Old Nov 28, 2012, 05:57 PM
solodare is offline
Find More Posts by solodare
United States, NC, Charlotte
Joined Oct 2012
Question
motor or esc
i have the easy trainer 800 from BH, on my last flight i noticed the motor was making a weird sound, i thought it was probably me just being anal but it seemed sluggish when I launched it. brought it back down to have a look and when i tried to test the throttle again the motor would not spin up. it just sputtered there a few times like it was jamming up, then it would brake lose and spin a bit. after test the other controls it finally seem to brake free and run up but every time you close the throttle it jams up again. any ideas what the problem is? its a new plane with only 3 flights and no crashes other then the normal belly landing. no impacts.
solodare is offline Find More Posts by solodare
Old Nov 28, 2012, 06:07 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
It might be bad soldering joints on your connectors. Or a loose magnet. Can you spin the motor by hand freely or does it grind when the motor isn't plugged into the ESC?
acetech09 is offline Find More Posts by acetech09
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
does the motor make a noise? you mention sputtering.
cmdl is online now Find More Posts by cmdl
Old Nov 29, 2012, 09:42 AM
solodare is offline
Joined Oct 2012
acetech,
You can spin it by hand, and it doesnt seem to be grinding.
What did you mean about "not plugged in to the esc? is it bad to spin it with it still plugged in?
cmdl, sputtering as in power more then noise. but it did sound a little weird at first but this is one of my first outrunners so i dont know if its normal noise or not.
Old Nov 29, 2012, 10:07 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
can you run it without the prop? does it run fine then or still the same issue?
Old Nov 29, 2012, 11:37 AM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
every time i have had a motor sputter as in it is trying to turn but stops jerks ect,it has been the esc going out or gone out.
fastfwd is offline Find More Posts by fastfwd
Old Nov 29, 2012, 12:21 PM
solodare is offline
Joined Oct 2012
cmdl,fastfwd
It seems to have corrected its self for the time being.
Can i expect the esc to just die one day? what am i looking at here? motor sounds a little "scratchy" from time to time. I mean to say , under power, you can hear an anomalistic sound scratchy in nature and totally random.
For 80 bucks I guess i should just fly it till the wings fall off!
Old Nov 29, 2012, 12:25 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
if the esc gives out when you're in the air, they certainly will fall off! If you have a spare esc or can get one from someone else, plug that one up and see if the problem is replicated with one you know is good. If so, we can try something else.
erikc641 is offline Find More Posts by erikc641
For Sale 3D Foamie Combo or Just Motor + ESC, or Servos DJO Aircraft - Electric - Power Systems (FS/W) 3 Aug 16, 2012 11:54 AM
Discussion magic smoke: ESC killed motor, or motor ESC ? mopetista Power Systems 4 Mar 13, 2012 03:50 AM
Sold 45 or 50A ESC w/Bec will trade Hacker 2026M motor or Pheonix 25A ESC Flyextreme Aircraft - Electric - Power Systems (FS/W) 2 Nov 21, 2007 10:52 PM
Sold Rimfire motor, and Electrifly 9A ESC. $50 for both, or $30 for motor, and $20 for ESC edge5foamy Aircraft - Electric - Power Systems (FS/W) 4 May 18, 2007 12:18 PM
Wanted BP-21 or similar motor or motor/esc combo pc_pilot Aircraft - Electric - Power Systems (FS/W) 2 Jul 27, 2006 12:21 AM
