Joined Nov 2012
sorry if it was not clear what i ment I did not mean flying more than 1 plane at a time I wounderd if on my tx i could have 2 separate rx's bound so i did not have to remove one and swop it over every time i switched planes. bert QUOTE=Mac50L;23392454]NO.
You can have dozens of planes bound to one HK T6A V2. Just use one plane at a time (that's normal, who has more than one in the air at a time?) but having switched the first plane off, as soon as you switch on the second one it will be bound as it was last time you used it. Hopefully the servos all work in the same direction. I fitted switches to the front of my T6A so it looks like a T4A. On one plane I need to reverse 2 switches to get the control sticks to work in the right direction. I should know as I have done it.[/QUOTE] |
My 9x with 8 memories currently has 13 Rx's bound to it. This also means that you can have more than one Rx in a big model to cut down length of leads etc. Nigel |
| Thread Tools | |
| Help! Separating retract power from Rx battery...will this work | mewannafly | Power Systems | 9 | May 05, 2013 11:35 AM |
| Sold 6 channel DSM2 RX's for sale 25 Each | trevjonez | Aircraft - General - Radio Equipment (FS/W) | 9 | May 28, 2012 09:50 PM |
| Discussion What size plane to run separate RX batt? | TomM | Electric Plane Talk | 19 | Mar 15, 2011 07:50 PM |
| Sold Closed to separate listing -2 Planes (PZ), 2 Helis(E-Flite), 1 TX (dx6i), RX (ar6200) | major.monogram | Garage Sale/Large Lot Ads | 1 | Jun 07, 2010 10:26 PM |
| Question Separate ESC for each plane? | panzerd18 | Power Systems | 14 | Mar 15, 2006 07:58 AM |
