This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Nov 28, 2012, 08:53 PM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Blade MCX autopilot
Finally got it to where it could drain an entire battery in a hover. It only lasts around 2 minutes. The IR leds consume enough power to make the voltage regulator hot.
The Edmond Optics IR filter ended up necessary. The higher shutter speed it requires got the framerate up to 30. The floppy disk required a shutter speed that was too slow to get 30fps. Some more software optimization got the position sensing good enough to do it.
It was entirely a matter of improving the position sensing speed. A pan/tilt camera using PWM to estimate the pan/tilt angles for every frame is going to max out in a 2m hover radius. It basically needs all the empty space in the room to hover.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Sold Blade mCX Heli Blades & Boom SRM Aircraft - Electric - Helis (FS/W) 0 Nov 19, 2012 07:01 PM
For Sale Blade MCX and Blade SR AKD001 Aircraft - Electric - Helis (FS/W) 6 Apr 12, 2012 01:03 AM
Sold Blade MCX with glow in the dark blades and tail plus extra parts flohio117 Aircraft - Electric - Helis (FS/W) 7 Mar 01, 2012 09:06 PM
Sold $35.00 Eflite Blade MCX/2 - 5in1 Replacement Board also for Orig MCX/MCX S300 HeliFlyer711 Aircraft - Electric - Helis (FS/W) 3 Jun 20, 2010 03:53 PM
Sold Blade MCX and Blade MCX S300 head04 Aircraft - Electric - Helis (FS/W) 1 Mar 24, 2010 09:40 AM
