
Discussion What size plane to run separate RX batt? TomM Electric Plane Talk 19 Mar 15, 2011 07:50 PM
Sold Closed to separate listing -2 Planes (PZ), 2 Helis(E-Flite), 1 TX (dx6i), RX (ar6200) major.monogram Non R/C Items (FS/W) 1 Jun 07, 2010 10:26 PM
Question Separate ESC for each plane? panzerd18 Power Systems 14 Mar 15, 2006 07:58 AM
