Joined Nov 2012
I have the Optic 6. I have the duel rates set up. For example when I switch to high rates on the elevator the elevator moves and the plane starts to dive. If I trim that out when I switch back to low rates it climbs and have to trim that out. Does that make sense?
no definitive answer.
I would check your subtrim (S.TRM) for the elevator channel. You want to keep it close to zero by mechanical adjustment of the servo. Other than that you may have some Tx mixing coming into play. There's a lot of Optic 6s out there and the radio forum may be of more help. Good luck |
Larry |
| Thread Tools | |
| Sold **SOLD** Hitec Optic 6 2.4 GHz + 2 Optima 7's and 1 Optima 6 | PBR600RR | Aircraft - General - Radio Equipment (FS/W) | 6 | Jan 10, 2013 11:40 AM |
| Discussion Decision, hitec Optic 6, Optic 6 sport, dx6i OR?? | MikeontheBike | Radios | 38 | Sep 21, 2012 10:42 PM |
| Sold Hitec Optic 6 72mhz w/spectra module + 6 receivers!!! | moparkris | Aircraft - General - Radio Equipment (FS/W) | 0 | Aug 11, 2012 06:45 PM |
| Wanted 72 mhz futaba 9c super , hitec optic 6, or hitec eclipse 7 | grfcon | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 16, 2012 05:54 PM |
| Sold Hitec Optic 6 and Optima 6 | TomM | Aircraft - General - Radio Equipment (FS/W) | 4 | Mar 09, 2012 06:07 AM |
