This thread is privately moderated by Green Fuel Boy, who may elect to delete unwanted replies.
Old Nov 28, 2012, 11:53 AM
Green Fuel Boy is offline
Find More Posts by Green Fuel Boy
Trader Rating: 30
Green Fuel Boy
United States, OR, Newberg
Joined Sep 2009
Trader Rating: 30
Sold
One RCEXL Optical Kill Switch and One RCEXL Tachometer Free Shipping
One Brand New RCEXL Optical Kill Switch and one RCEXL Mini Tachometer with Y-cable ""NEW in package"" Total price for two items is $27.50 dollars shipped USPS CON USA padded envelope. Paid with paypal. I will absorb the paypal charge. Free shipping!! I can ship to Canada for $3.50 more.
PM me for paypal payment address, please leave a description of what you are buying.
I have NEW Tenergy 6 volt 2000mah NIMH Ignition battery's for $14 each that be added to this order with no extra shipping.
These can be used as a remote switch to turn on/off a RC Airplane Gasoline engine ignition system. They can also be used to power lighting systems. The Rcexl Optical Kill Switch V2 uses a separate battery for power when not using a separate bec. The Rcexl Optical Kill Switch V2 does not use power from the receiver and this has no bec so the voltage going in from the accessory battery is the same voltage going to the item you want to turn on and off. The accessory battery can be up to 20 volt and 16 amp output for lighting or other devices.
This unit has no bec.
NEW Version 2.0
Remotely mounted bright LED ON/OFF indicator light
Fiber Optic Coupled Input/Output
Li-Pol/Li-Ion/A123/Ni-Mh/NiCad Input and compatible
Up to 20 volt 16amp output
100% surface mount technology
Heavy Gauge wire with Universal Connectors
Automatic Shut Down Feature when Transmitter or Receiver is Turned Off
Easy Installation
Light Weight
Thank you
GFB
Green Fuel Boy is offline Find More Posts by Green Fuel Boy
Help! RCEXL opto kill switch does not work tried three of them Go4it Engines 48 Jan 31, 2015 01:15 PM
Sold Two RCEXL Optical Kill Switches Free Shipping Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 6 Nov 15, 2012 09:08 PM
Sold RCEXL Ignition, Tachometer, Optical kill switch Timing tool Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 02, 2012 06:49 PM
Sold Two RCEXL Optical Kill Switches Free Shipping Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 31, 2012 11:28 AM
Sold RCEXL optical kill switches Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 5 Oct 17, 2012 12:26 PM
