Old Nov 28, 2012, 01:04 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Plank 2.5
Time to start thread for the next bigger and better Plank. Current specs are shown below. We'll see how much it changes during construction.
Previously I mentioned that I ordered some parts from Hong Kong (Hobby King) and was waiting and waiting for it to arrive......
So at 11 days, it arrives from the other side of the PLANET. This is during the Xmas rush. No complaints on deliver. Kinda amazing really.
Very pleased with the stuff. Especially the switch. The black housing is solid anodized aluminum. The charge jack is mounted with a set screw ! very nice.
I've added a lost plane alarm to mix and will mount it in fuel port to serve as a horn for the alarm.....like it.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Nov 28, 2012, 03:04 PM
ege53 is offline
Find More Posts by ege53
What's goin' wrong?!
ege53's Avatar
Joined Feb 2005
I will be carefully watching this build.
Are you at all concerned with the sand-switch interplay?
Eric
ege53 is offline Find More Posts by ege53
Old Nov 28, 2012, 03:10 PM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
subscribed
I've had good results with those folks too. They do have a US warehouse - so some stuff is available in-country - comes much more quickly.
HerkS is offline Find More Posts by HerkS
Old Nov 28, 2012, 06:51 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Sand Proof
I'll make the switch sand-proof, when needed, by simply laying a piece of tape over it. It seems that the only thing that works with sand is a completely sealed covering like tape.
Sand will certainly get into the fuse between the wing/fuse joint, so I'll mount the switch on top in hopes of keeping it above the debris below.
If any switch is sand-proof all by itself, it would be this one. Nice tight mechanical lever in front of the electronics.
Also got an altimeter and lost plane alarm from Hobby King for this one. Both work great. Here's the "flight graph" of me carrying the unit to the 2nd story of my house.
Kent
Old Nov 29, 2012, 01:24 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Nice looking forward for the build
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Nov 29, 2012, 02:55 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Kent
Methinks there's something seriously amiss with your staircase
Stuart A is offline Find More Posts by Stuart A
Old Nov 29, 2012, 05:17 AM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
Nice looking design.
Wth regards switches, I believe there are now magnetic switches that are activated by a magnet from outside the fuselage- so the hatch can be firmly closed for the whole flight session.
Your design also prompted the thought- you have quite a bit of sweep in the wing design so when does a plank become a swept wing?
mhodgson is offline Find More Posts by mhodgson
Old Nov 29, 2012, 09:53 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I would think when the sweep is enough to start providing some benefits for that sweep.
Sweep can provide a effect similar to dihedral.
Sweep can allow non-reflexed airfoils.
Sweep with twist can provide some yaw stability, is in Horten style.
This wing has negligible sweep and has been design as a pure plank. A reflexed PW51 with no twist.
The magnetic switch sounds cool. I could sure use one.
Kent
Old Nov 29, 2012, 10:37 AM
mhodgson is offline
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
One example.
http://www.electricwingman.com/jeti-...ic-switch.aspx
Old Nov 29, 2012, 10:47 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Oh that is trick....like it.
Currently I am sand-proofing switches the mechanical way. I bury them and actuate with a short piece of music wire.
Kent
Old Nov 29, 2012, 10:52 AM
mhodgson is offline
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
Zepsus.com as well, 7A and 15A.
Might have to try one myself, it would save fiddling with small hatches and switched and cold windy slopes.
Looking forward to your build.
Old Dec 06, 2012, 08:36 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Still quite green when it comes to foam and glass so I'd thought that I'd start with the fuse. Masonite templates each side worked pretty well.
The camera decided to take a break part way through....here's what I got.
Slicing up some foam (0 min 26 sec)
Kent
Old Dec 08, 2012, 06:26 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Glassing the fuse
The fuse is currently lightly reinforced with some Kevlar UNI and some kevlar fabric at the wing area plus 2 layers of medium glass. I'll add more glass before I'm done, but first I'll populate the inside with formers and boxes, which will add some stiffness. I think I'll add some CF tow down the side, leaving the bottom open for clear antenna reception, then at least one more layer of glass.
Kent
Old Dec 20, 2012, 12:16 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Antenna tube in fin
The LE of the fin is hollow to serve as an antenna tube. The antenna wire will exit at the top, well clear of the fuse for bungee launching. At the base of the fin, created an elbow guide to transition to a plastic housing to carry forward. This system is big enough to fish a standard pushrod through.
Kent
Discussion APM 2.5 clone - MegaFlight 2.5 ralphwu Multirotor Electronics 1 Sep 24, 2012 01:18 PM
Sold Nano-Tech 4S 2.2, Turnigy 3S 1.5, Zippy 3S 2.5 Tx, Genesis 2S 4.5 Lipos WiperBlade Aircraft - Electric - Batteries & Chargers (FS/W) 6 Jul 27, 2012 12:46 PM
Discussion This Old Plank #2 Maiden and Final Flight frivilousteamrc Fuel Plane Talk 1 Jul 22, 2012 01:16 PM
2.5 Blade, 2.5 Blade XL Extreme, Spider 2.5 or Hypnosis 2.2M hbielich Slope 13 Sep 25, 2005 07:42 PM
Hitec Flash 5 System X, good for plank wings? DennisRB Radios 8 Dec 24, 2004 05:59 PM
