This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Nov 28, 2012, 01:54 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Servo camera mount returns
So the servocity mount was voted off the island. With all the requirements for sensing its position, it was too slow. After PWM recalibration & a voltage experiment, the home made mount came back.
Another attempt to slow it down by running it on 3.3V made the motors stall. Tower hobbies said it ran on 3.3V. It must have been rediscovered many times but lost to memory that 3.3V makes it stall.
Then, the task of aircraft tuning resumed. There is a lot of noise in the position sensing, but given enough balancing, it can fly itself for a short time. Without a very good position readout, the feedback needs to be bare minimum & the balancing needs to be exact. The IR cameras only do 20fps while the visible cameras did 34fps, making for a much slower position reading.
The Syma X1 was more forgiving of balancing, but the Blade MCX is the vehicle of choice for micro UAVs because it is the smallest with full cyclic yet has the highest payload for its size.
Ended up putting a follower amplifier on the digital to analog converter, to eliminate any chance of the rc transmitter failing to receive the right voltage. That turned out to not be the problem.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Sold HK micro PCB Quad frame with led's and motors, and a Micro 2 servo Camera mount!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Apr 28, 2012 10:45 PM
For Sale Camera mount with servo actionplus Aircraft - Electric - Multirotor (FS/W) 2 Apr 25, 2012 05:40 PM
Discussion Alware 3-Axis 330/500X Pro V2 Camera Mount W/ Wide Angle 260D Digital Servos maikodk Multirotor Talk 0 Mar 20, 2012 04:14 PM
Discussion Mounting FPV cameras on servos Opt FPV Talk 2 Feb 29, 2012 03:58 PM
Sold 2-axis camera mount (MK HiSight) - including servos ed.ge Aircraft - Electric - Multirotor (FS/W) 2 Feb 27, 2012 03:38 PM
