Closed Thread
This thread is privately moderated by tbroeski, who may elect to delete unwanted replies.
Old Nov 28, 2012, 04:30 PM
Afton VA
Joined Sep 2002
Trader Rating: 27
Urethane Foam -- Wing Repair Kit
Very hard to find small amounts. Kit is 2 oz of each A and B. #2 density
Care must be taken since this stuff expands a great deal.
Finishes to a very light weight hard surface.
$14 delivered (check. MO, cash)
paypal@adesigner.com ($15 regular PP)
Pictures show 1/16" of each in bottom of Dixi cup.
email: tom@blueridgesoaring.org with questions.
tbroeski is offline Find More Posts by tbroeski
Old Nov 28, 2012, 08:02 PM
Afton VA
Joined Sep 2002
Trader Rating: 27
Originally Posted by Tabasco View Post
How long (time) from 1/6 in dixie cup to finished.
About 3 min to expand and 10 to set firm and 30 to rock hard
Old Nov 29, 2012, 11:58 AM
Afton VA
Joined Sep 2002
Trader Rating: 27
Build log here
http://www.rcgroups.com/forums/showt...4#post23395218
Shows how to do a proper repair.
Old Nov 30, 2012, 01:28 PM
Afton VA
Joined Sep 2002
Trader Rating: 27
I've cleaned up the post and pricing.
Old Nov 30, 2012, 08:36 PM
gavoss's Avatar
USA, OK, Oklahoma City
Joined Mar 2001
Trader Rating: 93
Just in case you didn't get a chance to look at the linked repair, note that there is only 1/16" in the cup, not 1/6". I'm sure Tom will get around to correcting it. I ordered my pack yesterday, did you?
Thanks Tom.
gavoss is offline Find More Posts by gavoss
Old Dec 01, 2012, 09:00 AM
Afton VA
Joined Sep 2002
Trader Rating: 27
Thanks Tom.
The build log has it correct.
I fixed the one below
Thanks George for catching it.
Old Dec 01, 2012, 10:56 AM
gavoss's Avatar
Joined Mar 2001
Trader Rating: 93
I can imagine someone putting in 1/2 of the dixy cup and watcing it go all over their building board. Ha! I'd almost pay to see that.
Old Dec 03, 2012, 07:01 AM
Afton VA
Joined Sep 2002
Trader Rating: 27
If you have any questions when you get the stuff, let me know.
Went around fixing all the leading edge dings in my planes. If done right, there is not even any sanding needed. It makes a smooth hard surface. Kinda cool.
T
Old Dec 03, 2012, 10:19 AM
gavoss's Avatar
Joined Mar 2001
Trader Rating: 93
I've got to fix the very tip of an Icon wing tip and the root of the center section. I'll do it like Tom shows and let you know how it works. George
Old Dec 03, 2012, 11:21 AM
Clinton, Utah
Joined Apr 2008
Trader Rating: 38
Sending Paypal.
Greg
fabmaster911 is offline Find More Posts by fabmaster911
Old Dec 03, 2012, 03:32 PM
Afton VA
Joined Sep 2002
Trader Rating: 27
Don't forget to wax the mylar or plastic you use. Saves a lot of filling and sanding.
Old Dec 03, 2012, 04:15 PM
gavoss's Avatar
Joined Mar 2001
Trader Rating: 93
I just received my kit. Not only does Tom send the foam A&B parts, you get 3 pipetes and some mylar/acetate to aid in repair! WOW, I am really impressed. Thanks. Tom
BTW, what cleaner can we use to get the foam off of stuff while it's still wet? Thanks again. George
Old Dec 03, 2012, 05:12 PM
gavoss's Avatar
Joined Mar 2001
Trader Rating: 93
OK, here is my dilema. The skin on the top and bottom of the root section have sheared. I tacked them with CA. The spar is fine but I'm still going to put either CF or FG or some combination there of.
The tip is mush. The Rohecell foam on the inside is torn and shredded. I think I'll put some fiberglass on the bottom to give it some strength and then pour the foam into the hole in the top of the wing. I'll have more photos as things progress. George
Old Dec 04, 2012, 12:56 PM
Afton VA
Joined Sep 2002
Trader Rating: 27
Best to just wipe it off right away. This stuff is tough to clean off. I clean my injector with lacquer thinner, but if you get it on you fingers and let it set, it's not easy to get off. Wear gloves if you plan to stick your fingers in it.
Old Dec 05, 2012, 12:55 PM
New York
Joined Feb 2002
Trader Rating: 9
Cool, Tom. Will send for your kit.
Steve
SteveR is offline Find More Posts by SteveR
Closed Thread
Help! How do you keep glue off aileron wire when repairing a foam wing? Bill Mercer Parkflyers 4 Nov 29, 2012 10:01 AM
Discussion How do I repair my EPO foam Mig-15 wing? Remy130 Foamy EDFs 7 Jul 17, 2012 01:51 AM
Discussion Molding foam: Thermaforming vs. liquid urethane spencer6891 Foamies (Scratchbuilt) 7 Jun 28, 2012 04:29 PM
Wanted Carl Goldberg Extra 300 wing kit,or a repairable wing, please pm with info! ropotulec Aircraft - General - Miscellaneous (FS/W) 1 Jun 26, 2012 12:27 AM
Discussion Anyone play with this Liquid Urethane Expanding Pour Foam videorov Composites Fabrication 1 Mar 31, 2012 01:15 AM
