Joined Apr 2012
Bad props from HK.
I had one of these props this summer and, after several flights in an area with a few scattered rocks, it broke in the air. Luckily I was able to shut the motor down before it tore the firewall out. When I examined the piece that was still attached there was a definite nick in it and I figured that I had damaged it on a landing. Well?
I stupidly got a second one without reading the reviews and went out to fly with it for the first time. I got up about 50 feet and pow! One blade broke where the shoulder merges in to the blade. Luckily, for the second time, I was able to shut down before any airframe damage. (Which is also a pretty good endorsement for the strength of the Specter 1800.) Upon examining the remnant of the blade I could see a substantial void in the plastic. Now I wondering if that "nick" was really caused by a rock or just where the plastic broke. Here's the link to the prop and, if you look at the reviews, you will see that others have had the same problem. http://www.hobbyking.com/hobbyking/s...propeller.html |
Latest blog entry: For motor builders
I bought a set of HK 13 x 6 CF series blades from them and they were the worst performing prop I've had on a sailplane. Lots of noise and no traction with a decline in climb with the same size Aeronaut or RFM from 2200 fpm to 1600 fpm.
They did not get enough use to have a chance to fly apart and now are in the shop junk drawer.
Latest blog entry: 1940 Megow Models Super Quaker
Every Prop same as every grinding wheel should have a MSRPM (Maximum Safe Revoultions Per Minute) molded on the blades not hidden away on some online site or no information at all
But how to change the situation
I have no experience with rctimer props ,but I do with lousy continuity of quality and aging of plastics that some use particlarly those orange horrors that go brittle after being out in the sun for a few days flying.
| Thread Tools | |
| Discussion bad vibrations from rctimer motor/prop adaptor (video) | helifrek | Multirotor Talk | 19 | Dec 25, 2012 12:40 AM |
| Discussion HK going from bad to worse | mike_o | HobbyKing | 12 | May 26, 2012 04:00 PM |
| Question Prop axis on wing centre line good or bad? | cmulder | Modeling Science | 1 | Mar 19, 2012 04:52 PM |
| Careful! Very poor and bad Service from Castle Creation - my case !! | marknopfler | Castle Creations | 5 | Mar 17, 2012 01:25 AM |
| Discussion New 6s Zippy from HK takes 98 minutes to charge at about 1c ? Bad cell ? | phranticness | Batteries and Chargers | 22 | Jan 24, 2012 10:18 AM |
