Old Nov 28, 2012, 09:47 PM
GRacing is offline
Find More Posts by GRacing
Portugal
Joined Apr 2002
Eage treeV4 stoped working
Hello all of you!
I think eagletree logger is a major tool for any RC modeler, but i'm felling unlucky with them.
The first one i have stopped working...it would get very hot on PIC sede, v3
After that bought a eagletree V4 150 AMP and last weekend as flying mine heli with it like i always do....conected The main pack...and The Power painel showed me The normal information..PKV..AMP...mah....rpm,and started flying it..
unfortunately when i landed The heli to check The mah consumed, saw that Power painel wasnt displaying any information neither The status led as blinking.!!
When arrived home i took it off from The heli in order to try to see something anormal, and after a while i checked that a small IC that is under from one of The current sensor legs is pinched from The outside..a small bubble....there isn't ay reason that can explain that..até least for me!!?
Can anyone help me please!?
Best regards to all of you, and thanks in advance
GRacing is offline Find More Posts by GRacing
Old Nov 29, 2012, 06:21 PM
GRacing is offline
Portugal
Joined Apr 2002
Can´t anyone give me an input, specially from eagle tree!?!?
Old Nov 30, 2012, 12:45 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
I think you fried the voltage regulator IC. How many of what type cells were you running?
dhares is offline Find More Posts by dhares
Old Nov 30, 2012, 06:29 AM
GRacing is offline
Portugal
Joined Apr 2002
eagle tree problems
Mello
First of all , thank you for input...It seemed so that as The voltage regulator...can you please see its parte number!?
I cant see mine because of The burn defect..
im using The same Power hás i always used in The last 6months without any problemas until now...12S gensace 5300mah 30c limpo
Best regards
Old Dec 01, 2012, 08:30 AM
dhares is offline
Saline, MI
Joined Jul 2006
Repairing it yourself is almost impossible. I'm assuming the issue with returning it to Eagletree is the long lead time from Portugal. Your's and mine are different. Mine has a lot more solder between the wires and the Hall effect sensor. Makes me wonder if you got the right version. The hall effect sensor says 100A too. Even if you replace the regulator, we still don't know why it died. I'll try to dig out mine this weekend but no promises. It's buried in the bottom of a boat I stored for the winter..
Meanwhile, I'd get a support ticket started so you can get real help.
Old Dec 03, 2012, 05:39 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi GRacing, and sorry to hear about your issue!
Is it possible that high voltage came in contact with one of the eLogger's input pins? The type of damage to the IC shown in the photo is usually what happens with high voltage. That IC is not field replaceable, and even if you did replace it, the unit will almost certainly not work (if I'm correct about the high voltage).
As Dave mentions, please open a support ticket with us at http://ticket.eagletreesystems.com and we'll get you taken care of. PS: that is a 150 amp sensor.
billpa is offline Find More Posts by billpa
Site Sponsor
Help! Can't calibrate pan/tilt on Eage Eyes station Thor_VR4 Eagle Tree Systems 1 Jun 24, 2011 01:01 PM
35 A esc stoped working rotccapt Power Systems 1 Oct 21, 2005 10:21 PM
BR Stoped working all of a sudden szeto BladeRunner Heli 2 Apr 06, 2005 10:14 PM
Mustek Mini 3 stoped working from the cold steve ypsi mi Aerial Photography 14 Feb 01, 2004 01:55 PM
